Nitrous Oxide Too soon, jr.
Soon to be another Bottle Fed Z !!
Old Jan 11, 2009 | 08:36 PM
JmNismo's Avatar
JmNismo
Default Soon to be another Bottle Fed Z !!
Well i finally decided to try the nitrous scene out and bought a kit (nitrous outlet) from a really good friend of mine .. I have been doing a lot of reading and research and came to the conclusion that a 75 shot would be ok to start off with until i get a new clutch and engine management !! Luckily i have a close friend that has been running it in his altima SER for a couple years now and he's kind like my crew chief lol !
Safety wise for a 75shot i was thinking/going to; run 1 step colder plugs and there's a Dynotune 2 step window switch / WOT that looks like a good must have ..
A few questions i had were, is it necessary to go ahead and upgrade my fuel system ? Also i was looking at the Dynotune lean cut off switch and was curious if there's something else out there better for the money ? Lastly would it be better to get a plenum spacer ?
Right now i have Nismo Intake,headers, and exhaust and my car is an 04 6spd touring .. any questions feel free to ask !! i hope to get it installed within the next few weeks and get it on the dyno, i just wanna make sure i take my time and get it done right minus tuning and i'll be sure to take pics of the install :-)
Thanx again
Old Jan 11, 2009 | 08:48 PM
genegoesfast's Avatar
genegoesfast
you won't need to upgrade your fuel system. Don't forget a bottle heater and pressure gauge.
Old Jan 12, 2009 | 04:09 AM
JmNismo's Avatar
JmNismo
ohh yea .. and purge :-) i'll make sure i add those to my list
Old Jan 12, 2009 | 06:58 AM
BakaN20's Avatar
BakaN20
Thanx again
You can use the dynotune lean shutdown switch in narrowband mode since the "widebands" didn't get put in until 04.5 models.
Old Jan 12, 2009 | 07:02 PM
JmNismo's Avatar
JmNismo
oh ok sweet ! do you think it would be a good investment, or is there something else out there better ??
Old Jan 12, 2009 | 07:10 PM
ladyzed's Avatar
ladyzed
Can someone explain what the wideband thing is, for the 2004.5 models? Mine is that model...
Old Jan 14, 2009 | 03:40 PM
BakaN20's Avatar
BakaN20
From what I have read, it is a very sound investment to get just to make the nitrous safer, especially for $100. You can run it in narrowband mode, but it is more accurate if you do wideband, which would mean getting an aftermarket wideband and finding a way to tap your cats, you can either drill a bung or buy hfc which have them already. I plan on getting the innovative and berks hfc to get it running wideband.
If you have an 04.5, you have factory widebands which register at 0-2v, which means you cannot use the dynotune a/f switch, since it can only read either in narrowband mode 0-1v, or wideband mode 0-5v, so it will not work with 04.5 and up which all have factory widebands.
Old Jan 14, 2009 | 04:37 PM
JmNismo's Avatar
JmNismo
Thanx for the input guys !! what do you guys think about a fuel pump ?? unnecessary ?? and if it is a good thing to have .. do i need a fuel pressure regulator for a walbro 255 !?
dragon11689
Sep 7, 2015 02:47 PM
eskimo
Nitrous Oxide
282
Jan 30, 2011 03:22 PM
EmpiricalGMan
May 26, 2003 06:39 PM
12SecZ
May 2, 2003 06:59 PM
MrSpiffy
Cleaning & Detailing
Mar 11, 2003 11:02 AM
