Nitrous Oxide Too soon, jr.
Kinetix V4 plenum with nitrous??
Old Jul 12, 2004 | 02:12 PM
Dth288's Avatar
Dth288
Default Kinetix V4 plenum with nitrous??
As said above, i have the kinetix V4 plenum and i'm thinking of going with 100 shot of nitrous (NX kit). what do you guys think about the V4 holding up?
i know this version was supposed to be built strong enough to handle it but i still have my doubts. It didnt look too strong if you ask me but then again i didnt see any of the other versions. opinions?
Just wondering what everything thinks... or if anyone has already done it.... Thanks!
David.
Old Jul 12, 2004 | 02:22 PM
ares's Avatar
ares
Veteran
does nitrous create any back pressure into the plenum like a turbo? if so, I wouldnt. its weak point is that it has no internal hold downs IMO. pressure could blow it open. but I think nitrous doesnt create any pressure outside the cylinder.
Old Jul 12, 2004 | 08:07 PM
MY350Z.COM's Avatar
moved
Old Jan 24, 2005 | 06:51 AM
titanjc's Avatar
titanjc
Bringing this one back, as I'd like to know the answer as well!!
Old Jan 24, 2005 | 06:54 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I haven't had any problems @ all.
Old Jan 24, 2005 | 08:14 AM
titanjc's Avatar
titanjc
Great, thanks for the input
How long have you been using the NX kit? And have you been at a 100 shot the entire time?
Old Jan 24, 2005 | 08:17 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
yes, 100 shot the whole time. I've had it for about 8 months I guess.
Old Jan 25, 2005 | 06:37 AM
g35irish's Avatar
g35irish
Nitrous does not pressurize the intake at all, so you should not experience any problems with a NOS system that is functioning normally. However, there are a few situations (or malfunctions) that can occur that create a "back fire" which rapidly pressurizes the manifold (there have been a few threads on this). When this occurs usually everything upstream of the throttle plate is blown apart. I wouldn't be afraid to use NOS with your intake, but you might want to read through the "back fire" threads to assure that you have addressed the issues associated with a NOS back fire.
Old Jan 25, 2005 | 12:33 PM
mrtomcat's Avatar
mrtomcat
backfire can ocour if you spray when not at wide open throttle.
Since the Z has drive by wire putting the wot switch underneach the gas pedal might not always mean it's at wot when it's depressed. You will need a TPS switch that splices directly into the TPS in your ecu to ensure that you truly only spray at wot.
NX has that switch
Also make sure you have a window switch
This should avoid the danger of backfire. These are must have's no matter what if you run n2o
Old Feb 11, 2005 | 09:33 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
There should be no additional stress as far as pressure goes, so that plenumshould hold up. It's always a good idea to run a metal planum anyway, but that's a whole different story IMO....
NissanZcrazy
Sep 23, 2015 07:59 AM
little_rod
May 31, 2004 09:07 AM
xlacrosse
May 11, 2004 02:25 PM
syf0n
Apr 8, 2004 01:02 PM
jakeup93
Mar 10, 2004 02:44 PM
