my turn
Old May 29, 2012 | 05:58 AM
  #341
mgrotel's Avatar
mgrotel
Originally Posted by kacz07
I have the same rattle and have seen the inside of my timing cover scored by the timing chain. I use a Mobil1 filter, too.
what oil do you use? brand and weight? conventional or synthetic?
i think it can be the chain tensioner, but that doesnt make sense cause mine was brand new
Old May 29, 2012 | 04:26 PM
  #342
kacz07's Avatar
kacz07
Mine was replaced, too. Mobil1 5w40. I've used as heavy as 10w60 with no real change on cold starts. Head milled too much causing slack in chain is really the only thing I can think of. HR gasket thinner? Idk.
Old May 30, 2012 | 12:34 PM
  #343
mgrotel's Avatar
mgrotel
i am going to try and log the int/v tim bank1 and 2 tonight, will post results if i get to it
Old May 30, 2012 | 04:54 PM
  #344
Classy's Avatar
Classy
Gotta love VQ's! I hope you get this all figured out though
Old May 30, 2012 | 04:57 PM
  #345
mgrotel's Avatar
mgrotel
Originally Posted by johnwigs
timing is off, intake sprocket/solenoid stuck open, or trigger wheel is off, those are the only things that could be wrong
monitor int/v tim b1 and b2... they should read 0+/-1 at idle and advance when you blip the throttle
ok, so just logged the intake timing advance on both banks. the bank 2 cam is being advanced with throttle. bank 1 on the other hand never goes outside of the -1.5,1.5 window, even with throttle. i also monitored engine speed and the intake cam solenoids, and both bank solenoids are working the same, so i think its safe to say those are ok. i logged the engine speed too, so if someone wants to look at my file i can send it to someone. other than that, based on the intake advance being dead on bank 1, does anyone have any ideas? safe to say it didnt jump a tooth? where do i go from here?
Old May 31, 2012 | 08:33 AM
  #346
mgrotel's Avatar
mgrotel
below is a cutout of part of a log i just did, the order is like this:
engine speed - b1 int tim adv - b2 int tim adv - b1 solenoid % - b2 solenoid %
863 0 1 0 0
963 0 1 0 0
1025 0 1 0 0
1088 0 1 0 0
1200 0 0 0 0
1325 0 0.5 58.8 57.6
1450 0 0.5 59.6 59.2
1563 1.5 2.5 57.6 56.5
1675 2.5 5 58.4 54.9
1825 2 9 63.1 54.1
1975 1.5 11 69.4 56.9
2075 1 14 74.1 56.9
2163 1 16 74.9 54.5
2300 1.5 20 74.5 49.8
2413 4.5 21.5 71.8 48.2
2575 1 24 76.9 44.7
2700 1.5 26.5 77.6 40.8
2800 3 27.5 75.7 40.8
2900 5 28.5 74.5 41.2
3000 4.5 29 75.7 41.6
3100 4 30 74.9 29
3200 3.5 30.5 74.1 26.7
3325 5 29.5 71.8 27.1
3413 5 28.5 71.4 28.2
3525 3.5 28 74.5 29.4
3663 5 26 68.2 28.2
3813 5 25 0 0
3875 1 21.5 0 0
3925 0.5 18 0 0
3950 0.5 14.5 0 0
3963 -1 8.5 0 0
3963 -1 3 0 0
3963 -1 0.5 0 0
3925 -0.5 0.5 0 0
3913 -0.5 0 0 0
3888 -0.5 0.5 0 0
3863 -0.5 0.5 0 0
Old Jun 1, 2012 | 08:36 PM
  #347
johnwigs's Avatar
johnwigs
solenoid % has nothing to do with the solenoid... it is just saying what the ECM is telling the solenoid to do... at least it ruled out the base timing being off... so now it is either wiring ECM->solenoid... or hydraulics.... could be lack of oil pressure on B1 or cam sprocket is full of junk... or just the solenoid has some crap stuck in it and isn't opening no matter what the ECM is telling it
Old Jun 1, 2012 | 08:42 PM
  #348
kacz07's Avatar
kacz07
Vince at RT hypothesized it was lack of pressure, the way the cams settle after the car is shut off, or a combo of both when the oil drains into the pans.
