DIY wheel painting, flame inside!
Old Sep 19, 2008 | 08:10 AM
Entaille's Avatar
Entaille
Default DIY wheel painting, flame inside!
I haven't had my Z long at all and I've already dumped a good chunk of money into mods and upgrades (tint, plenum spacer, drop in filter, exhaust, spoiler..)
that being said, there is no affordable way to get some black 5 spoke wheels for a while, it's on hold for at least half a year (christmas, birthdays, anniversaries coming up etc..) but I feel like that will really complete the look I am going for.
I am going to risk it and paint my stock wheels black for the in between time. Hate it, call it ghetto, whatever.. I am doing it!
I live in an apartment complex, and I don't have jacks + jackstands, so this is going to be a one-by-one process with the stock jack. I might take an extended weekend to give it ample drying time. Here's my thought process on how to do this, if you have painting expierience feel free to correct my stupidity:
Pull one wheel off at a time, tape around the tire thoroughly/under the wheel lip so paint doesnt get on it, sand it down and make it as smooth as possible, spray duplicolor wheel paint on it, let it dry for a few hours, put it back on the car and pull the next one off and repeat the process.
I figure letting it dry for a few hours before going back on the car will be good enough so that it partially sets - then let it sit for the next 3-4 days undriven to let it really dry.
I've thought about other things that might be required, such as clearcoat, but I am really uneducated in the painting dept. any help is appreciated - or if you wheel snobs want to donate your volks/rays etc to me, that works too!
I am aware that it is likely to chip and that touch up will be required all too often to keep it looking decent, but this is a nice affordable way to tide me over until I can afford some real wheels.
Old Sep 19, 2008 | 08:17 AM
t0mills's Avatar
t0mills
1. Paint them Satin Black, instead of gloss black.
2. Prep work is key. Sand them down with 400 grit, then follow up with some 600. Clean them, and use an adhesion promoter before you spray them.
3. A good trick for taping around the tire is to use Index Cards. If you lay them in the bead, these will make a cone around the wheel.
4. If you paint them in the shade, then lay them out in the sun, you should only need about 15-20min before you can put them back on the car. I'd recommend at least 3 coats of paint. 1st coat pretty light, should only need about 5 min to set. 2nd coat should be heavier, give it about 10min in the sun, and the final coat should be heavy, but be careful so that it doesn't run.
5. Make sure you do this on a nice sunny day, with LOW humidity.
6. Post pics.
-Tim
Old Sep 19, 2008 | 08:25 AM
Entaille's Avatar
Entaille
index cards.. that is a good idea
I think duplicolor also makes an adehsion promoter (primer?), would that do the trick?
thanks for the advice.. helped tons already
Old Sep 19, 2008 | 08:31 AM
wasuber's Avatar
wasuber
If they turn out great maybe throw on some spacers ? I know a few members that rock the stockers and they look great pushed out a bit. Look even better black!
Old Sep 19, 2008 | 09:12 AM
Entaille's Avatar
Entaille
Probably doing this next weekend. I will definitely take pictures for you guys to laugh at my poor craftsmanship. I am trying to figure out what part of the apartment parking lot I am going to do the spraying at, I will line the entire area with cardboard but I can only imagine they would get pissy if they saw me doing it
Old Sep 19, 2008 | 09:29 AM
SlowZster's Avatar
SlowZster
no worries. Lots of people paint the stockers. My brother painted his stock Enkei wheels on his evo, and they looked amazing. It's all about doing it even, and taking your time.
Old Sep 19, 2008 | 09:33 AM
Entaille's Avatar
Entaille
cool deal. I was hoping this wasn't an incredibly stupid thing to do.
last thing I am confused on - should I get a clearcoat product to put on after the paint is dry?
Old Sep 19, 2008 | 10:05 AM
redlude97's Avatar
redlude97
I would use painter's tape rather than index cards, it is more time consuming, but you can get the paint closer to the tire bead. I would also avoid clearcoat, so that it is easier to repaint later down the road, because you WILL get chips, they are inevitable
Old Sep 19, 2008 | 11:43 AM
Entaille's Avatar
Entaille
I am looking into some affordable pro painters too before I do it - if its cheap enough I'll just have them do it, but I am thinking it's not. if it is too costly I'd rather put that money towards new wheels
Old Sep 19, 2008 | 11:49 AM
t0mills's Avatar
t0mills
They will use an automotive paint, and most likely clear coat it. That would look great, but it will be chipping off in a few weeks, so I wouldn't waste my money.
FYI, in my area, I can get wheels powdercoated for $25 each. So, for $100, you could have a finish that will last a long time, and look great.
-Tim
Old Sep 19, 2008 | 11:54 AM
Entaille's Avatar
Entaille
I'll ask what kind of paint they will use and whatnot. you are right, if they are just going to use auto paint its a waste of time and money.
Old Sep 19, 2008 | 12:07 PM
Entaille's Avatar
Entaille
powdercoating is more expensive in my area, and on top of that, I'd have to have my car on jackstands (which I don't have), pull the wheels off, go to a tire place, get the tires taken off, bring them the wheels, do without my car for a couple of days.. becomes pretty expensive after everything required =/
Old Sep 19, 2008 | 05:26 PM
SlowZster's Avatar
SlowZster
yeah, just rattle can it...no need for clear...and my brother just used tape. I think he did it on the car too if I remember right.
Old Sep 19, 2008 | 10:31 PM
Entaille's Avatar
Entaille
damn.. on the car, how did he manage that? how did he get the insides so it didn't look like total garbage?
Old Sep 20, 2008 | 10:35 AM
sno's Avatar
sno
Paint the back/inside of the rim first, then flip it over and lay a good 8 or so layers of paint on the fronts.
Obadabot
Jun 18, 2023 11:31 PM
