Tomei Header and Cam install
Old Aug 13, 2009 | 09:37 PM
  #141
_ink's Avatar
_ink
Hey Gabe, so in terms of ECU, all you have is the stock ECU with Osirus flash?
Old Aug 13, 2009 | 09:42 PM
  #142
gabe3d's Avatar
gabe3d
Yeah, that's all I have.
Old Aug 13, 2009 | 10:22 PM
  #143
_ink's Avatar
_ink
would a piggyback or standalone see more gains for you?
I'm practically doing the same build as you, however i make a Greddy Ultimate.
You're running on stock valve springs correct? What do you have your rpm limit set at? Just wondering what a safe threshold would be.
Old Aug 14, 2009 | 12:38 AM
  #144
gabe3d's Avatar
gabe3d
I really doubt that a piggy back would do much of any difference. For that matter many tuners and people are switching from piggybacks to Osiris since the tuning is more seamless and there are things that you can do with osiris that you can't with UTEC or the Greddy.
Yeah i'm running on stock springs and valves, that is one mistake i think i might have done during this upgrade. I didn't really think that I would continue to upgrade the car further after the cams and headers but you know how it is... I'll push it to ~7300rpm and see how it is and if things are no good then perhaps an engine rebuild...
Btw, how far is your car along the line of upgrades?
Old Aug 14, 2009 | 01:25 AM
  #145
_ink's Avatar
_ink
Thanks for the info Gabe!
I've got the standard exhaust and intake mods. Waiting for my tomei v2 headers to arrive so i can install them along with the tomei cams at the same time, i also ordered the 3" maf and samco tube from Adam (Z1auto).
I don't plan on doing much more than this, so do you think keeping the stock valve springs will be sufficient for my application?
Old Aug 14, 2009 | 02:44 AM
  #146
gabe3d's Avatar
gabe3d
Awesome choice on the headers!!!
Which cams did you get from Tomei?
It's hard to really say whether or not you will need new valves and springs. If you get high lift cams then of course you'll need a new set, but if you get standard lift ones then perhaps you won't need it. However if you do intend to rev it higher or have higher CR then perhaps it might be a good idea. I wish i could give you a better answer, but in terms of labor cost it's actually a little bit different then just cam install, so you are not entirely wasting your money by only doing the cams (maybe 1/2). HTH.
Old Aug 14, 2009 | 05:02 AM
  #147
_ink's Avatar
_ink
I'm going with the 264 cams.. same setup as yours mate.
That's why im asking you about valve springs.. however if i dont plan to do anything else, i think they would just be an overkill.
Old Aug 14, 2009 | 07:26 PM
  #148
gabe3d's Avatar
gabe3d
I've been logging my car for the past couple of days and I see that my IDC hits 83% when at around 6400rpm. The recommended operation range is below 80%, but I'm a tad bit over that already and I plan to pushout the revlimit (and hopefully making more power). Any foreseeable issues? One of the shop I take my car to recommended to get a bigger fuel pump rather then bigger injectors. I thought bigger injectors made more sense but he said the bigger fuel pump will help bring down the IDC as well since it'll raise the pressure. Any opinions?
Yeah, sounds like you should be fine with the stock valves springs, but keep in mind that if you push the rev like mine you might need it. Perhaps if my tune gets done before I leave to asia at the end of next week, then it would be helpful to you to see if pushing the rev limit is worthwhile and if i do run into any issues.
Old Aug 16, 2009 | 12:53 PM
  #149
Bigalow's Avatar
Bigalow
There's a dude on the forums selling a used TD Bassani exhaust. I've heard vids of it and I like it.
Question is, can it benefit my build?
The exhaust is 2.25" and I'll eventually get wrapped headers, test pipes, and a 3" intake.
Any thoughts?
Originally Posted by gabe3d
I previously answered this question and said that I won't but I just made that statement become a lie this morning.... after thinking about it for a few days and talking to adam.... god have mercy on me and help me stop buying.
lol.
Old Aug 16, 2009 | 01:24 PM
  #150
0jiggy0's Avatar
0jiggy0
I think the exhaust would be fine. Dual 2 and a quarter is shouldn't be too smal for na.
Old Aug 16, 2009 | 01:43 PM
  #151
gabe3d's Avatar
gabe3d
^Agreed. I would say it will be perfectly fine for an NA motor.
Old Aug 18, 2009 | 11:26 AM
  #152
gabe3d's Avatar
gabe3d
Here is the remaining of the stuff that will go on to my car.
Quaife LSD
Nissan Frontier Final Drive 4.08
Nismo Finned Differential Cover
SPL Rear Differential Bushings
Apexi Filter > 3" MAF Housing > Samco Tube
Cosworth Twin Plenum
Old Aug 18, 2009 | 11:33 AM
  #153
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
it's going to be fun!
Old Aug 18, 2009 | 11:50 AM
  #154
gabe3d's Avatar
gabe3d
Forgot to mention the most important part.
Thanks Adam for great experience on this purchase!
Old Aug 18, 2009 | 12:11 PM
  #155
03threefiftyz's Avatar
03threefiftyz
+1, I have always had a great experience buying from Adam. I can't wait to see all the stuff installed.
Old Aug 18, 2009 | 01:09 PM
  #156
Z1 Performance
Former Sponsor
was our pleasure Gabe - anything to help progress the NA side of the site
next you gotta get rid of those cinderblocks, errr, wheels !
Old Aug 18, 2009 | 02:50 PM
  #157
gabe3d's Avatar
gabe3d
gah....note to self, stop talking to Adam about car parts.
Old Aug 18, 2009 | 02:51 PM
  #158
gabe3d's Avatar
gabe3d
Yeah, hopefully everything comes out good.
Old Aug 18, 2009 | 05:39 PM
  #159
allmotorsedan's Avatar
allmotorsedan
damn Gabe you really are going all out with your car!!!! I hope you plan on staying NA, cuz you and your build are my mentor!! Im getting the same FD and diff cover, and probably go with the Cusco RS lsd. I heard with the Quiaife, it acts like an open diff when there is no traction, such as ice/snowy conditions, or when making hard turn and one of your wheels lift. Obviously in cali, that wont matter to you. But here in Chicago, the winters suck!
cant wait to see what the Cosworth does for your car!!!!!
Old Aug 18, 2009 | 09:33 PM
  #160
__jb's Avatar
__jb
Z + Rear Seat
Wow! Now that's what I call a modding!
Curious to see how you like the SPL Rear Differential Bushings. Are they aluminum or neoprene?
Any reason you used an Apexi Filter instead of a Pop Charger?
-jb
