Nitrous Oxide Too soon, jr.
my nitrous 1/4 mile times
Old Mar 1, 2006 | 01:26 PM
titanjc's Avatar
titanjc
Nice times! I'd like to see what you trap on a clean run. Dammit you're making me want a nitrous setup!!
Old Mar 1, 2006 | 01:55 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
thanks guys, it will be much safer now cause the utec will control on and off at certain rpm and only on under 100% TPS
much much safer, i also have figured out that i was starting with 950 psi on my bottle, by the time i get to third gear it falls to almost 800
hence my slow trap speed, my next run i am going to heat it up to 1050 to start that way it might fall down to 900 at worst
i will be getting two bottles if i keep my nitrous setup much longer and do a two stage shot
Old Mar 1, 2006 | 05:46 PM
bacalhau16's Avatar
bacalhau16
wow thats awesome. but why do you lose so much pressure during your run? How big of a bottle do you currently have?
Old Mar 1, 2006 | 05:50 PM
Audible Mayhem
My350z
one 10 pound bottle, i can actually just watch the gauge fall as i hold down the button, kinda sucks so i will have to try raising up the pressure like i was told by a very knowledgable nitrous mustang guy, he told me to start with it high around 1050 or so, its just hard to get it that high when its chilly outside
Old Mar 1, 2006 | 06:18 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
raise it to 1100-1200, that's the way I used to run it
Old Mar 1, 2006 | 06:25 PM
Gators2001's Avatar
Gators2001
Bottle warmer!!!!
Automatically raises the temp to 1050.
I have a dual 10lbs bottle w/ dual warmers and dual remote openers set-up. Dont think I even had a long highway run that dropped me down to low.
For the track a single bottle will cut it.
But for the HIGHWAY the porschitez need more then a run or two to realized they just lost.
Old Mar 1, 2006 | 06:37 PM
Nowell's Avatar
Nowell
National Z Club
Hey bro, how do you have your pressure guage set up? I want to run my pressure guage to the A-piller pod. Is it possible? I have been trying to decide what guage I want and best to use. 2 bottle setup atm. Any suggestions? Thanks!
Old Mar 1, 2006 | 06:54 PM
done12many2's Avatar
done12many2
You need to double check what is going on with that bottle pressure. I know I don't drop any more than 50 PSI on a full 1/4 run.
I suspect this will square your trap speed away! I used to trap between 112 and 113 with a 100 shot. Even hit a couple of 114's. All that's about to change though
Old Mar 1, 2006 | 11:10 PM
bacalhau16's Avatar
bacalhau16
you can absolutely run a guage to ur a-pillar rather then on the bottle. they have adapters to do so. autometer sells nitrous guages, and i believe the have the adapter for the bottle too.
Old Mar 2, 2006 | 03:54 AM
Audible Mayhem
My350z
yeah i have trapped 110-112 with this same setup, i shifted early on that run into fifth which i shouldnt have. my friend that is a full mustang only nitrous guy says that this is normal with only a 10 pound bottle with a single stage shot. so i will try to warm it up more next time and see. i am very happy with my setup just need to work out a few little things
as far as my gauge, i have an autometer electric nitrous gauge that i mounted where the stock navi goes, autometer actually sells a holder for TWO 2 5/8s gauges, they are the bigger ones, it fits in the stock navi place that you dont even have to use anything to hold it if you didnt want to, i just have my nitrous and my vacuum for now, plus the shop didnt have an electric fuel pressure in that size/style, i just needed to put something next to it and i figure vacuum/ boost will remind me of my soon to be turbo kit, here i will attach a picture...
Attached Thumbnails my nitrous 1/4 mile times-gauges.jpg   my nitrous 1/4 mile times-steering.jpg
Old Mar 2, 2006 | 04:07 AM
Nowell's Avatar
Nowell
National Z Club
Sweet setup man! Yea my a-pillar has the AF and I was going to put pressure in there. I will hit up autometer this week! thanks!
Old Mar 3, 2006 | 09:12 AM
Old School's Avatar
Old School
Shift_Boost
Having extra line running for your gauge inside the cockpit could be why you looks so much pressure during your runs. More line makes your pressure drop quicker. Just FYI.
Old Mar 3, 2006 | 12:16 PM
Gators2001's Avatar
Gators2001
If your referring to his pressure guage. All pressure guages i know of dont have extra nitrous lines running into the cockpit.... Mine is electrical wires.
Old Mar 3, 2006 | 12:55 PM
Audible Mayhem
My350z
oh i know, its not mechanical though, its electric so no pressure loss at all...
Old Mar 3, 2006 | 01:30 PM
Old School's Avatar
Old School
Shift_Boost
OIC. nevermind then. Had mechanical in the civic 6 years ago.
Old Mar 22, 2006 | 02:05 AM
Audible Mayhem
My350z
hey guys i should be going to the track again if everything works out today. i am going to get 56N and 32F jets first and regap my spark plugs, if i dont have time to do that then i will probably just go run NA and see what i can lay down without the nitrous
not sure how my work is going to go today...
Old Mar 22, 2006 | 02:45 AM
Nowell's Avatar
Nowell
National Z Club
Must be nice, it just snowed last night =(
Old Mar 22, 2006 | 01:33 PM
  #38
Alberto's Avatar
Alberto
Cranky FI Owner
Good luck, keep us posted...
Old Mar 30, 2006 | 11:29 AM
  #39
faster than u's Avatar
faster than u
bro thats dead traction, how were you spinning, there is no way, 109mph is diggin, you had to of dead hooked
Old Mar 30, 2006 | 11:32 AM
  #40
Geovannie's Avatar
Geovannie
It was definately spinning. The low mph was because he kept having to get on and off the kit to stop it from going into the wall.
