JWT TT Install in my '05 G35
Old Nov 23, 2006 | 10:16 AM
  #41
myspivey's Avatar
myspivey
And Nick does a real good and safe job tuning. Just got back from having them tune my UTEC on my N/A Z and as always nick did a real good job, with real good gaines on a safe tune. With pretty much no other mods i was impressed to see what the Z could put out on an almost stock car. Numbers are in my signature if your wondering.
Old Nov 23, 2006 | 01:13 PM
  #42
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Yes, he does. I'm pretty impressed with Bill and Nick and MACAutosports
Old Jan 27, 2007 | 01:42 PM
  #43
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by Dave 90TT
Probably got another 10-15 hp in there at the same boost, but the injectors are almost maxed out. I'll need to go with bigger injectors, a higher flow fuel pump, and a boost controller next, and then, I would need to start building the engine, which I am not sure I am going to do.
Dave
So do you suggest to buy the injectors before doing the install? Also what injectors do you suggest? Doesn't the kit come w/ a new Walbro fuel pump. Thanks for the info!!!
Old Jan 27, 2007 | 03:13 PM
  #44
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
It does come with the walbro, and will work at stock boost, but if you are going to do injectors at some future point anyways, it makes sense to do it at the same time as the turbo kit. Install is cheaper since the ngine is apart, and since you will need to tune for the new injectors, might as well do the tune then as wel. Set of injectors (550's) is only about $500-600, depending on the brand.
Old Jan 27, 2007 | 03:23 PM
  #45
Robert_K's Avatar
Robert_K
Didn't Go Cheap
So go ahead and grab injectors and a larger Walbro than? Also, talk to Bill about a EBC that can be control by the UTEC as well. Looking to have a 6psi daily map and a 8psi aggressive map.
Old Jan 28, 2007 | 04:53 PM
  #46
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Well, yes, depending on your budget and your future plans., If nothing else, the larger injectors will add in a good margin of safety.
The UTEC, with version 2.8, can control a solenoid boost controller. From what I understand it won't be as good as some of the expensive boost controllers (HKS EVC, etc...) but should be more than enough for you or my needs.
Dave
Old Jan 28, 2007 | 06:34 PM
  #47
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well Bill mention a way for the UTEC to control boost through an EBC. Don't know have to get more details about it. Also I think I will get those injectors. Kinda want to do everything at once. Don't want to go back the the little here & theres later on.
Old Jan 28, 2007 | 07:30 PM
  #48
Juztin's Avatar
Juztin
Last I heard UTEC with GM boost solenoid was working from some of the guys w/ 2.8 software
Old Jan 28, 2007 | 07:53 PM
  #49
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Yep, thats what I was talking about.
Also, if you are going to do everything at once and get injectors, you might want to look into a fuel return system. AAM makes one, but I'm told there can be some gas smell from their's, while the CJ Motorsports one is better. Don't know firsthand, just what I have read on the forums.
Again, though, it's all budget dependant...
Old Jan 29, 2007 | 03:58 AM
  #50
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Yeah... Budget is the key. lol We'll see. Trying to get all the info now.
Old Jan 29, 2007 | 09:17 AM
  #51
Starchecker's Avatar
Starchecker
Alright, looks like Robert's back on the TT bandwagon!
Old Jan 29, 2007 | 06:14 PM
  #52
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
I hope so! he'll love it, the power is great!
Dave
Old Jan 31, 2007 | 04:38 AM
  #53
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I truely never left. I just keep ALL my options open.
