Please Help: Car Won't Started
Old Apr 23, 2007 | 07:53 PM
Super Avan Z33's Avatar
Super Avan Z33
Unhappy Please Help: Car Won't Started
Long story short, I had the Grounding System sit right on top of the fuse box, which mean I mounted that thing right on the battery clamp, today I tried to open the fuse box, then I have to removed that thing in order to open the fuse box, suddenly I drop that thing on the battery positive terminal, I had that thing caught on SPARKLING soon that thing touch the battery positive terminal, I removed that thing immediately and tried to start up the car see anything wrong, car just won't started, I thought some of the fuse may pop, I inspected both fuse box, one inside the car and one at the engine bay, non of the fuse were pop, I really don't know what have I done to my car. PLEASE HELP, I appreciate.
Old Apr 23, 2007 | 08:47 PM
jgxchris's Avatar
jgxchris
ouch..
did you check voltage on your battery?
Old Apr 23, 2007 | 08:57 PM
VN_350z's Avatar
VN_350z
you probably fried the ECU.
****. this is not good
Old Apr 24, 2007 | 06:26 AM
Zincognito's Avatar
Zincognito
Originally Posted by jgxchris
ouch..
+1
Old Apr 24, 2007 | 07:25 AM
Nihilation's Avatar
Nihilation
Do you get any power inside the cabin? What does the volt meter next to your oil pressure say?
Old Apr 24, 2007 | 09:18 AM
abui01's Avatar
abui01
Lesson learned, electrical currents provided via grounding kit do not enhance performance of a vehicle. However it seems odd that something like that could totally short out the ECU even though that is quite a possibility. Got Warranty?
Old Apr 24, 2007 | 10:06 PM
Super Avan Z33
NO power period.
Just replaced new battery today and still no power period.
Still running warranty.
Old Apr 25, 2007 | 05:28 AM
behjjeh's Avatar
behjjeh
Vendor - Former Vendor
change everything to stock and send it to dealer!
Old Apr 25, 2007 | 06:47 AM
mdracer76's Avatar
mdracer76
There is more than one fuse leading to the ECU. I'd check / recheck them.
When you put the key in and turn it to on.. do you see a check engine light? If so your ECU is getting power, if not... then no power to your ECU.
What is "that thing" that you dropped?
aarrgghh
May 1, 2022 11:04 AM
Mattg350z
Oct 2, 2015 06:51 AM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
