Nitrous Oxide Too soon, jr.
My Nitrous Install
Old Jun 19, 2009 | 01:19 PM
ChrisNelson's Avatar
ChrisNelson
Default My Nitrous Install
My nitrous install is just about finished so I thought I should post up the pictures. I am not new to the nitrous world, I had a couple systems in the past and one was in a 1986 Pontiac Fiero
I have my own NX refill station, and my favorite equipment is indeed NX. I used to be into NOS brand, but I think NX equipment is much better.
If anyone is interested in buying any particular nitrous parts, let me know. I usually stock a few kits at a time, and I'm not afraid to ship.
Anyways, here's my install:
1 Step Colder NGK spark plugs
Dynotune digital pressure gauge
Dynotune 52mm switch center
FJO Progressive controller
NX Fuel/Nitrous/Purge Solenoids
Dual purge kit from Dynotune - mounted at front bumper
Dynotune fuel block adapter
NX 15lb carbon fiber bottle
NX remote bottle opener
NX bottle heater with automatic pressure switch
NX Shark single fogger nozzle
I have mounted the fogger nozzle to the silicone coupler on my Nismo intake pipe, but I plan on hard mounting it to the actual metal pipe soon.
Old Jun 19, 2009 | 01:24 PM
ChrisNelson
The wiring was a nightmare because of all of the electrical components I am using for this system. Of course, after it was all put back together it is very nice looking, and you can't see any of it, even if you stick your head under the dash.
Old Jun 19, 2009 | 01:32 PM
ChrisNelson
We built a new base in the back of the car to mount the nitrous brackets to, by removing the foam stanchion on the drivers side in the trunk and fabricating a piece of MDF to it so that it looks factory when all put back together:
The way it was designed, the nitrous brackets can be removed from the car in a minute or two but doesn't look like it when it's all finished. This allows to utilize as much storage space as possible.
Old Jun 19, 2009 | 01:33 PM
ChrisNelson
The purge valve releases out of the front bumper, and you can't see it unless you get really close:
Here are the finished pictures:
Old Jun 19, 2009 | 02:24 PM
striker27's Avatar
striker27
Nice work!!! You spent some time on the install. It shows too....
Old Jun 19, 2009 | 05:20 PM
ChrisNelson
Thanks!
After we get it dyno tuned it will hit the track, but I won't spray it until that time.
Old Jun 19, 2009 | 11:35 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Nice install, although I personally don't like the solenoid location nor the purge exits. I definitely like the customization for the bottle, though.
Is there a reason why I see nitrous purge coming from the solenoid area?
Also, the way you have positioned your fogger isn't safe, not to mention the fact that it seems a bit far from the manifold. Nitrous is under pressure at around 1000psi and the fuel at 51psi, I believe. Unless you triple checked to see that it's secure while on the spray, I wouldn't even think about spraying.
Lastly, don't test out the nitrous for the first time at the track. Do it some place close to home so you can remedy any issues that may arise. And be sure to use a small shot for your testing.
Old Jun 20, 2009 | 06:06 AM
BakaN20's Avatar
BakaN20
Nice. The wiring part is a nightmare, many hours sent analyzing and over analyzing it, lol. As 3hree said, it looks like your nozzle can easily blow out. Everything is a little too exposed for my taste, but thats just me, sleeper ftw! Thats awesome you have your own refill station!
Old Jun 20, 2009 | 07:31 AM
ChrisNelson
Like I said in the first post, the rubber mount is only temporary. I needed to mount it SOMEWHERE to finish the install for a few car shows. I'm going to try and use the nut/bolt style mount inside the metal piping.
As for the mounting of the solenoids, I like them there - I'm not afraid to show off what I'm using.
Also, the dual purge kit from Dynotune doesn't seal very well. I just have to take it apart and re-seal it with new couplers.
Old Jun 20, 2009 | 09:31 AM
3hree5ive0ero
Retired Admin
No offense, but I personally would never have installed it there, temporary or not. You might as well do it right the first time so you don't have to worry about it. I hope you don't activate it while it's just stuck in the rubber coupler. And update us with pictures once you drill a hole for proper fogger installation.
For me, I don't like to disclose what I have, since I feel that I have no need to show off my car. I'm not a show person and I let the car do the talking. Plus, it's so much more fun when you see somebody talking smack about your car get raped down the track by it.
