alignment issues! help from mid-a
Old Feb 7, 2008 | 03:15 PM
mondi's Avatar
mondi
Default alignment issues! help from mid-a
put this in the suspension section..but would like some feedback from the are...quick question
my car is lowered..1.1'' all around. When i get my car aligned occasionally...my camber in the front is -2.2 average(alittle over OEM..but the less i can get it to be) and -2.8(rear)
long story short...i hit a curb..direct tire on curb i should say since there was no body damage and my car is lower than the curb.
When i got my car back from insurance..they replaced the lower, upper, knuckle, hub bearing i think, etc..my camber is now at -.6 on the front left and still -2.2 on the front right.. and my spring and shocks still intact so i know they did not change them.
is there anything i can do about this? or what do you think is going on here.
Old Feb 7, 2008 | 03:24 PM
got350's Avatar
got350
Front And Rear Camber Adjustment Kit!?
Old Feb 7, 2008 | 03:34 PM
SC 350Z's Avatar
SC 350Z
i gotta get one of them
Old Feb 7, 2008 | 04:14 PM
TeAm PrOSpEc's Avatar
TeAm PrOSpEc
A camber kit would work but my question to that is: If the equasion is still the same (shocks, spring, joints ect) and you had your camber @ -2.2 and -2.8 before the meeting with the curb :0! and everything was fixed with OEM parts, why cant you acheive the same camber? R U SURE NOTHING IS BENT?
Old Feb 7, 2008 | 05:07 PM
mondi's Avatar
mondi
that's what im wondering
maybe they didnt fix anything
Old Feb 7, 2008 | 05:12 PM
TeAm PrOSpEc
Or maybe frame damage? ... what you need to do is have someone drive behind you while you do 40 on a flat stright road and see if they can look stright down the center of your car evenly. It takes a trained eye but normally when your car has frame damage it tends to "crab walk" down the road.
Old Feb 8, 2008 | 05:12 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I assume where the camber is -.6 is where you hit the curb and parts were replaced? There is no factory camber adjustment in the front suspension of the Z, so something is definetely up. Seems as though maybe you may have bent something that wasnt replaced-maybe a control arm. Take it back to that shop-the work and result is unacceptable or go to a better shop.
Old Feb 8, 2008 | 05:22 AM
mdracer76's Avatar
mdracer76
+1000. bad shop...
Old Feb 8, 2008 | 06:15 AM
mondi's Avatar
mondi
it was through insurance :-\ so i didnt have a choice
Old Feb 8, 2008 | 06:19 AM
mondi's Avatar
mondi
I'm going back today and letting them know what's up
Alberto's Avatar
Alberto
Cranky FI Owner
By law you can pick any body/repair shop you take your car to. Of course they recommend Joe Schmoe but you can choose.
Old Feb 8, 2008 | 10:31 AM
HKS-Z's Avatar
HKS-Z
Backroad Pro
+100000.I was just kinda in the same situation,(not a curb though,damn road construction )bent a rim ,popped the tire,and bent the control arm,replaced all that and did an alighnement.the alighnment was still not right but they just had no idea what they were doing on a Z-take it to the dealer,you may have to pay for the diagnostic,but once you get that paperwork-it only takes a phone call from there.
Old Feb 8, 2008 | 02:32 PM
memphis350z's Avatar
memphis350z
i would not take it to a stealership...something is still deffinetly tweaked up from,most likely frame damage of some sort...if a camber kit will get you within the specs you want cool but i would still take it to a reputable bodyshop. Dont cheap out and go to some guys garage,frame damage is not a joke and what looks to be "fixed" now will cost you big later...chewing up tires,car not staying on course,vibations..all very bad...if your around baltimore check out Cliffs hi-tech on stemmers run rd.
i work there in the paint shop and our bodymen are pros...tell them dale sent you...we have had multiple Z's in our shop and our guys are no strangers to them
Old Feb 8, 2008 | 05:53 PM
ajcool2's Avatar
ajcool2
Its funny this topic came up since my Z is at the dealership now with similar problems. I needed both wheel hubs replaced and an alignment. I should have the car back tuesday.
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
