Shop Builds Temp moving posts for some clean up of this section.
PowerLab: Stage 5 Turbo Kit/ProEFI ECU/Intense 797WHP **Video**
Old Dec 8, 2007 | 07:43 PM
  #141
QuadCam's Avatar
QuadCam
does anyone know what software to use so that I can add the audio file from a supra dyno queen to the video of my G getting dynoed?
Seriously though....you guys need to post up some pics of this setup SOON!!!!
Old Dec 8, 2007 | 08:15 PM
  #142
DanielW's Avatar
DanielW
Originally Posted by IntenseFab
It's on a standard 6MT unsleeved, standard stroke motor
wouldn't this setup perform better on an automatic tranny?
Old Dec 8, 2007 | 08:29 PM
  #143
IntenseFab's Avatar
IntenseFab
Intense Motorsports
Not necessairly, Automatics just take the driver out of the equation, and turn it into a point and shoot setup more then anything else.
But there quite a few manual transmission supras/dsm's in the 8s, and even the 7s.. John Sheppard's DSM is piloted manually with a factory equipped transmission into the 7s at over 190 mph.
Old Dec 8, 2007 | 09:37 PM
  #144
DanielW's Avatar
DanielW
how would you keep the boost up between shifts?
Old Dec 8, 2007 | 10:35 PM
  #145
thawk408's Avatar
thawk408
Shift fast....
Old Dec 9, 2007 | 06:47 AM
  #146
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Have an EMS that features "flat shift" capability.
Old Dec 9, 2007 | 09:06 AM
  #147
DanielW's Avatar
DanielW
does the pro efi include that?
Old Dec 9, 2007 | 10:34 AM
  #148
rkd350z's Avatar
rkd350z
wow great. I gotta save up my money now..
Old Dec 9, 2007 | 11:17 AM
  #149
JRoC's Avatar
JRoC
Buh bye apsTT, hello 76s
Old Dec 9, 2007 | 11:44 AM
  #150
taurran's Avatar
taurran
Originally Posted by Audible Mayhem
wow, all done on a ACT 6 puck...
Old Dec 9, 2007 | 04:59 PM
  #151
taurran's Avatar
taurran
You can plainly see the dyno graph on the video posted in the OP. I know I've seen previous dyno sheets posted and the car has a 7.5k rpm redline.
Keep in mind the lines drawn on it are approximate...
Attached Thumbnails PowerLab: Stage 5 Turbo Kit/ProEFI ECU/Intense 797WHP **Video**-plstdyno.jpg
Old Dec 9, 2007 | 05:03 PM
  #152
IIQuickSilverII's Avatar
IIQuickSilverII
that was witha huge exhaust leak on the whole left bank....
basically that run in the video was with a 1.75L 3cyl engine
  #153
thawk408's Avatar
thawk408
That was also with the exhaust leak (and before VCT??). If it is spooling that 76 that slow then something is seriously wrong.
Old Dec 9, 2007 | 05:12 PM
  #154
Audible Mayhem's Avatar
Audible Mayhem
My350z
wow, 850+ on only 3 cylinders?? thats awesome...
Old Dec 9, 2007 | 05:13 PM
  #155
taurran's Avatar
taurran
Just posting whats on the video.
But, I very much doubt it would be making almost 800whp with only the use of 3 cyl. But fair enough, as I dont think a T-76 would make much difference anyway depending on the sizing of the other turbo components. The garrett GT37R has a 76mm compressor wheel anyway I believe.
I seriously hope it makes power much sooner than that. I'd be more worried about the stock sleeves failing any given moment at those power levels.
  #156
taurran's Avatar
taurran
Yeah, see above post.
Old Dec 9, 2007 | 05:26 PM
  #157
ForcefedZ's Avatar
ForcefedZ
Originally Posted by RudeG_v2.0
^Bingo.
The main issues are traction and whether the ACT 6-puck clutch will hold. We were still having problems on Friday with wheel spin with 3 guys on the trunk (myself included) and two others in the back seat. As IntenseFab stated, they intend to put the slicks on the car tomorrow and try again. If the clutch gives out and they decide to replace it, give them time (maybe a couple weeks) to order and receive a new carbon clutch that is up to the task.
I have an ACT 6 puck clutch in my car, and all mine will hold is about 630rwtq on the dyno. I think it's only rated at 580 torque (flywheel)
I'm sure the dyno sheets will come out once they have everything sorted out.
Old Dec 9, 2007 | 05:33 PM
  #158
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
I'm sure the dyno sheets will come out once they have everything is sorted out.
Exactly.
Old Dec 9, 2007 | 06:10 PM
  #159
BornSlippyZ's Avatar
BornSlippyZ
Nice...Just get that kit CARB Cert and you have a sale!
Old Dec 9, 2007 | 06:16 PM
  #160
taurran's Avatar
taurran
If you have an pre-turbo exhaust leak, and nearly an entire bank is not getting to the turbo, it's not that the turbo won't spool. it's that it will take it a hell of a lot longer to spool.
Manifold pressure is manifold pressure, if you measure 25 psi it's still going to make what 25 psi would make, but if you have a leak it's going to take longer to make the 25 psi.
Right, I think it was more laughing at the car running on "basically" 3 cyl. We all know that's not true. Yeah, I'm interested in seeing how quickly the present turbo setup's power peaks. I'd imagine it would be no later than 5500rpms...
