2007 350Z convertible outside door handle removal
How do you remove the door handle on a convertible 350z? I only see one rubber grommet. The 350Z coupe has two rubber grommets with 10 mm bolts behind them, the convertible has one. Please help!!
Finding the second one is the challenge. On the convertibles there is only 1 rubber grommet for one of the screws.. there is a steel door guide where the top grommet should be.. I think I have to remove the door guide to get to my top bolt. Thanks for the reply.
jhc (03-25-2019)
One bolt is already at the bottom of my door.. will try the painters tape since there are not any stores near me that carry magnetic nutt setters...
GOHeels!!!
I'm tried and true
I blead Carolina Blue
GOHeels!!!
I'm tried and true
I need same info. All videos show the coupe versions. I think need to remove 3 torx screws holding alignment pin to get to upper handle mount bolt. Can anyone verify?
General & Tech Moderator
scmtkings4
11-06-2016 07:43 PM
