My Check Engine light came one. QQ
Old Sep 3, 2008 | 08:23 PM
Looks Fast's Avatar
Looks Fast
Default My Check Engine light came one. QQ
zOMG! Can't believe it turned on at 8000 miles. Time to get a GTR.
Old Sep 3, 2008 | 08:29 PM
rosscoe's Avatar
rosscoe
It could be you did'nt get the gas cap tight ,dont freak out man. Get it checked first. Autozone will read it for free.
deeznutz's Avatar
deeznutz
It's telling you to check the height of your car
I kid, I kid.
Old Sep 3, 2008 | 08:31 PM
Looks Fast's Avatar
Looks Fast
Haha.
Yeah, it is probably gas cap has a problem. Happened in my other car, not worried. Just means I gotta take it in.
Old Sep 3, 2008 | 10:17 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
You need new tires probly DK
Old Sep 3, 2008 | 10:26 PM
Looks Fast's Avatar
Looks Fast
Rotas?
Old Sep 3, 2008 | 10:32 PM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
Rotas?
no I meant tire tires! Like you're drifting them out too much. Needs new rubber for the Mayas
Old Sep 3, 2008 | 10:36 PM
Looks Fast's Avatar
Looks Fast
Ah yes, that is probably why my Engine light is on; it is trying to warn my that my tires are almost dead.
Old Sep 5, 2008 | 10:49 AM
Looks Fast's Avatar
Looks Fast
So I took it to Nissan of the Eastside, they did their diagnosis and said the Engine light came on due to the evaporator had a tubing leak because it was moved (due to Greddy Evo 2) and who did it apparently did a bad job because moving the evaporator is satanic or something (bitching because I didn't hire them); but they could make it right and fix it for me.
So I said, okay... then they said since they didn't install the exhaust, it is going to cost me $300 to fix the tubing. I said hell noes. They charged me $150 for the bloody diagnosis. Took it to CarNutz, lifted the car, the tubing was fine. Popped the battery for 10 min, plugged it back in and the light has been off ever since.
Nissan wanted $300 to pop the battery; the evaporator may have had a small leak for a sec, enough to pop the alarm; but other than that it was fine. I can't believe it.... $300.
Old Sep 5, 2008 | 10:52 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
^this is normal behavior from most dealerships.
Old Sep 5, 2008 | 11:03 AM
HaulinZ's Avatar
HaulinZ
dont go there for service! they are horrible
only go there for sales
Old Sep 5, 2008 | 11:29 AM
umsta's Avatar
umsta
they gotta get someone on the servicing fees cause most educated customers go somewhere else like indy shops.
Old Sep 5, 2008 | 11:35 AM
Looks Fast's Avatar
Looks Fast
Yeah, I learned my lesson.
Old Sep 6, 2008 | 08:57 AM
rosscoe's Avatar
rosscoe
Did they tell you the code that was set ,if it was a evap leak, that means there was a leak in the evap system [fuel vapor recovery to prevent raw fuel vapors from going to atmosphere] that is the same code set by a loose gas cap. placement of the evap canister is not an issue as long as there are no leaks. If the light comes back on I would be willing to help you with it I am an ASE master tech and have angood scanner to check it with. The light cant be reset by disconecting the battery,but will reset on its own once the problem is not there for a couple of self tests.
Old Sep 6, 2008 | 09:06 AM
SlowZster's Avatar
SlowZster
or you could be cool like me and just take the damn thing off...
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
