Nitrous Oxide Too soon, jr.
Bottle Location
Old Aug 12, 2009 | 10:29 AM
Phenom's Avatar
Phenom
Toasty
Default Bottle Location
I know I've got a lot of planning and research to do before buying a kit but A TT kit is out of the question for the near future because of how much it will all cost. So I'm fairly sure nitrous will be my next big step, and I'm curious to know where a typical decent spot would be for lets say a 10 or 15 pound bottle.
Someone suggested placing it in the spare tire area, obviously I'd need to remove the spare and then the trunk mat won be able to fit over it. I'm assuming this will make my trunk look like crap and wouldn't that cause me to hear a lot more noise in the cabin (exhaust, tire noise, rocks, etc)? I'm not out trying to hustle kids with my sleeper or anything like that so I don't really care for a stealthy set up. Besides I go to some shows here and there and I plan on going to a bunch more so I think a nice clean, visible install would be something cool to show.
I have nothing in my hatch, no sub box or audio equipment so I was thinking the idea of placing it under the strut bar would be cool, except it seems that since it has to lay on an angle it won't fit under there. So I guess that just leaves me with in front or behind the strut bar (I'm guessing a 10+ pound won't fit behind there either). Any other suggestions/pics? Thanks a lot.
Old Aug 12, 2009 | 11:18 AM
biggersNISMO's Avatar
biggersNISMO
http://4.bp.blogspot.com/_L4b5t-25Fc...0/DSC02038.JPG
sorry, bad pic... but just an idea.
what mods do you have to get to 325whp N/A
Old Aug 12, 2009 | 12:04 PM
Phenom's Avatar
Phenom
Toasty
thats a cool setup, pretty much thats what I had in mind.
btw my mods are injen intakes, injen track exhaust, berk tp's, and the uprev tune. heres my thread about it https://my350z.com/forum/vq35hr/4465...tune-dyno.html
Old Aug 12, 2009 | 10:16 PM
ChrisNelson's Avatar
ChrisNelson
Having the bottle facing to the side like that is a bad idea. The bottle should be facing parallel with the car as much as possible. Here is a picture of my setup:
The reason for this is that the bottle uses a siphon tube to pick up the nitrous. When you are accelerating all of the liquid nitrous will flow to the bottom of the bottle where the tube is. This will allow you to get the most out of your bottle and you won't risk a low nitrous condition when accelerating.
When you have the bottle mounted sideways like suggested your nitrous will all get pushed to the side walls of the tank and will not get picked up at the end of the siphon tube inside the bottle.
Old Aug 13, 2009 | 06:14 AM
BakaN20's Avatar
BakaN20
Put it in the glove compartment. A 10lb is perfect for it. Here is how I have mine, it is not optimal, but it should still be able to pick up liquid nitrous. I also have a 4500psi kit at home, i think it would fit in there also. As for blow down tube, get the one from dynotune that has braided ss lines.
Old Aug 18, 2009 | 04:51 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
https://my350z.com/forum/nitrous-oxi...-play-too.html
Old Aug 20, 2009 | 12:11 PM
uglyduc's Avatar
uglyduc
Anyone have shots like this but with the bottle behind the driver side compartment? I like the idea of keeping my glove box... and I know technically drivers side doesnt just swing open, but that's an easy fix.
Old Aug 22, 2009 | 07:30 AM
BakaN20's Avatar
BakaN20
It would be the same on the driver side. If you have a bose system, just remove the subwoofer, if you don't have a bose system, just remove the subwoofer plate, but both compartments are the same. The glove box would fit on the driver side also, but it just doesn't have the latch to close.
Old Aug 27, 2009 | 10:08 AM
uglyduc's Avatar
uglyduc
Thanks for confirming. I've seen a couple people add latches to this panel, I'll have to dig those up for more ideas.
Old Aug 27, 2009 | 10:33 AM
BakaN20's Avatar
BakaN20
One thing I forgot to mention was that on the passenger side, there is a bracket that the glove box screws onto i think, that is not on the driver side, so you essentially have more room to work with on the driver side. I have my bottle on the passenger side and a nazar sub box on the driver side, but it could work either way. Only reason i have it this way is that I would access the nitrous a lot more than I would the sub box.
Stevo Z
Oct 3, 2015 09:14 PM
Tochigi_236
Sep 27, 2015 03:40 PM
