Nitrous Oxide Too soon, jr.
question for those with purge kits
Old Apr 17, 2004 | 06:09 PM
Melissa's Avatar
Melissa
Default question for those with purge kits
where are you guys having the purge spray the nitrous on exit?
having trouble figureing where to have it spray
thanks
john
Old Apr 17, 2004 | 08:50 PM
fluidz's Avatar
fluidz
left back corner of hood.
Old Apr 18, 2004 | 05:00 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I think I'm gonna have mine run out the front tow hook hole.
Old Apr 18, 2004 | 07:19 PM
scubasteve's Avatar
scubasteve
What is the purge for???
Old Apr 19, 2004 | 02:46 PM
cyberz350's Avatar
cyberz350
I've attached a picture of where my purge valve is routed. I mounted the purge valve in the brake fluid compartment and faced the Zex purge solenoid towards the firewall. The brass line exits out through the vent holes under the windshield wiper. You can see it in the top fo the picture.
As for what a purge does
From Zex website:
"To be the quickest off the line, your nitrous system must deliver pure liquid nitrous from the first instant. The ZEX Nitrous Purge Kit clears unwanted vapor out of the system to assure rocket-like starts, essential for beating the competition off the line."
Old Apr 19, 2004 | 03:14 PM
cyberz350's Avatar
cyberz350
Here's a quick video I have on imagestation if you guys wanna check it out. I think you have to be a member of imagestation but its free. I've got a better quality one in daytime if someone wants to host it.
http://www.imagestation.com/album/?id=4287683893
Old Apr 19, 2004 | 08:47 PM
cyberz350's Avatar
cyberz350
I actully just added a higher quality shorter clip to that album.
If you guys need the imagestation login just use:
Login: zmovies
password: 350z
Old Apr 20, 2004 | 07:30 AM
TheBigShow's Avatar
TheBigShow
keep the spray away from your windshield; it could crack it. pointing straight up from the top of the hood was where i had it on my si.
Old Apr 20, 2004 | 08:24 AM
cyberz350's Avatar
cyberz350
It actually clears the windshield and sprays away and to the side.
Old May 10, 2004 | 05:44 PM
jzarrabi's Avatar
jzarrabi
can i somehow make it blow off in vents in front of the drivers side tire? That is where i want to install mine. but i dont know if its possible
Old May 11, 2004 | 08:49 AM
shanedog's Avatar
shanedog
Just wondering, what shot are you running? How is it when the nitrous is on?
Old May 12, 2004 | 08:19 AM
cyberz350's Avatar
cyberz350
Man, with long enough hoses you could make that ish vent where ever you want.
Old May 13, 2004 | 07:05 PM
jzarrabi's Avatar
jzarrabi
k kool thanks cyber
Old May 19, 2004 | 05:20 AM
j's350z's Avatar
j's350z
We installed one at our shop on Edubbz Z spraying right through the front emblem. Drilled a small hole under the nissan logo and used brake line and a rubber grommet. Looks like a tiny camera but is sick when he purges!!! I will try to find pics...
Jason
MRC Motorsports
jason@racemrc.com
Old May 25, 2004 | 09:52 AM
jdm3fiddyZ's Avatar
jdm3fiddyZ
I am running the Zex purge kit in my Z and i used a vacuum hose coming out of the solenoid. i split the hose using a T bracket and i have them coming out each of the front wheel wells. Looks tight!
Old May 26, 2004 | 10:02 AM
cloudkid's Avatar
cloudkid
I am shooting mine out of the Infiniti Emblem. Right out the front nose. "Dragon style". =).
(G35 Coupe here). I am using the Zex Purge Light. I used a dremel and it fits perfect behind the emblem with the light. In the dark it looks very sick. The HD light is blue. I will post some pics soon.
issyz
Jul 2, 2017 03:04 PM
samansharif
Sep 25, 2015 12:31 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
