my nitrous 1/4 mile times
when i accidently left my nitrous map on my utec and did an all motor run. 5 degrees retarded, i ran 13.4 @102 switched the map to my NA map and ran 12.9 @106 not one thing different but switching the map
the two maps are identical except for the timing....
Originally Posted by done12many2
I agree. Some suggest the retarding or advancing does nearly nothing, but I know for a fact that I can feel it. I use the Cipher to pull and add and you can fell it right away. As a matter of fact, while you are doing it at idle, you can here the tone of the exhaust and motor change as you add or pull.
and i can feel it, it not that bad but i can tell a difference.
