GTM Performance Engineering 370Z SUPERCHARGER KIT PRESS RELEASE
Old Mar 2, 2010 | 08:49 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Default GTM Performance Engineering 370Z SUPERCHARGER KIT PRESS RELEASE
We are please to announce the GTM supercharger system for the 370Z. Our GTM supercharger system will be utilizing the Rotrex C38 supercharger, The Key to the Rotrex supercharger is unique compactness, efficiency, low noise and reliability and its state of the art traction drive technology.
Great speeds and low noise are just some of the advantages of traction drives over traditional gear transmissions. Traction drives transmit power through friction forces between its rolling elements.
The Rotrex traction drive uses an elastic annulus with a small pre-span to secure contact between the roller planets and the sun shaft with a reasonable force. The patented "ramp effect" increases efficiency and reliability in the transmission by regulating the torque transfer capability on demand through self-adjusting planet geometry.
To enhance performance, the Rotrex traction drive uses a special traction fluid. These fluids are a new family of synthetic hydrocarbon oils and greases offering a series of unique performance advantages. Developed specially for its use in Rotrex superchargers, the SX100 momentarily increases viscosity under high surface pressure, enhancing the traction drive performance by securing the optimum friction between rolling elements while cooling and protecting the system.
This traction drive combined with the latest technology in centrifugal compression, characterized by high adiabatic efficiency and low noise, gives Rotrex superchargers an exceptional competitive edge over any other forced induction solution.
The GTM Supercharger kit will Have four different Rotrex compressors to chose from: C38-61 Trim,C38-71 trim, C38-81 trim,C38-91. Combined with our custom compressor housing we will offer three different stages .
Stage zero up to 450 HP (carb approval pending)
Stage one up to 500 HP
Stage two up to 525 HP
Stage three up to 550 HP
All of our Supercharger kits are available in two forms. The tuner kit form, so the professional and the end user have the flexibility of choosing what ever fuel and engine management they may desire and feel comfortable using. The second option being a complete kit including fuel and engine management solutions. With that being said, GTM will also offer an extensive range of fuel system and engine management modules to go with our Supercharger kits.
Below is a description of all the components of the kit :
-Rotrex C38 supercharger
-GTM compressor housing
-GTM Supercharger Billet aluminum brackets
-GTM billet aluminum Sc pulley
-GTM supercharger cooler kit
-Rotrex Supercharger Traction fluid
-4-Ply High Resistance Nomex Silicon couplers
-Stainless Steel T-Bolt clamps
-2.5 x 10 x 24 Bar and Plate Core Intercooler Rated @ 700hp
-Polished aluminum IC Piping
-GTM oil Filter Relocation Kit
-Cold Air Intake System (using k&n filters)
-Bosch Bypass valve
-Pre-made steel braided oil and P.S Supply & Return lines
-All Necessary Hardware and Installation Instructions
-GTM Custom mapped plug-in And play engine management for optimum engine tune and power .
-GTM Basic fuel system with Denso 600cc Injectors and - Walbro 255 Fuel Pump .
-GTM Custom Drive belt By Bando
-GTM Heavy duty Belt idlers
Some Key points about the GTM supercharger kit
After literally installing and tuning every supercharger kit available for the VQ platform and seeing their short comings, we got the inspiration to develop a kit superior to all others. Problems with the other kits that we wanted to address with our own include: not supplying a descent amount of power, belt breakage and slippage, obnoxious gear lash noises, limited power expansion and lack of the OEM look. Some of the key things we did to achieve our goal are:
SUPERCHARGER NOISE : We chose the Rotrex unit, a very QUIET supercharger compared to anything else on the market .
SUPERCHARGER BRACKETS : Our supercharger bracket is 3 dimensional made out of of thick billet aluminum to prevent any flexing, we also mounted the supercharger unit as close as possible to the engine to limit the amount of flex possible, as well as keep the belt length down between pulleys.
BELT AND TENSIONER DESIGN : We have over 80% belt wrap on our supercharger's pulley and with utilizing the factory automatic belt tensioner over or under tightening is simply not possible.
