anything I should know?
Old Jul 19, 2008 | 08:35 PM
glbeckjr's Avatar
glbeckjr
Default anything I should know?
I am due back to the US in Oct. My Nizmo has been sitting on jack stands with the battery disconnected for a year now. Is there anything I need to know before taking a cab to the storage unit and finding out my car won't start? I plan to pick up a new battery on the way from the airport. I am just concerned that I will get the battery in and there will be ECU issues or something. Any info that could save some heartache (and being stranded at a storag facility) is greatly appreciated.
Old Jul 19, 2008 | 09:06 PM
NISMO_558's Avatar
NISMO_558
really it's not what you should do when picking it up, it's how you prepped it before you stored it. If you stored it correctly you shouldn't have any problems, I would suggest changing the oil though.
Old Jul 20, 2008 | 12:47 AM
terrasmak's Avatar
Good chance your battery will be fine, maybe a little low and needing a jump.
Old Jul 20, 2008 | 01:07 AM
Greg06's Avatar
Greg06
There shouldnt be any Ecu problems it would just be reset.. A new battery should be all you need.. Dont forget some tools for the batt exchange.
Old Jul 20, 2008 | 01:09 AM
Swifty's Avatar
Swifty
i left my old jeep in storage for a year while i was in Iraq, came back and it was perfect! like mentioned above, its all on how you prep'd it. you should be ok though.
Old Jul 24, 2008 | 07:59 PM
glbeckjr's Avatar
glbeckjr
Thanks to all for the info. I put fuel stabilizer in the tank and ran it for about 30 minutes, then disconnected the + terminal of the Battery. The rear jack stands are about 4 inches higher than the front stands. I am asking because I have read some threads about people having ECU issues when disconnecting the battery. I just wanted to be sure that I did/did not need to memorize the whole ECU reset procedure (turn key, push gas pedal blah blah) ya know. Anyway, thanks a million!
Old Jul 25, 2008 | 04:34 AM
Reality350's Avatar
Reality350
Put in a fresh tank of 93 octane!
Old Sep 14, 2008 | 10:15 PM
chopperman's Avatar
chopperman
Bumping an old thread instead of starting a new one.
I wont be home for another 3 months if the battery for the Z was disconnected will I lose my tune on my Fcon? Would it be better to just put a battery tender on it?
Old Sep 15, 2008 | 03:34 AM
jmark's Avatar
jmark
Battery Tender Jr. works great.
Old Sep 15, 2008 | 04:44 AM
Nizmo0395's Avatar
Nizmo0395
Alway disconnect neg. battery cable not pos.When you disconect the battery for 15 min or so that will reset computer.Then you need to drive the car for the computer to learn again.
