Shop Builds Temp moving posts for some clean up of this section.
RMS Time attack Build Super charged
Old Mar 16, 2009 | 02:05 PM
RevengeM.S.'s Avatar
RevengeM.S.
Default RMS Time attack Build Super charged
Revenge Motorsports sponsored Time attack Z (modified class)
-Vortech tuner kit modified for this application -6psi pulley
-Engine RMS race block, RMS ported cylinder heads + intake manifold and TB, wiseco pistons 11.2-1 comp., eagle rods, ARP hardware, BC stainless valves, JWT cams and springs, APS oil pan, cometic gaskets, 2qt accu sump, setrab oil cooler, PWR radiator/RMS dual fan kit, RMS combined breather and coolant tank.
-Fuel system AAM fuel rails, RC 750cc injectors, return fuel system, Jazz pro fuel cell, Aeromotive A1000 fuel pump/filter/regulator, AN fittings and lines, UTEC ecu.
-Suspension Tein flex/EDFC, Nismo front bushings, SPL diff. bushing, RMS roll cage, 350evo sway bars + heim joint end links, front camber a-arms.
-Brakes Stop tech 2 piece rotors+lines, porter field pads, soon to upgrade PMU BBK.
-Exhaust DC headers, RMS strait pipes and dual 3" exhaust coming soon.
-Drivetrain RMS fortified transmission, Nismo GTpro diff. and final drive, JWT clutch and flywheel, RMS Diff. cooler + tilton pump remote mount.
-Interior Sparco seats and harness, AEM guages /wideband/oil temp./pressure.
Anyways well keep adding pics of the build as it gets finished and dyno tune to come this week.
Attached Thumbnails RMS Time attack Build  Super charged-dscn2513.jpg   RMS Time attack Build  Super charged-dscn2516.jpg   RMS Time attack Build  Super charged-dscn2536.jpg   RMS Time attack Build  Super charged-sckit.jpg   RMS Time attack Build  Super charged-rails.jpg
Old Mar 16, 2009 | 02:08 PM
RevengeM.S.
Pic#1 PWR radiator & RMS fan shroud + FAL fans
Pic#2 FM inter cooler (spearco) included with kit
Pic#3 new spot for the blow off/surge valve
Pic#4 all the parts that are being removed
Pic#5 AAM fuel system some parts will not be used changing the parts we dont like
Attached Thumbnails RMS Time attack Build  Super charged-radiator.jpg   RMS Time attack Build  Super charged-dscn2541.jpg   RMS Time attack Build  Super charged-dscn2543.jpg   RMS Time attack Build  Super charged-the-tear-down.jpg   RMS Time attack Build  Super charged-fuel-system.jpg
Old Mar 16, 2009 | 02:13 PM
350z-900whp's Avatar
350z-900whp
very nice setup and clean
i think you should consider these headers with u big setup over DC but thats just me
link
https://my350z.com/forum/na-builds/3...oadster-5.html
Old Mar 16, 2009 | 02:19 PM
RevengeM.S.
Thanks. We will be changing a few things along the way as we see necessary.
Pic#1&2 dual duty coolant tank and crank case breather
Pic#3 intake for SC
Pic#4 fuel cell and pump unit
Pic#5 2qt accu sump where the old gas was mounted
Attached Thumbnails RMS Time attack Build  Super charged-tank2.jpg   RMS Time attack Build  Super charged-tank.jpg   RMS Time attack Build  Super charged-intake.jpg   RMS Time attack Build  Super charged-cell.jpg   RMS Time attack Build  Super charged-accu.jpg
Old Mar 16, 2009 | 02:33 PM
IIQuickSilverII's Avatar
IIQuickSilverII
new guys...1 post...pics+backup....clears all doubt.... RA 2 years... just moon dynos and countless of excuses
Props for a nice setup OP
Old Mar 16, 2009 | 03:11 PM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
AHAHAH agreed... Props to the OP and looking forward to the end results.
Old Mar 25, 2009 | 08:46 AM
RevengeM.S.
Default Update
New pictures and parts
-HKS F-con IS for our tuning enjoyment (we are hks pro-tuner certified)
-Fire suppression system
-Flared rear fenders to cover the 315-30-18 Yokohama's
Attached Thumbnails RMS Time attack Build  Super charged-fire-bottle.jpg   RMS Time attack Build  Super charged-firebottle2.jpg
Old Mar 25, 2009 | 08:49 AM
Motormouth's Avatar
Motormouth
so why a vortech?
Old Mar 25, 2009 | 11:11 AM
RevengeM.S.
Linear power band.
Old Mar 25, 2009 | 11:47 AM
MaRbLe's Avatar
MaRbLe
Autopower roll bar?
Old Mar 25, 2009 | 12:10 PM
RevengeM.S.
Originally Posted by MaRbLe
Autopower roll bar?
Custom RMS bolt in 4 point 1 3/4 DOM steel.
Old Mar 25, 2009 | 12:20 PM
iStan's Avatar
iStan
ZR
Any particular reason the BPV was relocated right next to the outlet of the blower?
Also- Price for Intake Shipped please
Old Mar 25, 2009 | 06:14 PM
DanielW's Avatar
DanielW
so what power levels are you shooting for?
Old Mar 25, 2009 | 08:19 PM
RevengeM.S.
To keep the dirt out of it, the stock kit has by the tire and it did not fit on our setup with the bigger radiator.
You may have to do some trimming to get it to fit but not much PM me.
Old Mar 25, 2009 | 08:21 PM
RevengeM.S.
We are going for a conservative tune its more for an mid to top end power gain estimate 450-475 whp. (road race)
Old Mar 25, 2009 | 08:32 PM
RevengeM.S.
Thanks we try.
Old Mar 26, 2009 | 02:59 AM
Quamen's Avatar
Quamen
Good luck. Even with the higher compression that number will be near if not impossible on a 6psi pulley. Especially on a conservative tune.
Old Mar 26, 2009 | 04:38 AM
RandomHer0's Avatar
RandomHer0
Nice, is that coolant tank one-off?
Old Mar 26, 2009 | 04:42 AM
Jeremy@Altered's Avatar
Jeremy@Altered
i agree with Quamen, those numbers wont be reachable with only a 6psi pulley. i would go with the 2.87 pulley and a little higher octane if needed.
Old Mar 26, 2009 | 05:09 AM
midz350's Avatar
midz350
Great work.
Nice to see a new shop here with new ideas.
