Installing LED tail lights easy enough?
Old May 13, 2006 | 06:31 PM
Mr_Q's Avatar
Mr_Q
Default Installing LED tail lights easy enough?
I've got my car at Mobworks right now getting a kit installed and I was wondering if it's worth another long a$$ drive out there to let them install my '06 LED tail lights.
Or is it something I can do with a screwdriver?
Thanks!
Old May 13, 2006 | 06:36 PM
Hella's Avatar
Hella
Dude.....you can do it. its super easy.
pop out the little covers.....unscrew bolts....remove old lights....put in new lights......tighten bolts......replace little caps. done.
literally took me like 7 minutes.
Old May 13, 2006 | 06:40 PM
3FITTTY's Avatar
3FITTTY
very easy to do your self!
Old May 14, 2006 | 01:57 AM
Mr_Q's Avatar
Mr_Q
HAHHAHA...okay..thanks.
Old May 14, 2006 | 02:04 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
VERY easy. Don't let them charge you crazy labor cost when you can do it in less than 10 mins.
Old May 14, 2006 | 05:33 AM
sluggoZ's Avatar
sluggoZ
Thanks!
Here ya go...
1. open the trunk.
2. 3 tabs on top of the tail light, pop off w/screwdriver, take your time, it can be tricky.
3. use 10mm wrench on the 3 bolts on each tail lamp.
4. when pulling out old lamps...stand to the side of the rear wheel and
pull towards you FIRMLY. Hold on tightly because when it comes out.....it really pops up very hard & it might fall out of your hands. By doing this you won't break off the 2 pegs on the retainer clips.
5. un-clip the harness
6. there are 2 harness plugs. One is a light that is always running and the other changes brightness. The smalller harness (only for the always running light) is not used with the LED tail light. You only hook up one and just cover w/tape & clip the other onto something.
7. that's it!!
Good Luck!
Old Feb 14, 2011 | 07:35 PM
bishop_98's Avatar
bishop_98
I was freaking out, then i noticed theres an adapter piece that comes off as well. Thanks, all.
Old Feb 14, 2011 | 07:49 PM
BoomerZ33's Avatar
BoomerZ33
damnn what a bump. yea dude no need to freak out. this is as simple as upgrading to a shorty antenna
Old Feb 14, 2011 | 07:56 PM
Arvin89's Avatar
Arvin89
Originally Posted by sluggoZ
Here ya go...
1. open the trunk.
7. that's it!!
Good Luck!
YOU FORGOT STEP 8!!!!
8. PUT EVERYTHING BACK THE WAY IT CAME OUT!
Goodluck
Old Feb 14, 2011 | 07:57 PM
Arvin89's Avatar
Arvin89
Hey.. that was not easy for me... i was using the wrong adapter screw hahaha. Stupid packaging.. the right one fell out on the floor when i opened the pack.
Old Feb 15, 2011 | 07:35 PM
NismoZZ's Avatar
NismoZZ
https://my350z.com/forum/body-interi...aillights.html
here you go with some pics
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
samansharif
Sep 25, 2015 12:31 PM