POWER EXPANSION : Changing the pulley on the super charger is less then 20 mints job
AESTHETICS : The GTM Supercharger kit maintain the clean oem look
ENGINE MANAGEMENT: With using the GTM flash we are to able to maintain the OEM drive ability so the car will run like stock, only with a lot more power .
POWER DELIVERY : The GTM supercharger is best bang for the Buck out of the box
Here is the pics of the GTM SUPERCHARGER KIT and some of its major components
Here is the pics of the GTM SUPERCHARGER KIT install process
HERE IS THE POWER OUTPUT OF STAGE 1 SUPERCHARGER KIT
Old Mar 2, 2010 | 08:50 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
VIDEO'S OF THE KIT IN
ACTION
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/ueIeB1YEjgc&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ueIeB1YEjgc&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/jpDwuKeZYdc&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/jpDwuKeZYdc&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/Zc9N9xF2h_s&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Zc9N9xF2h_s&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>]
PRICING
We are currently excepting pre-orders for a introductory Price of 4995.00 and for a limited time only .
Sam`
Old Mar 2, 2010 | 09:18 PM
EL Matador's Avatar
EL Matador
WOW...Clean Setup Guys!
Old Mar 2, 2010 | 10:02 PM
10-E-C-350Z's Avatar
10-E-C-350Z
Old Mar 3, 2010 | 06:38 AM
freedonutss's Avatar
freedonutss
Thats an AWESOME price!! Good work
Old Mar 3, 2010 | 07:38 AM
flecko28's Avatar
flecko28
O my, I am drooling all over the place
I have had my eye on Rotrex since they slapped them in the Caparo T1 I think it was called. I was hoping to retro fit one into my old car because they're smaller than most AC Compressors! I love your choice for the SC unit!!!
Makes me wish I had a 370Z, that's for sure.
Any chance a kit like this can be retro-fitted to fit us HR guys? Or a kit similar
(in price too!) to this for us HR guys??? I can dream, can't I?
BIG thumbs up to you guys for that kit AND that price!
Old Mar 3, 2010 | 08:14 AM
biggersNISMO's Avatar
biggersNISMO
^^^ check out the VQ35HR thread on this bro
Old Mar 3, 2010 | 08:55 AM
iceman21_23's Avatar
iceman21_23
one day i will have this for my 370z!
Old Mar 3, 2010 | 11:24 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
No need to dream it will happen
Sam
Old Mar 3, 2010 | 11:28 AM
BornSlippyZ's Avatar
BornSlippyZ
Great looking kit for the 370!
BTW Did you guys move from the hwy 15 location?
Old Mar 3, 2010 | 11:39 AM
flecko28's Avatar
flecko28
Sam
You, sir, have made my day! I did some searching...apparently an announcement about a kit for us HR guys is in the works for this week/month? I know that I am excited!
Keep up the good work!
TJ
Old Mar 3, 2010 | 02:43 PM
SatchScream's Avatar
SatchScream
Install looks very clean, very nice work.
Old Mar 3, 2010 | 04:03 PM
thatv35guy's Avatar
thatv35guy
Sam`
FFFUUUUUU...
That's an awesome deal!
Old Mar 4, 2010 | 07:02 AM
Quamen's Avatar
Quamen
That is one heck of a price! Nice work guys!
Other than the intercooler outlets and supercharger inlet ineffeciencies (due to design/space restrictions of course) this looks like one heck of a kit! Amazing workmanship as usual!
Old Mar 4, 2010 | 11:55 AM
duro78's Avatar
duro78
Wow that has to be 1 of the best looking kits from a quality standpoint and looks like it would cost a lot more than it does
Old Mar 4, 2010 | 12:03 PM
rcdash's Avatar
rcdash
Sam the kit looks awesome - great torque curve and outstanding bang for the buck. I was hoping someone else would've asked by now so I didn't have to risk being the thread idiot, but I cannot see the internal piping layout and curiosity has finally gotten the better of me :
Why do you need 2 air filters?
Old Mar 13, 2010 | 04:22 AM
Oleg's Avatar
Oleg
Wow... I am beyond myself with envy.
Any chance the DE guys may have something like this available, or are the new DE products pretty much over?
Old Mar 22, 2010 | 08:29 AM
SV1098's Avatar
SV1098
I'm ready for a kit for my HR..
