ENGINE LAMP! Evap Leak! HELP!!!!
Old Jun 17, 2004 | 09:45 PM
DZTZ33's Avatar
DZTZ33
Default ENGINE LAMP! Evap Leak! HELP!!!!
My "Service Engine Soon" lamp has come on for the fourth time on my 04 Enthusiast.
Each time they say it's an Evap leak, and there's something wrong with my fuel tank.
This last time, I filed a claim with Consumer Affairs.
I got two subs and amps installed in the trunk, and now the dealer is saying when that the installation is a reason, and now it's out of warranty.
What should I do? Please help
Old Jun 18, 2004 | 01:11 PM
Infern0's Avatar
Infern0
lol...tell the dealer to show you where a sub install causes those codes....seriously...make them look like dicks
You have a CAI? I actually got that light on my old tiburon when I messed up the CAI install. That little hose that conects to the intake pipe right before the throttle body....make sure that's attached tight. Reset the comp and that fixed MY problem. Only a suggestion until something better posted.
Old Jun 27, 2004 | 11:46 AM
ossboomer's Avatar
ossboomer
The check engine light is no big deal really. There is no possible way your sub installation could have caused that. An evap leak has to do with your fuel system, when the vehicles monitors detect a pressure leak in the fuel system it will set a code in the ecu. There is a fix, but only the dealer can fix. All they do is reprogram the ecu to widen the perimeter of evap. leak. It should be warrented up to 60,000 miles.
Old Apr 6, 2010 | 12:31 PM
CsabaH's Avatar
CsabaH
I just had auto zone check my Service Engine Light, and got this same EVAP code. Do you think that 60,000 mile warranty would still apply? I only have 39k.
Old Apr 6, 2010 | 01:40 PM
DavesZ#3's Avatar
DavesZ#3
Did you make sure your gas cap is tight? That's the most common cause.
Old Apr 6, 2010 | 02:25 PM
CsabaH's Avatar
CsabaH
Yup checked that one, and it still came on.
Old Apr 6, 2010 | 03:03 PM
KornerCarver's Avatar
KornerCarver
DZTZ33-Is it possible that when you installed the sub-woofers and amp that you might have drilled a small hole in the fuel tank? Just a thought.............
Old Apr 6, 2010 | 03:14 PM
DavesZ#3's Avatar
DavesZ#3
What's the exact code you're getting?
OP started this 6 years ago.
I have to admit that was my first though - either the tank or the vapor lines.
Old Apr 6, 2010 | 07:59 PM
CsabaH's Avatar
CsabaH
Yeah I saw how old it was but when I did a search in the technical forum, this was what came up that applied. I'll have to check on the code again. I tried to reset the ecu, but still getting it. I'll check back tomorrow.
Old Apr 7, 2010 | 08:52 AM
CsabaH's Avatar
CsabaH
Apparently it's two codes P0442 and P0456. Called the dealership and apparently the evap recall was already performed on my car by the previous owner. So not sure where to go from here.
Old Apr 7, 2010 | 09:04 AM
DavesZ#3's Avatar
DavesZ#3
The FSM lists these possible causes for P0442
 Incorrect fuel tank vacuum relief valve
 Incorrect fuel filler cap used
 Fuel filler cap remains open or fails to close.
 Foreign matter caught in fuel filler cap.
 Leak is in line between intake manifold and
EVAP canister purge volume control solenoid
valve.
 Foreign matter caught in EVAP canister vent
control valve.
 EVAP canister or fuel tank leaks
 EVAP purge line (pipe and rubber tube) leaks
 EVAP purge line rubber tube bent
 Loose or disconnected rubber tube
 EVAP canister vent control valve and the circuit
 Fuel tank temperature sensor
 O-ring of EVAP canister vent control valve is
missing or damaged
 EVAP canister is saturated with water
 EVAP control system pressure sensor
 Fuel level sensor and the circuit
 Refueling EVAP vapor cut valve
 ORVR system leaks
For P0456, it lists the same as above plus this one...
 Foreign matter caught in EVAP canister purge volume
control solenoid valve
Basically, something's wrong and there's a bunch of possible causes.
Old Apr 7, 2010 | 09:09 AM
CsabaH's Avatar
CsabaH
So the million dollar question is how do i test to see what it is w/out replacing all the lines and evan control valve? Any pics of said valve? is in near the fuel pressure regulator? Everything is bone stock on this thing and it only has 39k on it.
Old Apr 7, 2010 | 01:29 PM
DavesZ#3's Avatar
DavesZ#3
Look at the top of this forum and there's a sticky thread about the Factory Service Manual. Follow the link and download the EC section (Engine Control). Look in it for the DTC codes you're getting and you'll see lots of details on what, where, why, etc.
Old Apr 7, 2010 | 07:37 PM
CsabaH's Avatar
CsabaH
cool thanks for the info.
Old Apr 16, 2010 | 05:46 AM
djcetra's Avatar
djcetra
I had these codes appear a while back after having my Catback exhaust installed. The dealership fixed it and said it was because the people who did my exhaust installation put the hoses back on incorrectly.
Old Apr 25, 2010 | 08:31 AM
CsabaH's Avatar
CsabaH
Just an update. I was unable to trouble shoot everything per the factory service manual, but I drove to the gas station w/ the SES light on still. Got gas, fired it up and bam no more light. So I don't know if re-tightening for the 3rd time did it or what but the light is gone and everything is good in the land of Z...lol. So I have no clue if the computer just automatically re-adjusted itself or if re-tightening the cap again fixed the problem or what.
liqalu04
Jan 2, 2022 12:58 PM
Pleask
Dec 21, 2021 03:17 PM
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Nov 9, 2015 11:10 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
