my turn
Old Jun 5, 2012 | 07:07 PM
  #381
Classy's Avatar
Classy
Oh, and we made sure that oil was squirting to the VCT sprocket, what a mess, haha
Old Jun 5, 2012 | 10:18 PM
  #382
mgrotel's Avatar
mgrotel
you mean to the solenoid? im guessing you just pulled the solenoid off while the car was running?
Old Jun 6, 2012 | 03:14 AM
  #383
Classy's Avatar
Classy
That and I pulled off the cam sprocket cover, I wanted to make sure the ports from the solenoid to the VCT were clear.
Old Jun 6, 2012 | 05:51 AM
  #384
mgrotel's Avatar
mgrotel
when you say cam sprocket cover, do you mean the small cover that is a part of the larger front timing cover? or are you talking about the very front cam cap?
Old Jun 6, 2012 | 06:55 AM
  #385
Classy's Avatar
Classy
the cover on the timing cover, don't open the sprocket!
Old Jun 6, 2012 | 07:58 AM
  #386
mgrotel's Avatar
mgrotel
ok, thanks
sorry to keep showering you with questions, but when you replaced the sprocket, there had to be slack in the chain. how did you prevent the valvesprings from pushing on the valves and potentially making valve to piston contact?
Old Jun 6, 2012 | 10:31 AM
  #387
Classy's Avatar
Classy
I seriously don't think it is a large issue, I remember after having the timing cover off, taking out the bolt to the cam, removing the chains from the gear, removing and replacing the gear, retiming the engine and putting the front cover and everything that is connected to it on and firing it up
Old Jun 6, 2012 | 10:48 AM
  #388
mgrotel's Avatar
mgrotel
ok, why did you need a puller to get the ATI pulley off? i thought you just remove that bolt and it would come out
Old Jun 6, 2012 | 11:43 AM
  #389
Classy's Avatar
Classy
Mine was really in there... If it comes right out for you, I would be very happy for you, haha
Old Jun 6, 2012 | 11:46 AM
  #390
str8dum1's Avatar
str8dum1
its def not going to just come off. i had to use a serious puller as well.
Old Jun 6, 2012 | 11:54 AM
  #391
mgrotel's Avatar
mgrotel
awesome, i actually believed i was done working on it for a while...
Old Jun 7, 2012 | 06:30 AM
  #392
rcdash's Avatar
rcdash
Originally Posted by mgrotel
was going to put better clutches in, but the trans guy got the clutches and said they were the same material as stock but thinner, fitting 6 instead of 5, so he recommended putting stock in, so thats what i did.
You should've used the 6. It's the combined surface area that is important to distribute the load.
Old Jun 16, 2012 | 05:46 PM
  #393
Classy's Avatar
Classy
How is everything going, I want to know if everything worked out
Old Jun 16, 2012 | 07:50 PM
  #394
mgrotel's Avatar
mgrotel
havent started on the vtc sprocket yet, procratinating hardcore
Old Jun 17, 2012 | 06:43 AM
  #395
Classy's Avatar
Classy
Haha, not me, I did it ASAP and scheduled round 2 of tuning ASAP after that
Old Jun 18, 2012 | 05:10 AM
  #396
mgrotel's Avatar
mgrotel
I'm just worried about piston/valve contact when I loosen the chain
Old Jun 20, 2012 | 08:59 PM
  #397
johnwigs's Avatar
johnwigs
piston/valve contact? are you going to turn the engine with the chain off? the valve springs CLOSE the valves... so all of that pressure that makes the camshaft jump (if it does) closes the valves to a normalized position... if you line the timing marks up (lines on the intake sprockets to the little nipples on the top of the rear cover above the sprockets) then it wont jump on you. B2 will be normalized, B1 will be in a high spot and can stay there if you don't mess with it, if it moves just use 24mm wrench on the camshaft and line it back up when your ready to assemble
Old Jun 21, 2012 | 03:18 AM
  #398
Classy's Avatar
Classy
Thank you! See it isn't something to really worry about! I didn't spin anything without timing chains on, there was alittle crank movement while lining up timing marks, never had a problem, and I hope this fixes your car
Old Jul 5, 2012 | 06:53 PM
  #399
mgrotel's Avatar
mgrotel
i took off the old vtc sprocket off my old motor today, i will probably make sure all of the timing marks are lined up before i put slack in the chain to swap the sprockets.
Old Jul 6, 2012 | 11:57 AM
  #400
Classy's Avatar
Classy
Less talk more fix and nitrous shot
