Nitrous Oxide Too soon, jr.
dynotune window switch
Old Aug 10, 2007 | 07:36 PM
wckdclw's Avatar
wckdclw
Default dynotune window switch
hey, im installing my kit tomm and need instructions for what wire goes to where on my dynotune window/tps box, if anyone can help that would be awesome
Old Aug 10, 2007 | 08:41 PM
RebelinRI's Avatar
RebelinRI
Hey Why didn't you buy mine?? I know where they go, but I'm not telling J/K ok Here you are:
Blue is to TPS or WOT switch
Green is RPM or Tach input wire
Yellow controls first stage relay
Orange controls second stage relay
White to keyed 12volt source or arming switch
Black is ground
There you be. Now who's your best newest friend?
Old Aug 11, 2007 | 01:50 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
how do they switch between first and second stage/?? a timer or button??
Old Aug 11, 2007 | 04:59 AM
RebelinRI's Avatar
RebelinRI
Hey JT. I can send you the instructions if you want. Basically it's......
"Both channels have their own seettable ON and OFF points. Each channel also has its own multi-gear lockout feature which allows it to be turned off until you have cycled through the window. The internal TPAS can be configured to prevent the RPMWS channels from activating unless you are at WOT"
Let me know if you want a copy. Geeeezzzz Next thing you know I'll be selling dynotune products!
Old Aug 11, 2007 | 02:50 PM
wckdclw's Avatar
wckdclw
lol i didnt buy yours because it came with the kit i bought, and i need like how to find the pins to tap into, and the blue wire to tap into the wot switch, where does that run, and is it the same as where the zex will have to tap into?
Old Aug 11, 2007 | 04:13 PM
jksstar's Avatar
jksstar
https://my350z.com/forum/showthread....or#post2907766
that is how I wired up mine, just without the Zex box
Old Aug 11, 2007 | 08:11 PM
wckdclw's Avatar
wckdclw
that may help, but on the window switch theres 6 wires, so ones power, ones ground, ones rpm, ones tps, and what does channel one and two go to, and how do you find the pins by looking at it under the dash?
Old Aug 12, 2007 | 08:13 PM
dTor's Avatar
dTor
Channel one goes to the relays that will activate your nitrous & fuel solenoids.
Old Aug 12, 2007 | 08:18 PM
wckdclw's Avatar
wckdclw
so this is pretty much right?
and then i just need to know how to find the pins
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
AP350z223
Sep 8, 2015 04:38 PM
