UR Pulley install HElp!
Old May 11, 2006 | 06:18 PM
Cannysage's Avatar
Cannysage
Default UR Pulley install HElp!
I've been defeated by the stock, crank pulley bolt that's stuck. I have angled and 10" extension for my ratchet wrench but still wouldn't budget. I'll give it another go sat morning but it seems hopeless anybody wanna give me a hand this sat, if I'm unable to take it out? Also, they only sent 1 belt (thicker one). would the other (stock) one fit?
Old May 11, 2006 | 06:38 PM
Cannysage's Avatar
Cannysage
oh yeah, there's the stillen meet this sat. maybe after? I'll bring my tools to the meet, just in case.
Old May 11, 2006 | 08:10 PM
ecorona6's Avatar
ecorona6
Hey Canny...That bolt is a bit rude to say the least! What I did was use a 1/2 ratchet with a long extension. I fought with it for 5 minutes and decided to use a hollow metal pipe (2' long) for additional torque. The bolt unfastened with ease after using that pipe. ......Just remember to place your gear to 6th and have someone step on the brake while your loosening the bolt. Otherwise the crank seems to turn with the bolt and you end up with negative results.
To bad I am heading off to Wennie Roast on Sat. otherwise I would have been there to help you out. Good Luck.
-Edgar
Old May 11, 2006 | 08:19 PM
al503's Avatar
al503
I got an 18" breaker bar from Sears. It was the longest they had and I wish they had at least a 2'. Anyway, I was able to get the bolt off with the 18" but it took me pretty much everything I had (pushing against my ramps and front wheels with my feet, with my hands braced between my waist and thigh and basically doing a squat for all I was worth.) Long story short, I wouldn't try it without anything shorter than an 18" to a 2' breaker bar.
Old May 11, 2006 | 08:27 PM
Alberto's Avatar
Alberto
Cranky FI Owner
This is easy. Get the breaker bar or 1/2 ratchet(prefferably brealer bar) with an extension on the crank pulley bolt, set it at the 5 o'clock position touching the ground. Now turn the engine over by barely cranking the starter-DO NOT start the car. Give the starter 2 blips and the bolt will be loose. I have done 2 CP installs like this, its painless, it works, you'll be done in 30 minutes
Old May 11, 2006 | 08:35 PM
350Zteve's Avatar
350Zteve
This way works well. You should really use a breaker bar though. A ratchet is more likely to break.
Old May 11, 2006 | 08:39 PM
ecorona6's Avatar
ecorona6
Oh..I forgot to mention. You will need two belts. When I bought my betls from Stillen it came with two SMALLER belts due to the smaller diameter crank pulley. The stock belt will not fit!
Old May 11, 2006 | 09:42 PM
Cannysage's Avatar
Cannysage
thanks for all the input. I nearly **** my pants trying to get that thing loose. why the hell wasn't I sent 2 belts? that's what I need to know I had a pipe and it didn't fit over my rachet.. dunno if breaker bars would give me enough torque.. doh... I try some stuff mentioned above, after I purchase a belt somewhere. alberto's technique seems a bit scary, but I'll be trying anything to get that sucker off.
Old May 11, 2006 | 09:51 PM
Cannysage's Avatar
Cannysage
hmmm I wonder if Stillen would have the belt in stock. somebody told me the other belt would fit.. maybe it'll be too loose and start sqeaking?
Old May 12, 2006 | 11:04 AM
LaPuLaPu's Avatar
LaPuLaPu
Albert,
How did you stabilize the socket from loosening and perhaps stripping the bolt? Even worst, is there a remote chance that the socket/breaker bar flying out and damaging the radiator?
Old May 12, 2006 | 11:49 AM
ecorona6's Avatar
ecorona6
Originally Posted by LaPuLaPu
Albert,
Alberto's method has been used by many...you secure the socket/breaker bar to the floor which has very little play. If done right your chances of striping the bolt or having things fly around is very slim.
Old May 12, 2006 | 03:51 PM
Cannysage's Avatar
Cannysage
shiat.. just bought a breaker bar and the wheels (in the sky) keeps on turning. I have an 5at, how do I stabilize that shizzle?
Old May 12, 2006 | 08:32 PM
LaPuLaPu's Avatar
LaPuLaPu
Do you have it like such?
Old May 12, 2006 | 10:21 PM
Cannysage's Avatar
Cannysage
yeah.. have it exactly like that.. how do I keep the crank wheel from turning?
It's a 5at, so I can't put it in gear and step on the brakes.
Old May 12, 2006 | 11:04 PM
LaPuLaPu's Avatar
LaPuLaPu
you're suppost to crank the engine, BUT dont start it. DONT START THE ENGINE.
Old May 12, 2006 | 11:17 PM
LaPuLaPu's Avatar
LaPuLaPu
http://www.350zmotoring.com/forums/s...ad.php?t=38419
Old May 13, 2006 | 04:28 PM
Cannysage's Avatar
Cannysage
dooods.. got the bolt off but can't get the crank pulley off.. I'm desperate, HELP! I have to go to work tomorrow and gotta drive down san diego tonight.. gotta get it all back together any ideas?
Old May 13, 2006 | 05:04 PM
___DJK___'s Avatar
___DJK___
lolz, im glad I didn't try to install this myself...$130 seems like a bargain compared to this hassle.
Old May 14, 2006 | 08:22 AM
LaPuLaPu's Avatar
LaPuLaPu
You can go to Autozone and borrow crank pulley puller.
Fixxxercask
Nov 9, 2015 11:10 AM
