more questions about utec...
Old Jun 14, 2008 | 03:48 AM
  #221
SchismX's Avatar
SchismX
EDIT: Nevermind, I answered my own question. What is the difference between the Bosch sensor and VW sensor? Also what is a good switched 12v power source to use? Sorry, not a wiz in the electronics field.
Old Jun 14, 2008 | 09:33 AM
  #222
mw9's Avatar
mw9
starting tuning with the UTEC and tuner today. A few questions maybe you guys could help me out with.
1. when changing fuel map I have been just changing across the board. 0-100%
Do you guys play around with changing them individually?
2. The timing I haven't really messed with, just the base map from TurboXS.
Do you mess with the timing that much unless you are on a dyno?
If anyone has them can you post you maps, just for a reference. I am figuring out as I go. thanks for all the help
Old Jun 14, 2008 | 11:25 AM
  #223
HP 350Z's Avatar
HP 350Z
Question
if i have the current software version of the utec . how can i reset the utec where everything is blank on it ???
if anyone knows please pm me thanks
Old Jun 18, 2008 | 03:48 PM
  #224
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Just follow the instructions in the manual, for reloading/updating firmware. This will turn your UTEC into it's brand new condition. It won't be blank, but it will be factory fresh.
Old Jun 18, 2008 | 03:49 PM
  #225
Sharif@Forged
Forged Performance
no, don't change all the cells...that will really mess things up if you make global changes. You need to log some pulls on the road, or preferably on a dyno. Once you have data logs, you can see what load sites you are hitting, and make changes to AF and timing. This is really hard to do on the road (especially timing control), so I would suggest the dyno.
Old Jun 18, 2008 | 04:33 PM
  #226
TinmansZ's Avatar
TinmansZ
I just installed the Aquamist HFS-5 water/meth kit, can you integrate the Utec with it in case of a clog or malfuction the Utec will pull fuel and or timing so you don't blow up?
Old Jun 18, 2008 | 06:49 PM
  #227
athenG's Avatar
athenG
Utec is not capable of that, you need a full standalone like Vpro if you want that feature. Oh if you have a clog then why would you want to pull more fuel? You want to add more or basically switch to different map.
Old Jun 19, 2008 | 01:45 PM
  #228
TinmansZ's Avatar
TinmansZ
Cuz I'm a dumb ***, and miss spoke. But thanks, I didn't think that the Utec could do such, and you confirmed it Thank You.
Old Aug 2, 2008 | 01:13 PM
  #229
WhiteOnWhite350z's Avatar
WhiteOnWhite350z
edit: nevermind
Old Aug 9, 2008 | 05:45 AM
  #230
armt350z's Avatar
armt350z
Quick question, is the speed limiter removed using open loop on the 03 non revup motors? would love it if someone can confirm this?
Old Aug 9, 2008 | 05:50 AM
  #231
frankie945's Avatar
frankie945
The utec will not remove speed limiter you can only raise rev limit.
Old Aug 9, 2008 | 05:55 AM
  #232
athenG's Avatar
athenG
curious, have you given up with UTI? Where you able to make it work?
Old Aug 9, 2008 | 06:11 AM
  #233
frankie945's Avatar
frankie945
Im going to try again this afternoon.. A cold front came through my area last night it's only going to be 80 deg. today. I was going through the utec last night and realized the Temp. Comp. Has all 0's my tuner I guess forgot to put anything in. I bet thats why my car run like crap on hot days.Last night it felt like a stock Z at idle at 78 deg.
Old Aug 10, 2008 | 05:18 AM
  #234
athenG's Avatar
athenG
Good luck. This is were UTI is great, it is very helpful adjusting the temp compensation when the IAT and A/F is also part of the log. It is also very helpful on comparing logs from different date since temperature varies from day to day.
Old Sep 18, 2008 | 03:18 PM
  #235
Barzten1's Avatar
Barzten1
Just to be clear when is the best time to or the only time to switch maps on the selector switch. During idle, while car is off or on the fly?
Old Sep 18, 2008 | 08:23 PM
  #236
12AutoX's Avatar
12AutoX
The manual says the motor has to be under 1800 rpms or so to change maps.
When adjusting ignition timing, what is a good amount of degrees to adjust by? .5? 1?
My load maxes out at 80%, and my MAF voltage tops out at 4.17. Should I reset my MAF calibration in the PARAMETERS to 4.2 for max MAF voltage, or will this cause a global change and screw everything up? I am thinking that the motor may be capable of higher loads if I do exhaust work, so maybe I should just leave the MAF setting alone?
Old Oct 14, 2008 | 11:08 AM
  #237
nothix's Avatar
nothix
Paid for by THMotorsports
Old Oct 15, 2008 | 06:08 AM
  #238
nothix's Avatar
nothix
could this lean spike at 5870 RPMs be caused by a knock detection?
Old Oct 15, 2008 | 08:05 AM
  #239
frankie945's Avatar
frankie945
Need to see your AFR's to tell for sure.. Add a log to your post.
Old Oct 15, 2008 | 08:19 AM
  #240
nothix's Avatar
nothix
the wideband is on order through THMotorsports.
Hopefully I can have some logs by this weekend.
