Traction/VDC HELP!!! SLIP LIGHT!!!!!!!!
Old Jul 27, 2010 | 06:04 PM
MB350zz's Avatar
MB350zz
Default Traction/VDC HELP!!! SLIP LIGHT!!!!!!!!
Hey Nismo 350z community I don't know if this is the right place to post but I need help. So I recently changed my rear tires from 265/35/19 to 275/30/19...Ever since the install from last night till work and back home every once in a while my SLIP light comes on. It will last for like 1 to 3 minutes then it will go away only on the freeway. Do you think its because I changed the tires? It shouldn't do that though right because I had 19's before and never had that problem. I have a Nismo 350z with stock Nismo wheels. What do you guys think it is? Anyone had this situation before ? Any help would be much appreciated. Im searching the forum as well. Thanks everyone
Old Jul 27, 2010 | 06:10 PM
TheFarmer's Avatar
TheFarmer
Your new tires. If it was fine before and all you did was swap'd tires and now you're having this problem...huge clue That and the fact that your new tires are almost an inch shorter than your older ones.
Old Jul 27, 2010 | 06:17 PM
And the front tire size is?
Old Jul 27, 2010 | 06:23 PM
NISMO462's Avatar
NISMO462
You need 275/35/19...
Old Jul 27, 2010 | 06:41 PM
DavesZ#3's Avatar
DavesZ#3
You don't need two threads asking the same question. Already answered in the other one...
https://my350z.com/forum/wheels-and-...lip-light.html
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
