NorCal Autocross
Old Aug 21, 2011 | 02:44 PM
  #561
03threefiftyz's Avatar
03threefiftyz
The truechoice Koni's are more now.....
The phase 4 is $2995....not sure on the rest.
Old Aug 21, 2011 | 02:46 PM
  #562
03threefiftyz
Originally Posted by SE5spd
will E85 even make more power on a N/A Z?
A little bit, but you can run a butt load more timing in the midrange as well....more tq! It also makes the car run WAY cooler than standard gas. It's somewhat easy to get now in MD.
Old Aug 21, 2011 | 04:17 PM
  #563
SE5spd's Avatar
SE5spd
Yeah in CA there is E85 everywhere now, there's a station 5 miles from my house, all the EVOs around here run E85. If only they started doing E85 at tracks, even though I just use 100oct at track events.
Does anyone know what's better, a contour HD or GOPRO HD?
Old Aug 21, 2011 | 07:51 PM
  #564
scotts300's Avatar
scotts300
Originally Posted by Shamu Z
OS Giken fixed everything. Using their fluid now, little different tune, and had clutch discs coated with trick material to reduce friction. No issues now.
Molybdenum disilicide coating or other?
Theoretically, it should make a little more than a (my) 100 octane tune, use about 30% more fuel (needs bigger injectors), and run cooler. I just haven't put the wheels in motion yet, but I've been thinking about it and would love to do it. I need to get my 300 on E85, though the Q16 tune is pretty kickass, it's also $12/gal!
Old Aug 21, 2011 | 08:32 PM
  #565
SE5spd's Avatar
SE5spd
you're a MAD MAN!
my buddy is thinking of doing a E85 tune on his bolt on Z23TT, hopefully it'll make 400whp range.
Old Aug 22, 2011 | 07:26 AM
  #566
scotts300's Avatar
scotts300
you're a MAD MAN!
Sounds like stock turbos. It depends on what type and brand bolt-ons he has. Most stock-turbo'd Z32TTs run about 350rwhp with a 91 tune; some squeeze out a little more. He will need to upgrade to larger injectors to run more boost anyway, so he might as well go big enough if he plans to do the E85. My guess is that he will never do it, as it's not as common as it is on Evos and therefore a bit unknown, expensive, and risky.
I assume he knows that the fuel economy on E85 is terrible. My Z32TT gets 26-30mpg. . . while cruising.
Old Aug 22, 2011 | 08:08 AM
  #567
SE5spd's Avatar
SE5spd
Yeah he knows, he makes about 350whp. He keeps going back and further whether he wants E85 stock turbos or 91 octane on GT675Rs? I think that's what they're called.
Old Aug 23, 2011 | 02:15 PM
  #568
scotts300's Avatar
scotts300
Norcal UFO autox at Marina this Sunday. I should be there.
I will definitely be there on SATURDAY in a private event. If anyone is interested in going Saturday, make it known. You can not just show up and run on Saturday.
Old Aug 23, 2011 | 05:36 PM
  #569
03threefiftyz
You guys can have your earthquakes back....
Regards,
Maryland
Old Aug 23, 2011 | 09:07 PM
  #570
christoc's Avatar
christoc
I'll be in Lincoln Nebraska for Nationals the next two weekends, looking forward to getting my *** handed to me in E-Mod
Old Aug 23, 2011 | 09:14 PM
  #571
03threefiftyz
If you can stay within 6s per side of Jeff.....it was a good weekend IMO.
Old Aug 23, 2011 | 10:44 PM
  #572
SE5spd's Avatar
SE5spd
Regards,
Maryland
well one just happened so now you owe us one
3.9
Old Aug 24, 2011 | 10:06 AM
  #573
bdblackz's Avatar
bdblackz
There were a couple zs at SCCA autocross Sunday, you guys on here? I won STU class in tristans m3 and seriously considering buying one.... that car was fun!
Old Aug 24, 2011 | 10:45 AM
  #574
SE5spd's Avatar
SE5spd
E36 M3 are fun track toys. if you're small enough you should get into a Miata, now those are fun
Old Aug 25, 2011 | 08:22 AM
  #575
scotts300's Avatar
scotts300
Regards,
Maryland
Ha. We thought we'd share.
Old Aug 26, 2011 | 07:40 PM
  #576
SE5spd's Avatar
SE5spd
Old Aug 29, 2011 | 12:06 AM
  #577
scotts300's Avatar
scotts300
Good times this weekend, guys. I'll upload some pics and video soon.
Old Aug 29, 2011 | 10:10 PM
  #578
scotts300's Avatar
scotts300
A few pics from Saturday (still working on pics from Sunday). This is with the new TSW rotary forged wheels (18x10.5 +27) all around. They currently have 285 A6s on them, but I ran last month with 315 A6s in the rear without a problem.
I did a direct comparison with and without the wing on my 8th and 9th run (on street tires). Street tire times during fun runs (runs 6 through 9) were 50.0x, 50.0x, and 49.89x with the wing at its lowest AoA setting. I then raised the wing to its max setting, and netted a 49.1x with absolutely no other changes made. Hoosier times were high 47s.
Old Aug 30, 2011 | 12:02 AM
  #579
SE5spd's Avatar
SE5spd
I wish I had a Z CAR GARAGE banner too
Old Aug 30, 2011 | 05:52 AM
  #580
03threefiftyz
Downforce with drag is no worry in autocross.....I plan to go to a full 10" flat plane spoiler (think nascar) for next year.
