Nitrous Oxide Too soon, jr.
My install thus far
Old Feb 24, 2018 | 04:27 PM
  #41
Dhoffman's Avatar
Dhoffman
Old Feb 24, 2018 | 04:33 PM
  #42
Dhoffman's Avatar
Dhoffman
Purge solenoid mounted in with abs and master cylinder.
The nitrous and fuel lines that came with kit where to short so I put in 36” lines in stead of 24”. The longer lines created a short delay before nitrous kicked in. So I ended up installing
15” lines and a new intake tube 2” from the tb. Now the nitrous hits instantly under wot. The purge tube was way short so I bought one from a local speed shop that was flexible copper and ran it to drivers side windshield so I can see it purge.
More pics to come...
Old Feb 24, 2018 | 05:50 PM
  #43
onevq35de's Avatar
onevq35de
Nice pics so far D. Auto here as well. You got a transgo shift kit or valve body upgrade? If not, do it, do it now!
Old Feb 25, 2018 | 12:47 AM
  #44
Dhoffman's Avatar
Dhoffman
Default Nitrous install
Originally Posted by Dhoffman
Mounted nmu behind plenum. Was a tight fit especially when you have a automatic transmission dipstick right underneath the fuel and nitrous lines. Yes I have a automatic.
Old Feb 25, 2018 | 12:48 AM
  #45
Dhoffman's Avatar
Dhoffman
Mounted arming, bottle heater and purge
Old Feb 25, 2018 | 12:51 AM
  #46
Dhoffman's Avatar
Dhoffman
I have been thinking of adding that. I’m not experienced enough to install myself. Thanks for the tip.
Old Feb 25, 2018 | 12:54 AM
  #47
Dhoffman's Avatar
Dhoffman
I also added the Zex nitrous fill gauge in cubbyhole. Well worth it.
Old Feb 25, 2018 | 01:16 AM
  #48
Dhoffman's Avatar
Dhoffman
Over all I’m glade I did the install myself. A local shop wanted 600 to 800 bucks to install. If you want to have it installed quick then pay someone else to do it.
It took me 2 months to do it because I only worked on it a few hours on the weekend
It was well worth the wait. You can’t put a price on self gratification on a job well done yourself. I was nervous but excited for the first time I hammered it to the floor. I’m currently running a 65 shot. Still not enough but fun. As soon as I hit 75 shot I will think about a tune. I’m still not feeling the full punch of the nitrous because I can’t get the bottle pressure up to 950 even with a heater. It’s still a little cool here in Florida but warming up fast.
Oh, just one more tip, if you have traction control make sure you turn off when spraying.
If anyone out there is thinking of nitrous on a stock motor don’t hesitate just be safe and take your time! Remember nitrous does not kill motors People do!
Any questions feel free to ask.
Old Feb 25, 2018 | 04:19 AM
  #49
onevq35de's Avatar
onevq35de
Good job D. You might want to consider the nano & ditching the blanket. That's what I've got planned. N2O can kill your auto trans quick so as you up the power, ya might wanna set that window switch up properly if you haven't already.
Old Mar 4, 2018 | 05:39 AM
  #50
Dhoffman's Avatar
Dhoffman
Anyone running nitrous with a NWP 75 mm throttle body with wot switch? I searched lots of threads and found nothing. I’m currently running Zex nitrous with stock tb. I’m thinking of
Purchasing the NWP tb. I would image I would have reprogram the new tb with the nwu.
Any takers on this?
Old Mar 7, 2018 | 06:44 AM
  #51
BakaN20's Avatar
BakaN20
Going with nano can be pretty annoying, especially if you go with their 4500psi kit. Blanket is much more convenient.
Any takers on this?
I am using a maxima 75mm tb, no problems I see
https://my350z.com/forum/na-builds/6...xima-tb-3.html
Dhoffman, how do you have your bottle blanket wired up? Do you have the power going directly from the battery? Is the psi/temp setting set correct? There should be no reason you can't get it up to 950 psi.
Old Mar 7, 2018 | 07:16 AM
  #52
onevq35de's Avatar
onevq35de
[QUOTE=BakaN20;10943580]Going with nano can be pretty annoying, especially if you go with their 4500psi kit. Blanket is much more convenient.
They don't make the 4500 anymore, just the 3000.
What annoyed you about the Nano?
Old Mar 7, 2018 | 10:41 AM
  #53
BakaN20's Avatar
BakaN20
It was difficult to find a place that could fill up to 4500 psi, thats why I got rid of it.
Old Mar 7, 2018 | 10:55 AM
  #54
onevq35de's Avatar
onevq35de
Ah. Is that your only gripe then?
Everything I thought I knew about it lead me to believe it's better than a blanket in near every way, except cost. Don't have one yet so I speak only from research and talking to the new owner of Nano, but this is an important part of my would-be setup.
Old Mar 8, 2018 | 11:24 AM
  #55
BakaN20's Avatar
BakaN20
Finding a place to fill it was difficult. And I compiled the list of locations for the old owner, was looking for the thread on ls1tech, but couldn't find it. Also, it is susceptible to heat. Sometimes keeping it simple is the better way to go.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
