Shop Builds Temp moving posts for some clean up of this section.
taurran : "Testing new waters" with the Turbonetics ST
Old Oct 17, 2007 | 02:50 PM
  #781
taurran's Avatar
taurran
Originally Posted by Jay'Z
Obviously he doesnt want to share.. Its all good..
We will asap when everything is done. It hasn't even been shipped yet, and we need to verify it all works... Hopefully we'll have something to show soon.
Old Oct 18, 2007 | 03:12 AM
  #782
ILLBZNU's Avatar
ILLBZNU
I don't really think that my update was "off topic" I'm sorry it wasn't about your build, but I believe that I was also "testing the waters with the Turbonetics ST" I didn't really expect my turbo to be replaced, it just really sucks that I am our 1000 dollars due to their incompetence.
Originally Posted by taurran
Sorry to hear, but I don't think my thread is the best place to bring up these issues. I'm going to agree with Tengai here, but of course it's up to you.
Unfortunately providing a new turbo is the only reasonable thing they can do. Performance parts companies cannot make practice of refunding every dollar spent trying to get a part to work, even if it's a manufacturing issue, or else they'd be out of business real quick. It sucks, but that's the way the industry works.
I don't think you're going to make 500whp on the 60-1 because the turbo isn't sized for that kind of power. You'll probably see 450-470whp and a lot of torque.
That being said, I'd like to ask that the thread not get off topic. If you'd like to turn it into a Turbonetics bashing session, make another please.
Old Oct 18, 2007 | 05:38 AM
  #783
IIQuickSilverII's Avatar
IIQuickSilverII
+1
oh well at least you got things figured out... but i hope you keep the bigger turbo
Old Oct 18, 2007 | 06:09 AM
  #784
Julian@MRC's Avatar
Julian@MRC
Good luck making the power your looking for..thats gonna be one big a$$ turbo!!
Old Oct 18, 2007 | 06:46 AM
  #785
taurran's Avatar
taurran
Thanks, actually I'm hoping the spool characteristics won't be that much different than the previous setup. This time around we've taken into account of our power goal of 600+ with the utec and future goal of 700+whp on a stand alone EMS (most likely Haltech).
The new compressor will be big, but should also be resistant to surge on low boost under partial throttle.
I'll see if Jeremy can get some pics of the turbo this weekend.
Old Oct 18, 2007 | 06:54 AM
  #786
Julian@MRC's Avatar
Julian@MRC
It will spool up later.I notice going from twin GT25's on the APS standard to twin GT28's on their extreme kit, the car has lost that low end spool up, and makes full boost at 4500rpms whereas the older set up spooled at 3600.
Just off set the spool up with N2O
Old Oct 18, 2007 | 07:12 AM
  #787
taurran's Avatar
taurran
Sure, but I don't believe it will be THAT much of a difference. We didn't change the turbine side at all.
Unlike your example, we didn't swap out for an entirely new turbo. You're thinking of out-of-the-box turbo sizings while I'm on the level of actually sizing the individual components. We only went with a larger compressor side with a nicer housing so I'm hoping it'll make full boost around the same time that extreme kit does.
Old Oct 18, 2007 | 07:26 AM
  #788
MIAPLAYA's Avatar
MIAPLAYA
Craig is spot on with his assessment I think. The GT25 turbo uses a 53mm 62 trim turbine with a smaller compressor (46.5mm 60 trim) while the GT28 uses a 53.8 mm turbine with a 76 trim and a larger compressor (47.2 mm 62 trim). I would fully expect the GT28 to spool up slower as the turbine and compressor size both went up. Craig is not changing the turbine section at all on the new unit. He is simply moving up in compressor wheel and housing size to a 72mm compressor as opposed to the 66mm he was running. Bottom line the turbine section is identical to what he had before and the additional weight of moving up 6mm in the compressor side should have a negligible affect on his boost threshold. Additionally his last compressor did not have the Compressor Shroud porting his new compressor cover will have. That alone will widen the map and allow for some better air flow at lower boost pressure and prevent surging as it bypasses air past the inducer and allows air to flow directly to the major fins at lower boost and throttle positions. Short version: his spool up won't likely change enough to be noticeable if at all.
Old Oct 18, 2007 | 07:35 AM
  #789
Motormouth's Avatar
Motormouth
that is some interesting stuff, is the porting you are talking about the holes drilled into the inlet (venturi shaped cone off the middle of the intake side of the turbo? I wondered what that was for.
how does that close at higher boost or is it simply an effect of the airflow at that point?
Old Oct 18, 2007 | 10:24 AM
  #790
taurran's Avatar
taurran
They don't close. They simply improve flow at both low and high boost levels. At lower levels this give an "anti surge" effect, and at higher boost it facilitates increased air flow and allows the turbo to operate more efficiently. Hence the term "map enhancement porting".
Old Oct 18, 2007 | 01:27 PM
  #791
Motormouth's Avatar
Motormouth
that is a great idea, thanks for the details.
Old Oct 18, 2007 | 01:41 PM
  #792
escobar929's Avatar
escobar929
saw your car at PF last week, it looks sick!
cant wait to see how it does w/ the new turbo.
Old Oct 19, 2007 | 02:42 PM
  #793
taurran's Avatar
taurran
Thanks,
On another note - Jeremy just got the new turbo. I'm still waiting for pics.
Old Oct 19, 2007 | 03:19 PM
  #794
diwun67's Avatar
diwun67
giggidy!
Old Oct 19, 2007 | 03:21 PM
  #795
taurran's Avatar
taurran
Originally Posted by diwun67
giggidy!
...giggidy goo...
Trust me I'm wanting to see it too.
  #796
Zilvia's Avatar
Zilvia
Thanks,
aren't we all.....lol
Old Oct 19, 2007 | 04:25 PM
  #797
Julian@MRC's Avatar
Julian@MRC
pics please!!!
Old Oct 19, 2007 | 05:13 PM
  #798
MIAPLAYA's Avatar
MIAPLAYA
+1... Typically when you run a large compressor wheel at low boost pressure/mass flow rates the compressor will be at the surge limit. The ports in the compressor shroud (compressor inlet) allow air to bypass the inducer on the compressor and go directly to the major section on the compressor to prevent the compressor from surging on the low end. At the top end it allows more then just one inlet to the compressor wheel and widens the compressor map to allow more efficient air at various levels of boost pressure.
Old Oct 19, 2007 | 05:17 PM
  #799
buzzardmountain's Avatar
buzzardmountain
Craig...is your build the deciding factor on if TN does a stage 2 kit?
Can't wait to see pics.....
Old Oct 19, 2007 | 05:23 PM
  #800
taurran's Avatar
taurran
Nope, I don't think so. Mine will be a custom setup.
I'm heading up to Orlando tomorrow to check it out. Maybe I'll get something then.
