Nitrous Oxide Too soon, jr.
changing spark plugs are a pain
Old Oct 2, 2005 | 06:23 PM
faster than u's Avatar
faster than u
Default changing spark plugs are a pain
changing spark plugs are a pain, trying to put my nitrous in and oh my god these hard to get to
Old Oct 2, 2005 | 06:31 PM
westpak's Avatar
westpak
SFZCC
Actually they ar enot bad just move some section of harness out of the way on the back ones, just remove a couple of bolts holding the harness bracket.
Try doing it on a 300ZX you have not seen PIA
Old Oct 2, 2005 | 07:13 PM
QuadCam's Avatar
QuadCam
Taking you time, you should be able to do in an hour.
Make sure the engine is cool thouh. Hot heads make life more dificult.
Old Oct 2, 2005 | 07:55 PM
Barzten1's Avatar
Barzten1
It takes from about 45min to and hour. Kind of a pain in the *** though
Old Oct 4, 2005 | 08:41 AM
babyz's Avatar
babyz
hey ima spray 75 shot you think i should change out the plugs?
Old Oct 5, 2005 | 07:53 PM
faster than u
ok i chaged them and the car seems to be louder, and i feel vibration in the gas pedal, can some one tell me why, they are ngk step colder iridium
Old Oct 10, 2005 | 10:24 PM
westpak's Avatar
westpak
SFZCC
It sounds like yo umight not be running on all cylinders, still have the problem?
Old Oct 21, 2005 | 09:17 AM
Jaki's Avatar
Jaki
+1 Did you check your coils to make sure none are blown and everything is connected right?
Old Oct 22, 2005 | 09:20 PM
JRaptor2000's Avatar
JRaptor2000
its not too difficult with a spark plug socket. takes about a 1/2 hour at most.
Old Oct 23, 2005 | 08:04 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Have you changed plugs on a Z? If not then you dont know whats up. Im mechanically inclined and my first time along with performing a compression test took me 1 hour. You have to move the engine harness and put your hands in tight spaces to manuver the coil packs out. Its not hard to do you just have to be smart about getting into tight spaces. If I had to do it again I dont think I could do it in 30 min, 45 tops, but def not 30...this isnt a Corrado
Old Oct 23, 2005 | 02:38 PM
JRaptor2000
yea i did some on a Z, it's definately not the easiest but it's not as difficult as something like a v6 minivan.
corrado's are a PITA to do the plugs. you gotta use a special spark plug wire removal tool to get the plug wires off, and that can be a pain, especially if the wires are stuck, because if you break the tool, you have to remove the intake manifold to get the wires off. (add 40 mins)
then you have to get the spark plug socket down in there and on the plug blind.
it takes around 45 mins to do if everything goes right.
Old Nov 15, 2005 | 05:31 PM
NdaCut's Avatar
NdaCut
how safe is it to use 100oct or nos octane booster in these cars?
NdaCut
Old Nov 16, 2005 | 05:52 PM
done12many2's Avatar
done12many2
NdaCut
If you are spraying, the 100 octane is not a bad idea depending on your shot size. If you are not spraying, it really isn't necessary at all. The whole idea of using higher octane fuels and colder plugs is to compensate for lack of pulled timing and to reduce severe detonation.
Old Mar 10, 2006 | 06:28 AM
BobbyRitz's Avatar
BobbyRitz
Bert--
I'll meet you if you have time to help me change them out this weekend.
Old Mar 10, 2006 | 06:40 AM
nissansource's Avatar
nissansource
took me about an hour 2 days ago... just move harness alittle bit to get the coils out
350z82
Oct 1, 2015 06:25 PM
