NA Build Inside....Soup to Nuts :)
Old Apr 23, 2009 | 07:22 PM
  #801
jmccarty's Avatar
jmccarty
Originally Posted by OCG35
this came to 50K???
Cosworth VQ35 CNC Big Valve Cylinder Head "Rev Up Version"
Cosworth VQ35 High Performance 95.5mm Short Block 3.5L
Cosworth Twin Intake Plenum (Ordered October 2008, delivered 11 March 2009)
Cosworth High Volume Fuel Rail Kit
Cosworth Metal Head Gasket 96mm
Cosworth Head Studs Kit VQ35
Nissan OEM Bearings
HKS Kansai Intank Fuel Pump with Relay Kit
HKS Twin Power Ignition System
HKS F-Con Vpro Engine Management Unit
HKS Valcon VCAM Plus Kit
HKS Fire Racing Plugs M35iL
HKS 480cc injectors
HKS Racing Suction Kit
HKS Oil Cooler Kit
HKS DB RS oil Temp, Oil Pressure, Water Temp and unit controller
This came to $27,140. this is only part of the list.
Old Apr 23, 2009 | 07:33 PM
  #802
Chef-J's Avatar
Chef-J
Booooosstt!!
Originally Posted by jmccarty
The list is a bit longer and holistic:
Nissan OEM Bearings
HKS 480cc injectors
HKS Stainless Headers
HKS Front Center Pipe
HKS Hypermax III Sport suspension
HKS Oil Cooler Kit
HKS 6 pot front and 4 pot rear breaks.
Mine's Straight Pipe Kit
Kakimoto Racing Dual Exhaust
Exedy Hyper Series Carbon Twin Clutch Kit
Nismo GT Pro LSD 1.5 Way
Arc Full Aluminum Radiator
Carbing oil collector tank 10mm
Carbing Aluminum Front Strut Bar With M/CS
C's Short Shifter Kit w/Nismo GT Titanium Shift ****
Carbing Radiator Cooling Plate
Varis CF Air Duct
50k included labor for the build and tuning and that is at a slight premium to get this parts list into Singapore from Japan and the US.
This started as just a block and heads change and kept going until there was nothing else to add to it as far as I'm concerned.
This is in a country where a 350Z costs $100k http://www.nissan.com.sg/lookfor/350z/350z_price.cfm and getting ripped off starts when you buy any new car.
Edit: just saw your profile. Good numbers.
Old Apr 23, 2009 | 07:35 PM
  #803
Kwame's Avatar
Kwame
Old Apr 24, 2009 | 08:20 AM
  #804
OCG35's Avatar
OCG35
Old Apr 24, 2009 | 08:21 AM
  #805
OCG35's Avatar
OCG35
Nissan OEM Bearings
HKS 480cc injectors
HKS Oil Cooler Kit
Varis CF Air Duct
^^^ a lot of that stuff isnt engine.
Your post read as the engine build was $50K... the list I pulled from your profile and listed above was all I could find that was engine related.
Old Apr 24, 2009 | 08:23 AM
  #806
OCG35's Avatar
OCG35
so your "engine build" was more in line with what most of us were saying is the norm
Old Apr 26, 2009 | 06:39 AM
  #807
jmccarty's Avatar
jmccarty
Absolutely. But I would not spend that sort of money on the engine and neglect the rest, and the rest is important if you want to get the most out of the car. I suppose anything outside of the block is not technically the engine then!
Old Apr 26, 2009 | 07:55 AM
  #808
OCG35's Avatar
OCG35
Obviously we spend additional money on the remainder of the car – suspension, driveline, etc… I’m just pointing out that your post stated your NA build was 50K – that seemed awfully high. Typically people don’t consider “NA Build” being things other than engine related.
Here’s the post I’m referencing.
It's a hobby like any other, the more you are into it, the less the cost becomes an issue. My N/A build came to well over $50k but I have what I wanted. Bigger the boy, bigger the toy or something like that!
there’s no point going on and on about it… the bottom line is your engine didn’t cost 50K to build and that’s a good thing.
Old Apr 26, 2009 | 08:05 AM
  #809
XM 1's Avatar
any updates or new pics adam?
Old Apr 26, 2009 | 08:12 AM
  #810
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I haven't really been working on the car lately as I've been tied up with work
Old Apr 26, 2009 | 08:23 AM
  #811
CarlosCh's Avatar
CarlosCh
I would assume that none of those prices include labor... I bet getting all of that done costs a pretty penny!
Edit> I just re-read and here is what he says about the 50K and the labor included part... "50k included labor for the build and tuning and that is at a slight premium to get this parts list into Singapore from Japan and the US."
Old May 30, 2009 | 01:18 AM
  #812
XM 1's Avatar
bump for updates
Old May 30, 2009 | 03:39 AM
  #813
Z1 Performance
Former Sponsor
nothing much to report, car has just been sitting. Hopefully I'll have time in the coming month to get back to it
I did send my Racepack to my stereo/interior guru to work his magic and come up with a nice clean pod
Old May 30, 2009 | 06:14 AM
  #814
XM 1's Avatar
nearly forgot about you racepack gauge cluster .....can´t wait to see teh fninished product/ the hole car.just put my rims on today with the Project Kics which i bought from you...they look just sick
Old Jun 2, 2009 | 03:40 AM
  #815
0jiggy0's Avatar
0jiggy0
Post that damn sexah Dash. In hi res this time!
Old Jun 2, 2009 | 07:22 AM
  #816
Z1 Performance
Former Sponsor
once it's back in my hands, I'll share
Old Jun 2, 2009 | 09:04 AM
  #817
tuko316's Avatar
tuko316
Hey adam its justin.
Are the tomei cams you used the procam series or the poncam series? Just want to double check. Thanks.
Old Jun 2, 2009 | 09:46 AM
  #818
Z1 Performance
Former Sponsor
the ones I used were 268's, but they aren't made anymore...I don't remember if they were pro or pon series though
Old Jun 25, 2009 | 01:53 PM
  #819
aggietsi's Avatar
aggietsi
It's been a while
Old Jun 25, 2009 | 04:14 PM
  #820
Z1 Performance
Former Sponsor
Yep you're right
Seriously though, we've been working on stuff, but I can't say when it will be finished yet. Still waiting on loose ends to be tied up. I've actually just been updating the work we have been doing for/ on the car on our blog
www.cornerbalance.wordpress.com
