Nitrous Oxide Too soon, jr.
Bottle placement.
Old Dec 6, 2009 | 07:48 PM
SLIdEwAyZ25's Avatar
SLIdEwAyZ25
Default Bottle placement.
Can a 10 pound bottle be placed parellel to the rear strut bar on the side closest to the driver?
like right behind the little click open cubby hole were it can be reached from the driver seat without a remote bottle opener.
Old Dec 6, 2009 | 09:07 PM
You can mount the bottle anywhere as long as it is secure. There are plenty of clamps available for unique applications.
I have seen a bottle mounted between the driver and passenger seat. Probably not a smart idea to have a 900 PSI bottle next to your head.
Old Dec 7, 2009 | 06:25 AM
absurdparadox's Avatar
absurdparadox
Yep, a lot of people have their bottle there.
The downside to doing that is that its harder to use a full bottle, with it mounted sideways. I couldn't find an easy way to get underneath the "floorboard" there, so I used some inverted claw screw things (unsure what they're actually called). I drilled a hole, folded the "claw" up, pushed it through the mount and the hole, and then tightened it up. Does that make any sense? lmao
Old Dec 7, 2009 | 07:01 AM
eltness350's Avatar
eltness350
The Untouchable
i put mine behind the passenger with the valve facing towards me ...then its easy to open/close it since its within a arms reach instead of payin a bunch of money for a opener...
Old Dec 7, 2009 | 07:08 AM
absurdparadox
I still used an opener, myself. I figured I was buying the gauge-style switch center from dynotune... might as well get an opener to go with the switch, lol. Plus, I thought it would be awkward to try to open while driving or something. Not that one ever would need to do that... <.<
Old Dec 7, 2009 | 10:44 AM
SLIdEwAyZ25
do you mind sending me a picture of your set up?
and those "claw screw things" lol.
Old Dec 7, 2009 | 10:56 AM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I have mine mounted there, facing the valve away from the driver.
https://my350z.com/forum/nitrous-oxi...-play-too.html
Old Dec 7, 2009 | 12:23 PM
SLIdEwAyZ25
dang that looks nice thats were im planning on putting mine.
and if i am seeing it correctly, do you have to take all the plastics out for it to fit or do you just have it like that to save weight?
Old Dec 7, 2009 | 12:26 PM
3hree5ive0ero
Retired Admin
Thanks.
You'd have to take some interior panels out if you want the wiring hidden and to install your mounting brackets. I was supposed to put the interior panels back in after the install, but I got lazy and never put them back in. It's been years, but I still have them out. The road noise will increase noticeably but I guess you do lose a bit of weight (it's plastic so it's very light, thus probably negligible) so I guess it evens out.
Old Dec 7, 2009 | 12:51 PM
SLIdEwAyZ25
Thanks.
I figured i would have to take the interior panels out to do the wirring i just put my wideband in my cubby and had to take some of the dash out.
so all i have left is to put put the nitrouse system in, I just wanted to make sure the bottle would fit in that location without having to hack away at some of the pannels.
AngryZ
East Canada
Sep 16, 2015 05:08 PM
eskimo
Nitrous Oxide
282
Jan 30, 2011 03:22 PM
bhobson333
Cleaning & Detailing
Jul 8, 2003 05:20 PM
EmpiricalGMan
May 26, 2003 06:39 PM
John
May 20, 2003 10:20 AM
