Nitrous Oxide Too soon, jr.
Zex Wet Sys - 2004 DE Comments and Questions
Old 11-13-2018, 03:03 PM
BGrieb
BGrieb's Avatar
Default Zex Wet Sys - 2004 DE Comments and Questions
Okay, so I've determined from the forum that I can install the Zex wet system in my stock DE, go to a colder plug, let the ECU handle the retarded timing up to a 100 shot and not worry about detonation. Can I use a progressive controller? Any other comments or suggestions? Thanks in advance.
Correction: For the 100 Shot - The Zex Wet Kit Part Number 82220 calls for 92 Octane fuel or higher, Two-step colder plugs and a tune.
Last edited by BGrieb; 01-30-2019 at 02:36 PM. Reason: Cprrection to above statement
Old 11-13-2018, 05:46 PM
onevq35de
onevq35de's Avatar
Must you go to a colder plug for a 100 shot?
Old 11-13-2018, 06:47 PM
BGrieb
BGrieb's Avatar
Yes, Zex installation instructions say one step colder plugs for the kit...and besides, that's easy. Some say a two step colder plug for a 100 shot but I'm not sure about that.
Old 11-13-2018, 07:03 PM
onevq35de
onevq35de's Avatar
The plugs might foul out quickly if it's a daily driver with limited N20 use. I'd think the stock heat range would be fine for the occasional 100 shot.
Old 01-19-2019, 11:20 PM
LateSpoolZ
LateSpoolZ's Avatar
Im on a 75 shot with 1 step colder plugs, was thinking of going with the 100 shot and use HR plugs, thats what i read most people do.
Did you do it or not ?
Old 01-20-2019, 05:23 AM
BGrieb
BGrieb's Avatar
I have not installed the kit yet but thank you for your info. I have heard from several folks that you can get by with just the one step colder plugs up to the 75 shot. Thank you for confirming that info. The big question is, what does it take to use the 100 shot. I intend to go two step colder plugs and add or fill the tank with 100 unleaded octane fuel. I have not discovered a way to retard the timing through a factory ECU. It would take a $2000 Haltech ECU to be able to tune the timing and that's too expensive for my setup. One option is to install the $400 Innovate PSN-1 gauge and watch the Air/Fuel ratio during testing. I hope to install the kit in March for the late April race season. I'll update as it comes together. Keep the ideas coming!
Nick Pieroni (02-02-2020)
Old 01-30-2019, 01:08 PM
BGrieb
BGrieb's Avatar
I'm not sure what HR plugs are (standard plugs for the HR engine?) but my research shows that the two-step colder plug for my DE is NGK 2309 (LFR7AIX) Iridium plugs. They have the same size, pitch, reach and the "7" means it's two steps colder than the standard NGK 6240 (PLFR5A-11) Laser Platinum. The one-step colder NGK plug being the NGK 7654 (PLFR6A-11) Laser Platinum.
Old 04-09-2019, 11:59 AM
BGrieb
BGrieb's Avatar
Below are the plugs for the DE engine (2003-2006)
Standard: NGK 6240 (PLFR5A-11)
One Step Colder: NGK 7654 (PLFR6A-11) The "6" denotes one step colder
Two Step Colder: NGK 2309 (LFR7AIX) These have the same thread, pitch and reach as the standard PLFR5A-11 but the "7" denotes two-step colder.
Old 05-21-2019, 12:28 PM
350zderder
350zderder's Avatar
Default 100 shots use
Stock ecu retard ignition but you need this soup for best result
Old 05-21-2019, 12:29 PM
350zderder
350zderder's Avatar
Default 100 shots use pics
Old 05-21-2019, 12:33 PM
350zderder
350zderder's Avatar
Dont forget buy window switch
PEQUES
Nitrous Oxide
09-18-2009 03:43 PM
StreetOC192
07-22-2008 05:01 AM
Old School
Nitrous Oxide
26
11-22-2006 07:29 AM
spdu4ia
Nitrous Oxide
24
05-25-2005 06:24 PM
damien
11-07-2003 05:09 PM
Quick Reply: Zex Wet Sys - 2004 DE Comments and Questions
