Power Steering Fluid
Old 06-19-2011, 02:05 AM
sometimesjoey
sometimesjoey's Avatar
Default Power Steering Fluid
Hi all.
I understand that you can use ATF for the power steering, as that is what the cap states. But does it matter which dexron atf you use? Would dexron vi be safe to use? which power steering fluid would you recommend? Any help is appreciated, thank you.
Old 06-19-2011, 04:54 AM
Mint Racer
Mint Racer's Avatar
dexron III/ mercon, or equivalent which mean VI will be fine
Old 06-19-2011, 04:59 AM
RandomHer0
RandomHer0's Avatar
What year vehicle do you have?
2003-2006 require DexIII
I've used Mobil1 in the past but it seems their newer formulas are no longer Dexron certified.
Use; http://www.amsoil.com/StoreFront/atf.aspx
Old 06-19-2011, 06:20 AM
zheiland
zheiland's Avatar
Default Amsoil ATF synetic
Hey,I use Amsoil syn ATF for
my power steering fluid.Well,if you are at a standstill and turn your steer wheel from side to side while the car is on with the
stock fluid I hear the pump kind
of makes a whine noise.When I changed over to Amsoil syn ATF the noise went away and the steering felt better.Also this fluid
has one of the lowest pour temp as well as one of the highest temp point.The guys on the oil
rigs up here use it on all hydraulics for a reason.
Old 06-19-2011, 08:34 AM
sometimesjoey
It's a 2007.
Old 06-19-2011, 09:35 AM
Mint Racer
Mint Racer's Avatar
since dexron III is no longer made, VI has taken its place. they are both hydraulic fluid, VI has more additives for smoother shifts, better temp control, longevity, etc.. it is just an improved formula and will be fine.
Old 03-17-2012, 05:57 PM
mw9
mw9's Avatar
Anyone try Motul power steering fluid?
Old 04-09-2012, 12:45 PM
sanbaifo
sanbaifo's Avatar
Do you have to remove all of the current fluid before you add the Amsoil ATF?
Or can you just remove what is in the reseriour and fill it?
Old 04-12-2012, 11:57 AM
zheiland
zheiland's Avatar
I would drain all the existing fluid.
Old 03-24-2019, 07:14 PM
noobie_1337
noobie_1337's Avatar
Old thread bump, but just to make sure since i'll be replacing my PS fluid soon on my 05, any of these should be fine correct?
Red Line RED30704 D6 Automatic Transmission Fluid Red Line RED30704 D6 Automatic Transmission Fluid
Royal Purple 01320 Max Automatic Transmission Fluid Royal Purple 01320 Max Automatic Transmission Fluid
Mobil 103529 Dexron-VI Automatic Transmission Fluid Mobil 103529 Dexron-VI Automatic Transmission Fluid
Mobil 1 112980 Synthetic Automatic Transmission Fluid Mobil 1 112980 Synthetic Automatic Transmission Fluid
Old 03-30-2019, 07:29 PM
noobie_1337
anyone?
Old 04-25-2019, 02:41 PM
Desert Z
Desert Z's Avatar
I use Redline synthetic on all 3 of my VQ cars, specially on the 350z where I heat up the fluid form autocrossing.
lapham3
10-07-2022 03:15 PM
MM'08_350Z
04-22-2021 09:42 PM
Depravity
10-01-2015 04:49 PM
Quick Reply: Power Steering Fluid
