Nitrous Oxide Too soon, jr.
direct port idea
Old Mar 28, 2012 | 02:09 PM
  #61
2bad240's Avatar
2bad240
Originally Posted by mgrotel
did you tune? were you able to get enough fuel to it with running just a dry setup? i may do something similar but do each port wet instead of dry. i like how you hid the lines and none of it is visible. looks much better and cleaner than a bunch of ugly hard lines all over the place
no i havnt got it tuned yet for the nitrous. just a n/a tune to be able to drive it around some. im trailering it to national speed on april 14th for the dyno tune. i have 550cc injectors in it now so im pretty sure they will supply the needed fuel.
yea im pretty happy the way it came out you cant see any of the lines. the real test will be when i hit the dyno. im hoping to put down about 415/445
Old Mar 28, 2012 | 02:19 PM
  #62
mgrotel's Avatar
mgrotel
i see, i didnt realize you got bigger injectors. i was worried the stock injectors would not supply enough fuel. post numbers after you dyno!
Old Mar 28, 2012 | 02:23 PM
  #63
2bad240's Avatar
2bad240
yea i called deatchwerks and they said 450s would do it, but would be close to maxed out, so i got 550s. yea il post numbers for sure. im thinking of sticking my gopro to the bottom of the hood facing the engine in case it blows up.
Old Mar 28, 2012 | 02:46 PM
  #64
mgrotel's Avatar
mgrotel
lol
Old Apr 14, 2012 | 02:08 PM
  #65
2bad240's Avatar
2bad240
Dyno'd it today. Made 396/441 with bottle psi @950 410/470@1100.
Old Apr 15, 2012 | 09:58 AM
  #66
2bad240's Avatar
2bad240
http://youtu.be/NQQlFcvAbcw
Old Apr 15, 2012 | 12:29 PM
  #67
denchan350gt's Avatar
denchan350gt
what did you have before?
Old Apr 15, 2012 | 02:11 PM
  #68
2bad240's Avatar
2bad240
They pulled up my dyno chart from 150 single wet and it made 370/409
Old Apr 19, 2012 | 07:28 AM
  #69
mgrotel's Avatar
mgrotel
can you post the graphs? im curious about what your a/f ratios were
Old Apr 19, 2012 | 10:36 AM
  #70
2bad240's Avatar
2bad240
Old Apr 19, 2012 | 08:59 PM
  #71
mgrotel's Avatar
mgrotel
thanks
Old Apr 19, 2012 | 09:00 PM
  #72
mgrotel's Avatar
mgrotel
badass! need to get mine done
Old Apr 19, 2012 | 09:36 PM
  #73
juicinjake's Avatar
juicinjake
glad to see this is going well. congrats on the good results. nice video too!
Old Apr 20, 2012 | 07:13 AM
  #74
mgrotel's Avatar
mgrotel
do you have stock half shafts in the rear? i cant wait till i get mine back together
Old Apr 20, 2012 | 07:34 AM
  #75
mgrotel's Avatar
mgrotel
i might have to steal this idea man, i am really liking that setup. except i think ill do wet shots at each cylinder, im thinking 30hp each
Old Apr 20, 2012 | 07:55 AM
  #76
2bad240's Avatar
2bad240
Yea stock axles. Stock flywheel too. Running a f1 racing stage 3 clutch. I did a few test passes at my local 1/8th mile track it was unpreped Just spun bad. But picked up 2 tenths over last time I took it there. I'm pretty sure its close to getting the front wheels off the ground. Im really impressed with this setup. The car is alot smoother going down the track and just feels so strong.
Old Apr 20, 2012 | 09:16 AM
  #77
mgrotel's Avatar
mgrotel
you convinced me, im doing it. except i might just use T fittings at each cylinder, to mimick a nitrous rail and then also a fuel rail except with T fittings
Old Apr 20, 2012 | 09:50 AM
  #78
2bad240's Avatar
2bad240
the reason i did the dry setup is more precise fuel and dont have to worry about mixture or puddling.
Old Apr 20, 2012 | 01:15 PM
  #79
mgrotel's Avatar
mgrotel
Yea, I understand why you went with dry, I just have stock injectors, so wet it is for me. Unless you think pooling is a possibility with 30hp pills in there.
Old Apr 20, 2012 | 03:40 PM
  #80
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
^ Where would it pool when you have a DP set up? I think you're fine.
