Vtc gear differences?
Old Feb 13, 2012 | 02:00 PM
tilleys99's Avatar
tilleys99
Default Vtc gear differences?
I did some searching and couldn't find any I formation on the differences between normal de, rev-up and hr cam sprocket degree differences... Are they all the same degree or are they different?
Old Mar 27, 2012 | 08:42 AM
SurraTT's Avatar
SurraTT
They are different.
My 09 Maxima motor (HR) Heads has 50 degrees of intake cam adjustment.
The older DE's have 40.
Old Mar 27, 2012 | 08:43 AM
SurraTT's Avatar
SurraTT
Sorry for the late reply, just trying to help out. Not much of that over here on this forum.
Old Jun 6, 2012 | 10:35 AM
mgrotel's Avatar
mgrotel
do the HR sprockets just drop into a non-rev DE?
Old Jun 6, 2012 | 01:48 PM
kacz07's Avatar
kacz07
^Good question, but I doubt it.
Old Jun 6, 2012 | 02:40 PM
bluezee's Avatar
bluezee
And is there a valve clearance issue at the extra cam advance if they do?
Old Jun 10, 2012 | 06:18 PM
johnwigs's Avatar
johnwigs
Adding a VTC sprocket that has more "adjustability" or degrees of advancment does not matter, the engine will not advance the cam anyfurther than the stock one... unless it has been reflashed, the VHR sprocket is the best by the way
Old Jun 10, 2012 | 06:28 PM
SurraTT's Avatar
SurraTT
Unless one is using a Haltech or other capable tuning system.
My car has no problem running 48 degrees on the intake cam. With the newer VTC sprocket, older ecu, and haltech.
Old Jun 11, 2012 | 10:03 AM
mgrotel's Avatar
mgrotel
can uprev tune for the more advancement to take advantage of it?
Old Jun 11, 2012 | 01:34 PM
bluezee's Avatar
bluezee
That's a great question for the folks from Uprev. I have the Uprev tuning pack for my DE and it is presently limited to 40 deg of advance. I also know later versions of the engine allow for more. I have know idea how hard it would be to have that changed to allow for more control from a different VTC sprocket.
Old Jan 6, 2013 | 01:59 PM
Kwame's Avatar
Kwame
Yes, according to Rich at Uprev when I spoke to him about this about a year ago.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
