Nitrous Oxide Too soon, jr.
Nitrous and colder plugs question
Old Jul 12, 2007 | 01:53 PM
Derek Dee's Avatar
Derek Dee
Default Nitrous and colder plugs question
If I am only using my nitrous every once in a while, say, 1-2 pulls a month, are colder heat plugs necessary?
I am worried that running 1 step colder plugs while using the car as a DD will give me idle problems, as some have mentioned.
Basically, will running 1 heat range colder plugs without any spray/mods cause any problems for me?
Old Jul 12, 2007 | 02:02 PM
garym's Avatar
garym
You should go to the top of this thread to the Sticky by Audible Mayhem labled Nitrous Basics Thread . . . . .
Old Jul 12, 2007 | 02:05 PM
Derek Dee's Avatar
Derek Dee
Read it many times.
So I guess maybe I should rephrase the question....
Will running one step colder plugs give me any problems without any other mods?
Old Jul 12, 2007 | 02:53 PM
jksstar's Avatar
jksstar
Originally Posted by Derek Dee
Read it many times.
You will be fine running them, you will just have to change them more often
Old Jul 12, 2007 | 03:25 PM
garym's Avatar
garym
Yeah, they will foul more.
One way you might be able to get around it is if your running an EMS like the UTEC and you have a map to run slightly leaner fuel when you're just cruising around.
Old Jul 12, 2007 | 04:28 PM
Derek Dee's Avatar
Derek Dee
Thanks for the input all.
Old Jul 12, 2007 | 04:36 PM
ZU L8R's Avatar
ZU L8R
Viper Sellout
you will be fine
Old Jul 12, 2007 | 08:33 PM
Derek Dee's Avatar
Derek Dee
Thanks again all.
I had read something about the idle being goofy for some after they put in colder plugs. But I guess one heat step is not that huge of a deal.
I guess I will run some NGK's. If they foul, I'll just throw the oem ones back in. They're good for what 105,000 miles...lol
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
