VQ powered S14
Old Apr 12, 2008 | 10:53 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
this is going to be a BAD *** setup guys, trust me on this
Old Apr 13, 2008 | 07:13 AM
ke0ki2k's Avatar
ke0ki2k
I wana hear this asap btw...never heard a car running JDM nismo cams. if they ever come out with a good ITB setup for USDM..you should get it. make your car obnoxiously loud ^_^
Old Apr 13, 2008 | 07:20 AM
Z1 Performance
Former Sponsor
there are videos of Ritchie's Z from Australia who had the Spec 1's floating around from a couple years ago
Old Apr 13, 2008 | 02:12 PM
ke0ki2k's Avatar
ke0ki2k
couldnt find it. but I found what I want.
http://www.youtube.com/watch?v=A2-2I...eature=related
Old Apr 13, 2008 | 06:39 PM
supra crazy's Avatar
supra crazy
Originally Posted by nismo240r
just grabbed an s14 engine x-member from a friend a few mins ago. . .here's a quick and definitive comparison between the two. . .
comparison:
top is vqswap s14
bottom is oem s14. . .
same width as my frame
Damn that sucks I was planning on doing the same thing to my S14 and using vqswap for there mounting kit but i guess they dont fit worth ****...did you call them about that yet?
Old Apr 13, 2008 | 07:00 PM
redmike_02's Avatar
redmike_02
Looks good so far. Trying to talk my buddy into putting one in his S14.
Old Apr 13, 2008 | 09:38 PM
nismo240r's Avatar
nismo240r
I phoned him late last week about it and he said as soon as the x-member arrives he'll get on it right away. . .i'm hoping that this will actually be for an s-chassis. . .
I've found a few other crossmembers so i'm going to try and fab something for myself as well and compare it to vqswaps mounts. . .i'd like to get it as low as possible and as close to the firewall as possible.
Another fitment issue i've seen with a lot of vq's is the plenum sticks out about a 1/2" above the hood so they've had to cut out some of the ribbing. . .(i've got a cf hood )
There's someone else that's doing this swap into his wife's S14 and he was kind enough to show some pics of his custom x-member. . .i like his work. . .
specs are a lot tighter with this. . .can't wait to compare!
Old Apr 23, 2008 | 12:50 PM
EnjukuBG's Avatar
EnjukuBG
Enjuku Racing
Awesome, there is a VQ s14 running in nopi. Hope it all works out for you. So far the car looks good.
Old Apr 24, 2008 | 08:52 AM
gregfarz78's Avatar
gregfarz78
Nice work I just picked up a s13 coupe yesterday the vq engine is ready to go I probably won't get there for a few months though need to take care of some body work first
Old Apr 24, 2008 | 03:30 PM
nismo240r's Avatar
nismo240r
A genuine s14 x-member made to work with the vq came in today! Had a snowstorm up here so I wasn't all that motivated to go and work on it in an unheated area.
Also went to Calgary to pick up all my suspension parts and cooling items!
Will get the x-member in tomorrow and hopefully the engine and tranny as well!
Pics!
Peak Performance suspension and koyo rad
FAL fans
Turbo XS Utec, MAP sensor and AEM w/b gauge
X-member, Suspension Techniques sway bars, Greddy tower braces
Thanks to Sharif and Sandy @ Forged for the parts as well as Oliver and Nguyen @ Autodream!
Old Apr 25, 2008 | 02:01 PM
weaselfury's Avatar
weaselfury
man this is going to be sweet bro... G/L on this. hope everything goes smoothly!
Old Apr 25, 2008 | 06:18 PM
350z_Gio's Avatar
350z_Gio
Looks like an awsome project keep up the good work can't wait to see the progress
Old Apr 29, 2008 | 06:17 PM
nismo240r's Avatar
nismo240r
The x-member came with new mounts, but the bolts that came with it are too big to fit in the mount points on the engine, not a biggy but something not good on Vqswap.com's part.
The clearance on this x-member looks pretty good so far, just can't wait to finally get the thing in lol.
bolted in
waiting on a couple parts from Nissan and then it'll be going in. . .can't wait
Old Apr 29, 2008 | 09:01 PM
lgear080's Avatar
lgear080
heavy... very heavy... should run hard and be bulletproof.
sick. all classy/functional parts. nice.
Old May 1, 2008 | 06:51 AM
gregfarz78's Avatar
gregfarz78
Does that xmember bolt right up to stock vq mounts? I'm not clear how the engine bolts up to the xmember unless it will make more sense when its bolted in.
Old May 1, 2008 | 07:28 AM
nismo240r's Avatar
nismo240r
yep the mount location on the s14 x-member have been modified/relocated so that it will work with the stock vq mounting brackets. . .but not the stock isolators. . .
Old May 6, 2008 | 03:33 PM
nismo240r's Avatar
nismo240r
Engine and the transmission are in, this was just to mock it up to check clearances. I had to remove the left header as one of the pipes was interfering with the steering rack knuckle. Looks like i'm going to have some custom ones made up pretty soon here. . .
Engine and tranny ready to go:
Tranny in the tunnel. . .
Everything is so tight, width and height, would have like to drop the chassis onto the engine and tranny. . . mebbe next time. . .
Tranny peeking into the tunnel. . .
Almost in. . .
This is about an inch above the mounts. . .
Next time I'll know to remove the plenum as the neck at the top hits the top of the firewall and prevents you from getting any angle. . .
Have to remove the power steering lines from the rack as they're right in the way. . .
1 mount on. . .
The sway bar will have to be lowered with some spaces as the oil pan drops right onto it in the factory location
IN!!!
Clears the hood as well!
Left mount. . .
Right mount. . .
Front. . .
Space between the bottom of the engine and the x-member. . .
Will have to grind out a little of the ribbing on the engine close to where it meets the transmission as it's just rubbing on the steering rack. . .
and just a few other shots. . .
ABS
Hoodline. . .
Old May 6, 2008 | 05:37 PM
  #38
gothchick's Avatar
gothchick
Wow... Very, very, very impressive!!! Must feel really good to come this far!! You make it look a lot easier than I'm sure it is~ Congrats! :-)
Edit: What are you lifting the engine with? Are those Cat Braces?? Lol~
Old May 6, 2008 | 05:40 PM
  #39
Marty_G's Avatar
Marty_G
that f'en cool
Old May 6, 2008 | 05:41 PM
  #40
SlideFox's Avatar
SlideFox
Very Nice!
