Na build dyno #s estimate
Old Dec 4, 2018 | 01:41 PM
BluestreamDE's Avatar
BluestreamDE
Originally Posted by MatthewBouchard
Cool graph, never seen that post before. With a proper plenum, there should be no reason to fall off that hard after 6.2?k.
Search bar is your friend!
yes, for me at least, the longer the torque curve can be maintained in the upper rpms,, the better as it correlates with HP production. You will continue to make power past the stock redline even with stock cams with the Kinetix Velocity by sacrificing short peak whp with a flatter torque line, you have more power overtime. With cams and high compression more gains will be had.
If you want to keep it simple and go with a spacer and stay at the stock redline, this is fine. The Kinetix is not for everybody, and you will need to have other parts along with it to yeald better results along with a remapped tune to rev higher.
Old Dec 4, 2018 | 05:27 PM
Conway_160's Avatar
Conway_160
Hopefully, In jan i'll be able to hit the dyno and ill show the differences between my 288whp tune with stock manifold and 5/16 spacer and the kinetix.
Old Dec 4, 2018 | 05:38 PM
BluestreamDE
You have 272 cams and 11.1cp , right? I'd rev all the way to 7400rpm with those, with the oem bottlenecked plenum you are just shooting yourself in the foot choking your motor of air on the topend.
Old Dec 5, 2018 | 07:09 AM
Conway_160's Avatar
Conway_160
i only have 264's at the time i wantes drop ins and 272's needed springs. I do rev to 7400 i double checked this morning.. The dyno sheets shows 6800 but thats due to smaller tires and reading dyno rpm not engine rpms.
pearl350z
Aug 14, 2003 10:49 AM
failsafe
May 18, 2003 06:15 AM
Ludecrew
May 17, 2003 05:53 PM
Jill
Dec 21, 2002 07:55 PM
