high oil pressure
Old Nov 23, 2006 | 10:13 AM
bigslim350Z's Avatar
bigslim350Z
Default high oil pressure
I have just done an oil change and when driving around last night I noticed that my oil pressure was at 120 psi, and the engine was only turning at 2300 rpm. This was also after driving around for a while, so clearly the engine and oil were warmed up. When it was started up cold later that night, the p ressure gauge read 130 psi at idle and higher.
Anyone know what the hell would cause this? It worries me.
Old Nov 23, 2006 | 04:39 PM
mdracer76's Avatar
mdracer76
What weight oil did you put in?
Old Nov 23, 2006 | 07:49 PM
Nihilation's Avatar
Nihilation
Add too much oil?
Old Nov 23, 2006 | 07:59 PM
rockinbboy's Avatar
rockinbboy
Not normal at all. Takes about between 5-10 minutes to get the oil warmed and lubricated thoroughly in the engine.
At 70 MPH, you should be at 2500 RPMs with an oil pressure is reading of 60 PSI.
Old Nov 24, 2006 | 01:42 AM
gNaRKiLL's Avatar
gNaRKiLL
If you put anything other than 5w30 oil in youll see this. I told the dealer about this when I had my tranny done and according to Nissan its normal with the higher weight oil.
Old Nov 24, 2006 | 06:14 AM
bigslim350Z
5 quarts of 5 W / 30 W Mobil 1.
My friend said that the problem is probably the bypass valve in the oil filter sticking. Going to change the filter today and see if that helps.
Old Nov 24, 2006 | 06:54 AM
Nowell's Avatar
Nowell
National Z Club
Nah mine runs a bit higher with Mobile 1 also. I think its just the fact its a full synthetic vs a blend you get from the factory. I dont know that it runs 120 or 130 though, but Mobile 1 will have you running higher than stock.
Old Nov 24, 2006 | 08:28 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Mobil 1 isnt actually full synthetic though guys, they recently changed the way this is measured. Try that oil filter and let us know. Ive run up to 10W-40 in my car with no ill effects. Good luck.
Old Nov 24, 2006 | 09:44 AM
bigslim350Z
it's not the oil filter, so it might either be a problem with the sensor or the oil pressure regulator or something. unfortunately I don't know where that is located. The worst case is that I might have to go to the dealer and have it checked out, but since I have stuff done to my car they might not cover it under warranty.
Old Nov 24, 2006 | 09:47 AM
paul_kemshall's Avatar
paul_kemshall
Vortech superchargers have caused this as they are piped into the main oil supply.
Similar problem maybe with the Procharger?
Paul
Old Nov 24, 2006 | 09:48 AM
bigslim350Z
Procharger is self contained oil supply. The main reason I went with it. So, i'm guessing it might be some kind of oil pressure regulator or bad sensor.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
