How-To Change Your Oil **WITH PICS**
Old Dec 11, 2008 | 12:37 PM
  #81
Bevo's Avatar
Bevo
Originally Posted by DrinkPremium
As for those who brings in their car for oil changes, is it $30 bucks for regular oil or synthetic? My DIY oil change cost me around $30 bucks (OEM nis filter & 5 Quarts of 5W-30 Mobil 1 Full Synthetic).
Correct me if I'm wrong, Last I remember synthetic oil change costs like $50-80 bucks?
I brought my own Mobil 1 5W-30 jug to dealer and have them change it. It only costs me $5 OEM filter + $10 lablr = $15
Old Dec 13, 2008 | 08:47 PM
  #82
350ZPK's Avatar
350ZPK
How many quarts does the HR motor take again?
Old Jan 5, 2009 | 06:52 PM
  #83
paposalsa's Avatar
paposalsa
Default Air Duct Template???
Delete comment!! Wrong posting!!!
Old Jan 5, 2009 | 08:36 PM
  #84
mclovin.too's Avatar
mclovin.too
Where are you finding jugs of mobil 5w30? No one here has them
Old Jan 12, 2009 | 08:47 PM
  #85
n8vz's Avatar
n8vz
Try Walmart
Old Jan 19, 2009 | 04:51 PM
  #86
candyman7's Avatar
candyman7
what oil and filter do you guys recommend
Old Jan 23, 2009 | 07:21 AM
  #87
Bevo's Avatar
Bevo
I use Mobil 1 5W-30 with Nissan OEM filter, so far so good.
Old Feb 1, 2009 | 09:11 PM
  #88
abeklipse's Avatar
abeklipse
My Z has always used non-synthetic oil in the past. On my next oil chance, if I was to switch over to synthetic, do I need to do something in particular before I pour in a different type of oil?
Old Feb 10, 2009 | 01:36 PM
  #89
Bevo's Avatar
Bevo
According Mobil1 website, just choose a shorter interval (3k miles) for the first time. Other than that, nothing you need to worry.
Old Feb 21, 2009 | 11:52 AM
  #90
mclovin.too
Mobil 1 5w30 with a K&N filter.
Old Mar 7, 2009 | 01:59 PM
  #91
Lug's Avatar
Lug
Thanks for the walk through. I found it really helpful today while changing my oil. I put in 5 qrts of castrol 0w-30 and a K&N filter.
Old Mar 24, 2009 | 10:25 AM
  #92
Tru_Religion's Avatar
Tru_Religion
Nice write up, i just did my first oil change
Old Mar 24, 2009 | 12:47 PM
  #93
Done Deal DR's Avatar
Done Deal DR
Originally Posted by AlvinHuyN
Can you do this without removing the diffuser? That seems so annoying if you have to remove it every time you change the oil lol. Ok ok I guess I'll stop being a lazy bum haha
I think it may be possible with a remote filter relocation kit...depending on where you were able to put it.
I won't say I haven't thought of trying it!
Old Aug 29, 2010 | 09:56 PM
  #94
350zx6r's Avatar
350zx6r
Originally Posted by jeffie7
lol I didn't know people used Fram filters on Z.
One thing to add, make sure you check the old oil filter to make sure it still has it's gasket on it. If not you'll double up the gaskets when installing the new oil filter. This makes for a nice oil leak.
The flat fram gaskets do this often!
So the new filter should have a gasket? is that right? and if theres one attached to the filter hook up I should remove it right? Because according to this quote you should NOT have 2 gaskets. Thanks.
Old Aug 30, 2010 | 05:33 AM
  #95
J. Dub's Avatar
J. Dub
Old Jul 7, 2011 | 12:36 PM
  #96
Z33Garage's Avatar
Z33Garage
RoyalPurple & Purolator Filters #1
Old Aug 8, 2011 | 07:51 PM
  #97
allshownogo's Avatar
allshownogo
OP, thanks for posting this DIY up. bought my 07 Z about a month ago with only 16k miles on the odo and that time came around to change the oil. the day i bought my Z, i lifted her up because there was too much oil (it was slightly above the top dot) and when looking underneath the car, im thinking "damn how do i get to the filter?" and having an 8th gen civic Si before, i thought space was tight on getting to the filter on that car. removing 14 bolts was def. fun. Oil change took me about 45 minutes, mostly from sitting around for 25 minutes to let most of the oil drain. and whoever put on the filter on placed on so damn tight that i had to jam it with a screw driver and remove.
but yes, informative DIY on the removing the black piece underneath the car!
Old Aug 8, 2011 | 07:54 PM
  #98
allshownogo
Originally Posted by dapperstu
My last Full Synthetic oil change was $58. I usually do my own, but changing oil when it's 20 degrees is no fun. Winter time oil changes are left to Valvoline.
better than changing oil in 95+ degree WITH humidity weather in florida
Old Apr 19, 2012 | 07:54 AM
  #99
ItsNOTaPurpleZ's Avatar
ItsNOTaPurpleZ
Originally Posted by vo7848
I've used fram filters for over 10 years now, and never had one single leak. Perhaps those doing the oil changes are forgeting to coat the new filter gasket with some oil before they screw it on.
On a different note, I've been brainstorming ways to modify the deflector shield so I can change the oil, in a clean manner, without removing it. My GF's Corolla had a similar problem. I was able to cut the plastic shield under her car with my dremmel. Oil changes are a breeze now. Of course with the Z it's a bit different, considering the deflector actually serves a purpose. I'd hate to compromise the intergrity of why the panel is there or even cut an open hole in it, allowing dirty street water to splash up and dirty my immaculate engine bay.
Any thoughts?
On that note you could make a panel kinda like we've got on our aircraft. Find a way to tack it on. When you're ready to do an oil change remove one of the bolts or whatever you choose to use and loosen the other one to where it's not fully off but will make it a pivot point so you can move the panel out of the way without losing it or completely removing it. Then when you're done close it up
Old May 21, 2013 | 11:41 AM
  #100
bullionz's Avatar
bullionz
Originally Posted by Sean
I guess if I was making this guide, it would just be a picture of me pulling into the dealership
or a picture of you throwing money into a fireplace...
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
