N/A build advice for lower plenum
Old Mar 11, 2012 | 08:50 AM
silvertouringz's Avatar
silvertouringz
Default N/A build advice for lower plenum
Hi, I am building my 04.5 5AT 350z with the mods below:
1)3.53 final drive with vLSD off a manual
2)Greddy Ti-C true dual exhaust
3)2.5'' non resonated test pipes
4)topspeed headers
5)Blox 5/8'' plenum spacer
6)nismo intake with 3'' MAF housing
7)UR racing pulleys
8)transgo valve body upgrade
9)NGK IX Iridium #6 spark plugs
10)BC stage 2 camshafts IN/EX 264/264 10.82/10.82
the rev limiter will be raised to 7500 and the car will be tuned using uprev osiris. the question is if the revup lower plenum with shorty runners and bigger openings will help me yield high rpm power.
thanks
Old Mar 11, 2012 | 09:03 AM
kacz07's Avatar
kacz07
Yes. The revup plenum makes more high rpm power than the DE.
Old Mar 12, 2012 | 07:21 AM
terrasmak's Avatar
Should be closer to NA bolt on setup.
Old Mar 12, 2012 | 01:36 PM
thisishk350's Avatar
thisishk350
Looks like you're going all out for bolt ons, If you can get ahold of a cosworth intake manifold you should see some nice gains in the upper RPMs since you're doing cams
Old Mar 12, 2012 | 06:08 PM
Rubidium's Avatar
Rubidium
I highly suggest you keep the stock crank pulley, as I have had an un-orthadox racing pulley on for 30k miles and now it wont come off unless I go to extreme's or possibly break it's connection with the crank. GTM has video's somewhere explaining this issue.
You can get other light weight pulleys for the other components but save the life of your engine and stick with the stock (or ATI pulley)
Are you going to do any port and polishing with the upper plenum or heads?
Old Mar 16, 2012 | 03:51 PM
snobes's Avatar
snobes
are you doing anything internal apart from the cams? if not i wouldnt be reving it to 7500
Old Mar 16, 2012 | 06:06 PM
rich2342's Avatar
rich2342
sub'd for results.
Old Mar 25, 2012 | 11:36 AM
silvertouringz
Here's a shot of my engine bay right now with:
-Nismo intake, Ur pulleys, Cusco oil catch can, Blox plenum spacer, polished plenum, HKS oil& radiator cap,mishimoto thermostat
Headers, radiator silicone hoses, BC cams stage 2 waiting to be installed:
sorry for the crappy android pics
Old Mar 25, 2012 | 01:34 PM
2bad240's Avatar
2bad240
i run a ported and heavily shaved revup lower plenum on my car. but i dont have any before and after dyno or anything to backup if it made a difference. i like to say it helps and i have my rev limiter raised to 7300.
Old Mar 25, 2012 | 01:59 PM
350Zdj's Avatar
350Zdj
+1.
Rafael, it's me Dex
Install Revup oilpump or Nismo (better but costly) if you want to push beyond 7k rpm.
Sexy build you got there, me likey.
Old Apr 16, 2012 | 09:57 AM
KA24DE's Avatar
KA24DE
Don't use those headers, don't rev that high without rodbolts and a better oil pump and don't use the cosworth(less) or Revup plenum. Good luck.
Old Apr 16, 2012 | 04:52 PM
kacz07's Avatar
kacz07
You only need JWT valve springs and shims to rev to 7500, as per SG's build.
Revup oil pump is a great idea.
The revup lower will peak higher in the RPMs. It works if your peak is above 6350. Fact.
Old Apr 16, 2012 | 05:31 PM
2bad240's Avatar
2bad240
i rev my stock de to 7300 spraying a 150 dry shot. and i have a revup lower on it
Old Apr 16, 2012 | 06:38 PM
0jiggy0's Avatar
0jiggy0
Post pix of lower end guts on the floor when it happens, thx.
Old Apr 17, 2012 | 01:22 AM
2bad240's Avatar
2bad240
just had it tuned this weekend. made 410/470.
Old Apr 17, 2012 | 11:21 AM
KA24DE's Avatar
KA24DE
And make less average power overall. Fact.
Old Apr 19, 2012 | 09:35 AM
DFW Z33's Avatar
DFW Z33
I am salad
Please post dyno results afterwards! Sub'd
Old Apr 26, 2012 | 03:18 AM
R3belzBRN's Avatar
R3belzBRN
why bro? any personal experience on it? i just bought the header but i havent install it yet
Old Apr 26, 2012 | 06:24 PM
kacz07's Avatar
kacz07
He specifically asked about high rpm power. Fact.
Old Apr 27, 2012 | 01:52 AM
snobes's Avatar
snobes
No point in using the revup plenum unless it's a built motor.
He just won't be reving hard enough to get power under the curve.