Old Jun 2, 2012 | 07:52 AM
  #349
mgrotel's Avatar
mgrotel
Ok, the solenoid % makes sense, because the ECM is really trying to advance the b1 side. For example, the actual advance will be about 4* on b1 and about 30* on b2, but the solenoid % for b1 will be about double that of b2. So that tells me the ecu is doing its part on at least trying to get b1 to advance more. Can I rule out the ECU by that?
I swapped the solenoid again yesterday with one I had and it's no better, so I think I can rule out the solenoid, agree?
So down to wiring or the cam sprocket I guess. Any recommendation on how to proceed? Car throws the P0011 regularly and is noticeably down on power, especially midrange. With a high stall torque converter the midrange is painfully weak. Car has hard starts sometimes, sometimes starts super easy, thanks
Old Jun 2, 2012 | 08:02 AM
  #350
mgrotel's Avatar
mgrotel
I'm guessing you are referring to the noise on cold starts here? Did it do a lot of scoring to the timing chain case when you looked at it? I have royal purple 5w30in now and it seems to be a little worse. Might go with thicker and conventional. Might have the dealer change the tensioner cause maybe I put the new one on incorrectly or something. Are you just planning on living with that noise? It's embarrassing
Old Jun 2, 2012 | 08:06 AM
  #351
e30cabrio's Avatar
e30cabrio
I am not trying to start an oil debate or uproar but I just had my 4.08 and quaife reinstalled and the differential specialist said the warranty would be void if I used RP.
He insisted on only Amsoil syn or Mobil 1 dyno.
Old Jun 3, 2012 | 12:19 PM
  #352
Classy's Avatar
Classy
I never have been a fan of the royal purple band wagon. If your cam gear is advancing like it is supposed to, it is working. When my car did it's first starts at Uprev, my driver's side intake sprocket was frozen and it did a flat 0 for retard and advance when it was hooked up to the computer. I think your car is advancing like it should, I think there might be something to the resurfacing the heads/block and the chain itself being loose from it. I don't know, I hate seeing you in this spot... I wish I could have just sold you my engine, lol
Old Jun 3, 2012 | 04:49 PM
  #353
mgrotel's Avatar
mgrotel
what was the cause of your "no advance/retard" problem at uprev? how did you fix it? sounds just like mine, the drivers side will not advance properly despite the ecu telling it to. my passenger side will advance to 30* with just a throttle blip, the drivers side never above 5*. this is definitely not normal operation and i can feel it in the powerband, not to mention the p0011 code on a regular basis.
Old Jun 3, 2012 | 04:53 PM
  #354
mgrotel's Avatar
mgrotel
and about the oil, i think i might try a 10w30 conventional and see what that does for the cold start timing chain rattle
Old Jun 4, 2012 | 02:36 AM
  #355
Classy's Avatar
Classy
Oh, I thought it was advancing, ya, my drier's side cam sprocket was shot, I got a limp tune from Uprev, drove it home, got a new sprocket and a week or so later went down to Uprev again and it was working perfectly
Old Jun 4, 2012 | 04:32 AM
  #356
Classy's Avatar
Classy
Also, it made a pretty consistent tapping noise, I drove it around without a hood so I could hear it to make sure it didn't get worse, haha
Old Jun 4, 2012 | 05:33 AM
  #357
mgrotel's Avatar
mgrotel
hmmm, how loud of a tap?
did you have to remove the timing cover to replace it?
Old Jun 4, 2012 | 10:12 AM
  #358
Classy's Avatar
Classy
You have to remove the cover to replace it, it wasn't as loud as my #6 piston slapping around with no rings, it is pretty audiable
Old Jun 4, 2012 | 01:25 PM
  #359
mgrotel's Avatar
mgrotel
just the sprocket cover? or do you mean the whole timing cover?
and you had a piston in the block with out rings? whoa, lol
Old Jun 4, 2012 | 03:18 PM
  #360
Classy's Avatar
Classy
The whole reason I did a motor build is because my motor was knocking away! The whole sprocket needs to be replaced, and yes, I know how big of a pain it is to pull the front timing cover off while it the engine is in the car... I did it to fix my car, but ya, after that, ran like a champ, about 10k miles of no problems at all, and whoever the luck **** is who bought my 350z is will probably never have a problem with the motor...
