HR intake on the DE?
Old Aug 3, 2011 | 11:43 PM
coldmack's Avatar
coldmack
Default HR intake on the DE?
Not sure where to ask this, but I thought this maybe the best place to ask? I did a search, but couldn't find an precise answers on this. There is one or two threads on getting the intake setup off the VQ35HR to work on a VQ35de motor with nice results. I'm interested in knowing if the VQ37HR or possibly the VK38 intake setup to work with the VQ35de with even more power gains? Thanks.
Old Aug 4, 2011 | 12:17 AM
User 42426's Avatar
User 42426
Instead of all that work I think you are just better off buying a used or cheap intake for 100 bucks or less. Jwt's are pretty cheap lately, and will give your engine a louder growl than the hr intake. Btw, intakes provide very minimal gains, if any.
Old Aug 4, 2011 | 07:30 AM
mgrotel's Avatar
mgrotel
got any links to successful HR intakes on DE threads?
Old Aug 8, 2011 | 11:16 AM
KhanMan's Avatar
KhanMan
You can see some pics of a HR plenum on a DE motor. https://my350z.com/forum/vq35hr/3740...an-03-a-5.html
Not sure if they are modded VQ35HR plenum or just based of them, but they are sold here. Kind of pricey if you ask me. http://www.speedforceracing.com/index.php?productID=849
Old Aug 8, 2011 | 01:28 PM
INTIMAZY's Avatar
INTIMAZY
Unrelated to HR entirely.
Came out well before HR manifold and its an entirely different concept. It's more like a kinetix ssv manifold x 2 banks.
Old Aug 10, 2011 | 05:02 PM
KhanMan's Avatar
KhanMan
Really? Could anyone say how these compare to the HR? If not would it be possible to just install the HR plenum and intake system?
Old Aug 10, 2011 | 05:42 PM
dcains's Avatar
dcains
What would one do to get the DE computer to work with the two AFM's the HR intake has? That seems to be the biggest problem.
Old Aug 17, 2011 | 07:10 PM
12AutoX's Avatar
12AutoX
Based on Sasha's testing, it seems that the problem with our intakes is too much vacuum pressure preventing enough air from getting into the cylinders at high rpms. I would think that the dual intake system would help aleviate this. If it was set up like a four barrel carb, with the secondary intake opening at the appropriate rpm, it seems like we could get the right velocity at all rpms. I gave up trying to get more power from my NA setup pending some engineer developing an intake/TB that solves this problem. If it wasn't for the MAF sensor issue, I would try it myself. A modified intake that runs a bigger throttle body might also work, but nobody sells those either. Someone here was making a limited production set, but they stopped.
Seems like we are all limited until someone steps up to the plate and designs something that works.
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
_koubie_
Sep 20, 2015 06:34 PM
