brakes squeaking
Old Jul 18, 2004 | 07:18 PM
rtztoy's Avatar
rtztoy
Unhappy brakes squeaking
HI, I am new to this site and love my Z. However I need some help. I have a 2003 Z and the brakes are squeaking so bad! I just got the front ones changed after only 11,000 miles and now they are squeaking again after a few weeks! Does this happen to yours?? Let me know. thanks!
Old Jul 22, 2004 | 10:44 AM
emir's Avatar
emir
Default Re: brakes squeaking
My brakes squeek, but only when i'm going in reverse. If you had this problem fixed let me know how you went about solving it. THanks
Old Jul 22, 2004 | 06:31 PM
Spartan1510's Avatar
Spartan1510
My brakes squeal, but only when going at low to moderate speeds without any pressure on the brakes. Thats right, they only squeal when I'm NOT on the brakes! When I hit the brakes, the squeal stops.
Anyone know if this is brake dust or rotor edges? I took it into the dealership today, but Murphy kept the squeal away.
Old Jul 23, 2004 | 01:37 PM
Dissolved's Avatar
Dissolved
Normal. I have the same thing
Old Jul 24, 2004 | 06:39 AM
boxsterkiller's Avatar
boxsterkiller
rtztoy I also had the my fronts changed at 10k but were warranteed because under 12k I hope you did not have to pay for those. But dissolved is right the Z brakes always sqeek this sucks.Emir there is a TSB for squeeky front brakes while going in reverse check it out they replace some outer brake shim.
Old Aug 5, 2004 | 11:23 AM
bumba244's Avatar
bumba244
Default Squeaky...
My first 350 was an auto 2003.. the brakes were horrible! i had the fronts replaced at 14k because they made squeaks for about 2k miles and then eventually they started making a metal-on-metalish type noise when i didn't even have my foot on the brakes. I took it in and they resurfaced the rotor under warrenty but i had to have the brakes replaced in another 1k miles so that cost me about 300 bucks. Sold that one got another, manual, with 12k miles, no brake problems.
Old Aug 5, 2004 | 12:36 PM
BLACKZTRACK's Avatar
BLACKZTRACK
Mine too .I replaced them with Greenstuff at 21k miles now they do it too.Dealer says its normal.
Old Aug 5, 2004 | 01:12 PM
Audito350Z's Avatar
Audito350Z
disk brake squeal... part of life.... you can get some Wurth DBQ2000.. it's goo that you put on the back of the pads.. it works for a little while...
FAQ about squeeky brakes
http://autorepair.about.com/library/faqs/bl131d.htm
07ZEKE
Aug 23, 2021 09:15 PM
samansharif
Sep 25, 2015 12:31 PM
