Rear Hatch Opening Fix
Old Feb 1, 2005 | 07:41 PM
  #61
DIYZ's Avatar
DIYZ
performance nissan sells a higher strength strut for 350Z hatches. For vehicles with added wings.
www.performancenissanparts.com
Old Feb 17, 2005 | 02:46 PM
  #62
Edison_Chen's Avatar
Edison_Chen
I've just try it.. 4 Pennies, 2 on each side..
Is the rear hatch suppose to open all the way to the top?
Or does this just help the trunk pop open 1/2 inch when trying to open?
Old Feb 17, 2005 | 05:59 PM
  #63
Ed 718's Avatar
Ed 718
BRAVEHEART
Just help it pop up but it seems to work better in warm weather..Go figure
Old Feb 19, 2005 | 11:49 AM
  #64
BOOFER7's Avatar
BOOFER7
I have to say thank you to all of you for a simple suggestion, wich made my life easier. Your idea worked perfectly.
Thanks Much!!!!!!
-John
Old Feb 19, 2005 | 01:47 PM
  #65
zipman's Avatar
zipman
Default REAR HATCH
Wow why didn't i think of that, sooo simple works great, thanks. up goes the hatch
Old Feb 19, 2005 | 02:17 PM
  #66
LaidbackRacr's Avatar
LaidbackRacr
Default Re: REAR HATCH
I too just joined the DIY ranks this morning now the hatch pops up quite a bit more and have not had a problem since. This is great and belong is DIY of resources.
Old Feb 19, 2005 | 04:08 PM
  #67
Satchel's Avatar
Satchel
fixed mine last night. thanks!
Old Apr 6, 2005 | 07:50 AM
  #68
onecoolee's Avatar
onecoolee
Been to the dealership twice for this, and I didn't know there was a tsb out (and they didn't bother to check!)... they claimed it was fixed both times, still acted the same to me... about 20% of the time it opens all the way, 80% it gets stuck and requires 2 or 3 more button pushes to pop it open... I will try the $0.04 trick, and avoid another day at the dealership... thanks guys.
Old Apr 6, 2005 | 08:24 AM
  #69
TX-Ruben's Avatar
TX-Ruben
So happy I found this thread. 6 cents later, and I got pop-up action!
Old Apr 6, 2005 | 08:32 AM
  #70
onecoolee's Avatar
onecoolee
I wonder if a nickel will fit... ($.06 total per side) ... I want to be the first with the bling fix ! I will be sure to use shiny nickels !
Old Apr 6, 2005 | 08:43 AM
  #71
boma's Avatar
boma
the sad part is that the dealer should fix this no questions asked. we shouldn't have to put pennies into our 350z.
Old Apr 6, 2005 | 08:58 AM
  #72
ANXIOUZ's Avatar
ANXIOUZ
Same here. Twice I've had my car there and had them look at this while they were at it. It still works the same as yours.
They claim that it opens perfectly for them every time they try it. Yeah right.
Old Apr 6, 2005 | 08:59 AM
  #73
TX-Ruben's Avatar
TX-Ruben
I'm going with 6 dimes for the $0.60 cent bling job.
Old Apr 8, 2005 | 05:18 PM
  #74
bstfugtfomrfn's Avatar
bstfugtfomrfn
When I first saw this thread, i was happy to find solstice in such a novel deduction.
I proceeded to place 4 pennies in their respective positions amoung my hatch springs, and indeed; success.
I drank a Guiness, and exclaimed: 'BRILLIANT!'
I recently added a Nismo spoiler. The 4 pence I added was not enough to lift the hatch, so again, I added 4 more pence and indeed; success.
Again, I drank a Guiness, and exclamied; 'BRILLIANT!'
~AJ
Old Apr 8, 2005 | 06:01 PM
  #75
Ed 718's Avatar
Ed 718
BRAVEHEART
Wow can't believe some folks still find this thread....But glad it all help you guys. The Stealerships seem not to help us at all so screw them......
Old Apr 9, 2005 | 07:00 PM
  #76
goku's Avatar
goku
For all of you budget minding DIYs this works with just 2 pennies (1 in each side) as well.
Old Nov 19, 2005 | 02:24 PM
  #77
al_3rabi's Avatar
al_3rabi
I just tried my 6 cents and they worked just fine. I wanted to fix this 3 years ago, But, I have not had the chance to go to the dealer to fix it. My 3 year warranty will expire at the end of this month. I tried this trick today so I don't have to go to dealer and deal with their CRAP about this issue.
This my 6 cents.
Thanks everyone for your help with this problem.
Old Nov 19, 2005 | 05:49 PM
  #78
Ed 718's Avatar
Ed 718
BRAVEHEART
^^ 3 pennies on both sides may be too much pressure and may dent your latch so check it to make sure....
Old Nov 20, 2005 | 12:42 AM
  #79
MySunset350Z's Avatar
MySunset350Z
had to try it at 430am. it works great. but i used 4 canadian pennies i had lying around.
total cost: .033593 USD.
Old Aug 15, 2006 | 05:54 PM
  #80
Ed 718's Avatar
Ed 718
BRAVEHEART
I wanted to bump up this thread since many have asked about this simple solution I posted a while back....
