Shop Builds Temp moving posts for some clean up of this section.
taurran : "Testing new waters" with the Turbonetics ST
Old May 31, 2007 | 11:29 AM
  #201
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by Havok_RLS2
Hey MIA! Any word on the Watercooled bearing housing upgrade yet?
Not yet. I'm checking on it now...
  #202
failsafe306's Avatar
failsafe306
Originally Posted by MIAPLAYA
Typically a failed seal is recognizable by smoke after you are out of boost and back at idle. This is when the pressure inside the turbine and compressor housings fall and allow the seal to expand and send a bit of oil into them. If you are seeing black smoke under WOT its likely because of the 9:1 AFR you were running.
+1, black smoke = fuel
Old May 31, 2007 | 11:32 AM
  #203
Blu_Blur's Avatar
Blu_Blur
That is what I was hoping for, my very conservative tune mixed with straight through piping.
Thanks for alleviating my concern but I am still staying ever vigilant.
The turbo system is still at GT, is it easy to check the seals on these things and when checking the seals, is it possible than just by looking or inspecting them, that when the housing is put back together, that they could be reinstalled incorrectly leading to further problems.
I am thinking about asking GT to look into this prior to the install.
Old May 31, 2007 | 11:33 AM
  #204
Blu_Blur's Avatar
Blu_Blur
OK.
White smoke (with maybe bluish haze?)= Oil?
Old May 31, 2007 | 11:34 AM
  #205
priscilla ls1's Avatar
priscilla ls1
Originally Posted by taurran
If that's the case then Greddy should reimburse people for all the emanage blue's and blown motors that have been caused by them. Power enterprise should reimburse all of the people with cracked SS manifolds. APS should reimburse all the people that are buying external wastegates and forge actuators. Doesn't make much sense does it?
They did replace them all for free. Even payed for shipping. Been boosted twins for over a year and not one problem. I never cracked my SS manifolds and PE still sent me the cast iron upgrade for free!
Originally Posted by doug
its funny how the TN hierarchy is on this board.. its like big brothers and little brothers.. Craig and MIA are the big brothers.. and then you have the little brothers who follow them around and say stuff.. yeah.. get em craig..
lol.. hillarious
+1
Old May 31, 2007 | 12:22 PM
  #206
failsafe306
Originally Posted by Blu_Blur
OK.
Yup
Old May 31, 2007 | 01:44 PM
  #207
taurran's Avatar
taurran
Originally Posted by ILLBZNU
Taurran, You should really reconsider going the twin route. I am having my GTK 650 installed currently and it has been a very difficult install to say the least. I should have it completed and tunned with in the next couple weeks and I'll keep you posted. Function Tunned is doing a great job and all I have is good things to say about them. If you choose to still go with the ST and use the Turbonetics piping instead of the APS, good luck with the down pipe.
Yeah, it will be difficult to mount a normal GTK 650 on the kit piping becuase none of the flanges will match up. We're hoping to get around that easily.
Let us know how your setup works out, I'm interested in hearing how it performs. Good luck to you as well.
Old May 31, 2007 | 01:47 PM
  #208
taurran's Avatar
taurran
I know that some people got screwed and ended up paying for it (Cheston I beleieve). THey didn't reimburse you for the work involved in replacing them did they? I believe that's what Jetpilot was suggesting and I believe that's quite ludicrous...
Old May 31, 2007 | 02:02 PM
  #209
35ounces's Avatar
35ounces
03 CS Track 6MT
WERD! You are running 9:1 AFR?
Old May 31, 2007 | 02:06 PM
  #210
MIAPLAYA's Avatar
MIAPLAYA
Yup he was. He tuned it that way on a Emanage Ultimate.
Old May 31, 2007 | 03:25 PM
  #211
Blu_Blur's Avatar
Blu_Blur
Well, it wasn't 9:1, it was 9.6-9.8:1.
I wanted a conservative tune and yes I know about fouling plugs but if Sam at GT Motorsports didn't voice a concern then it should be fine.
My worst fear was blowing my motor due to detonation because I was detonating like mad before the EU tune.
Believe it or not but my 9.6:1 ratio worked incredibly well for me. When it gets reinstalled, I may lean it out a little.
Old May 31, 2007 | 04:16 PM
  #212
diwun67's Avatar
diwun67
Originally Posted by 636Racer
On the white smoke issue. My car was already blowing white smoke before the TN install. So it's has to be the rings. The TN kit never made it better or worse. Just saving money to get me that Cosworth shortblock.
White smoke is a blown head gasket, you're getting coolant in the combustion chamber.
Old May 31, 2007 | 05:19 PM
  #213
636Racer's Avatar
636Racer
Nah, did a dye test, and nothing found. Makes me think it's possible crapped out valve seal(s) or bad ring landing(s). No milkshake in the resvoir or hints of coolant smell coming from the exhaust either.
Old May 31, 2007 | 09:08 PM
  #215
JETPILOT's Avatar
JETPILOT
Wow.... like anyone knows what your talking about.... except me of course!
Is he back yet?
JET
Old Jun 1, 2007 | 03:50 AM
  #216
ILLBZNU's Avatar
ILLBZNU
Default Gtk650
It took over a year for my entire build mainly due to the first shop that I was dealing with going out of buisness while they had my car. Plus a ton of other issues that I won't go into. I should be able to post up some #'s fairly soon. Taurran, if your downpipe is already upgraded, you'll probably have alot easier time than me. The GTK 650 is still an extremely tight fit. Turbonetics makes an adaptor flange that makes it work. I am interested in who did your AC line and how much it ran you. It hasn't been easy for me to find a shop in my area that works with metric AC line.
Old Jun 1, 2007 | 04:52 AM
  #217
Audible Mayhem's Avatar
Audible Mayhem
My350z
Originally Posted by 98MODMTR
LOL @ Jeremy and the road trip to/from Georgia. Haha
honestly, that was the most i have laughed in one 18 hour long *** drive. craig and jason are some funny MARTA riding MFers!!
Old Jun 1, 2007 | 06:40 AM
  #218
MIAPLAYA's Avatar
MIAPLAYA
Craig had a local shop in Tampa do the line for him. I sincerely doubt they have a webpage but he might still have the number to their shop..
Old Jun 1, 2007 | 07:31 AM
  #220
RA11325's Avatar
RA11325
Sorry to here about this mang, but you had one heck of a run with the stock motor. Maybe I missed it, but how many miles were you boosted for?
