vq35de and vq35hr block comparison
Old Dec 11, 2010 | 10:09 AM
rwd > fwd's Avatar
rwd > fwd
Question vq35de and vq35hr block comparison
ive done some searching and maybe i just need to look even harder but i was wondering. i have an hr engine that was using oil but i have a DE engine in my car. i want to know if i can use the DE heads, front cover, oil pan, etc on the hr block. this way i can put the bottom end together and swap the parts over whenever i have the time to pull the DE out of my car. i dont want to have to buy an ecu and wiring harness. basically is the HR bare block the same as the DE bare block and if not what are the differences.
Old Dec 11, 2010 | 11:39 AM
kacz07's Avatar
kacz07
I am not the expert on something like this, but be prepared for some constructive criticism.
Old Dec 11, 2010 | 11:42 AM
0jiggy0's Avatar
0jiggy0
Completely different blocks. Even the dimensions. Rods crank pistons. All of it.
Short answer, no.
Old Dec 11, 2010 | 11:46 AM
accordfreak's Avatar
accordfreak
I was looking around for parts and came across a for sale ad on the HR block. Seems like this guy has experience with DE heads on a hr block so I emailed him and here's what he said:
It will bolt up to the DE head jsut like the 35HR. However, you will need a 35HR or 37HR front cover which you'll need if you decided to do a HR conversion anyways. You will have to cut the lower cover and mate it with the top of the DE over. It is has the same mounting as a DE so no custom mount require.
http://zilvia.net/f/sale-items/33852...ort-block.html
Old Dec 11, 2010 | 11:47 AM
Kwame's Avatar
Kwame
Do a search!
This very topic has been discussed not even three weeks ago...
https://my350z.com/forum/engine-and-...ml#post8803159
There are more threads that have discussed this in the past.
Old Dec 11, 2010 | 01:56 PM
rwd > fwd's Avatar
rwd > fwd
ok point well taken, i guess i need to work on my search skill. with that said does anyone want to trade or buy some spare HR parts?
Old Dec 11, 2010 | 05:24 PM
gt20ir's Avatar
gt20ir
depends what your selling, but I have thought of buying some spare parts for my HR
Old Dec 12, 2010 | 02:34 AM
raycs7's Avatar
raycs7
Do you have to change the tranny if using a HR block?
I see the starter and crank angle sensor is relocated..and the shape looks different..
Old Dec 12, 2010 | 09:44 AM
gt20ir's Avatar
gt20ir
everyone says it is different, but I have been trying to find another block and actually measure and compare what the difference is, but theh CAS is in a diff spot...
sherm
Apr 11, 2020 05:21 PM
AbyteZero
Sep 22, 2015 09:17 AM
_koubie_
Sep 20, 2015 06:34 PM