It's funny how you say that the Dynotune solenoid doesn't seal well. I've experienced similar issues, too, with 2 solenoids actually. My nitrous solenoids (1st one that I returned and the 2nd I got) leaked, but my purge solenoid seems to be fine. I just used a lot of teflon tape in the connections (teflon paste is highly recommended) and it slowed down the leak greatly. I still have a very minimal leak, but I actually like that there since it gradually clears the line pressure for me.
Old Jun 20, 2009 | 10:14 AM
ChrisNelson
Sorry no, I meant that I am using the Dynotune dual purge kit.
I have NX solenoids, and none of them leak. The connection between the nylon purge line, and the twin line adapter leaks because all it uses is crush-couplers.
Also, at this point in time I can not accidentally push the button and make it go because it is all automated, but I have yet to hook the FJO controller up to the computer.
There is no "go baby go" push button in the car. Arm the system, then at wide open throttle, between 3K and 6.2K rpm the system will spray. I do not currently have the controller connected to the tach or throttle switch wires at the ECU yet, so the actual injection system is currently dead.
When I get to permanently mounting the fogger nozzle, I will be finishing the wiring on the FJO controller as well. At that point the system will be ready to go.
As far as shows go, I think people like to see the equipment installed on the car so that's why I put them where I did. I like looking at them, and so do other people. I do a lot of car shows, and I want to have something to show.
Old Jun 20, 2009 | 10:17 AM
3hree5ive0ero
Retired Admin
Cool. That all makes sense. I just like having a sleeper, that's all. When it's time to change your solenoids, you'll be done a whole lot faster than I will be, I'll give you that.
Old Jun 20, 2009 | 02:18 PM
ChrisNelson
This single observation pretty much justifies having my solenoids front and center all by itself.
Old Jun 22, 2009 | 09:16 AM
garym's Avatar
garym
I agree with 3hree5ive0ero, nice setup, but I also like to keep my system secret.
Especially these days with law enforcement looking for bottles hooked up in cars, and jerks out there that will turn you in for it just to be a jerk.
My purge is behind the front wheel so no one sees it.
I just took mine in to UnNatural for the Dyno Day they had this weekend.
If I hadn't of told him it had nitrous, the only way they knew I had it was from the smell of the exhaust (and the numbers).
He smiled and said "I know that smell! I love it!" LOL!
I like your bottle. Sweet paint job!
Old Jun 22, 2009 | 01:00 PM
coachk's Avatar
coachk
What size shot are you going to spray?
Old Jun 22, 2009 | 01:58 PM
Italianjoe1's Avatar
Italianjoe1
Agreed. The solenoids on my Cobalt were under the intake down by the ABS module, you couldn't see them for ****, but I couldn't reach them for **** once installed either. Having to change out the nitrous one twice after the inital install, I started to regret putting them there. Anyone I know already knew the car was on bottle, and anyone else could go **** themselves if they wanted to look under the hood, I don't open the car up out at race spots unless there is something major wrong.
Old Jun 22, 2009 | 08:00 PM
ChrisNelson
It's jetted for a 75hp shot according to NX instructions, so we'll see how it goes. I think I'll up it to a 100hp shot later after we get it all working.
You don't hear about many problems around where I live about cops busting people for nitrous. Not many people use it, and most cops don't know a damn thing about racing parts anyways. Besides, they gotta catch you before they can check for nitrous, right?
Old Jun 22, 2009 | 08:01 PM
ChrisNelson
Thanks for the comment, but it's not painted. The bottle is a lightweight carbon fiber composite bottle. That is just what the material looks like. It is only clear coated.
Old Jun 22, 2009 | 09:52 PM
VS 350Z's Avatar
VS 350Z
You need to place the nitrous nozzle placement 6” to 18” from the throttle body so the fuel and nitrous can mix! Hope you change the location before you use it! Good luck! Like the custom trunk area!
Old Jun 23, 2009 | 10:25 AM
garym's Avatar
garym
It looks too close, but if you look at the 5th pic and the last one in the set of pics in the first post, he has it in the coupler next to the MAF sensor, and then 8-10 inches of Nismo tubing between the nozzle and intake. He should be okay.
My bad! Still is a sweet looking bottle!
