more questions about utec...
Old Aug 22, 2006 | 03:49 PM
  #161
Audible Mayhem's Avatar
Audible Mayhem
My350z
this is a very imformative thread about all kinds of things dealing with the utec for sure...
Old Aug 22, 2006 | 03:57 PM
  #162
Gators2001's Avatar
Gators2001
damn its was a good read!
Old Aug 22, 2006 | 07:30 PM
  #163
Kenk2's Avatar
Kenk2
Professional
^ +1 learned more today about tuning the utec than I did before I started reading this.. Thanks for the posts Julian, Sharif and J..
Old Aug 23, 2006 | 07:54 AM
  #164
QuadCam's Avatar
QuadCam
Sharif is right. There are so many things that jump out at you the more you look over the manual. at first, it looks overwhelming, but it is very straight forward.
Old Aug 23, 2006 | 08:18 AM
  #165
SmokyTyrz's Avatar
SmokyTyrz
Agreed. I'm on my second pass now. The first read was about "everything it does". The second read is about "what those things do" and "what I actually need to use". Looking forward to reading it again!
Old Aug 23, 2006 | 12:03 PM
  #166
Gators2001's Avatar
Gators2001
is the map on the unit the same as the one they have on the web?
Old Aug 23, 2006 | 12:38 PM
  #167
Kenk2's Avatar
Kenk2
Professional
I believe so... what are your mods?
Old Aug 23, 2006 | 02:47 PM
  #168
Gators2001's Avatar
Gators2001
Well, right now it exhaust, HF Catz, spacers, and intake.
Wanted to play with the unit before I put the turbos in.
Old Aug 23, 2006 | 04:40 PM
  #169
Juztin's Avatar
Juztin
Damn reading through this thread makes me want to learn how to tune my own car
Old Aug 23, 2006 | 04:53 PM
  #170
SmokyTyrz's Avatar
SmokyTyrz
I read through this thread and now I have a UTEC sitting next to me, waiting for me to finish learning before I install it.
Old Aug 23, 2006 | 05:27 PM
  #171
dchrastil's Avatar
dchrastil
Hey Audible, I've been taking my car to a guy in WY who does all my Utech tuning and he was showing me some of the nitrous features when we were tuning an evo with a 75 shot. Are you using the TPS and WOT (aux silenoid on/off after xxx, etc etc) for your nitrous though the UTEC too? oh, and i also saw they have a aux silenoid on/off on Coolant temp.... what do you think about that stuff?
just asking cause im gettin my nx setup put on this weekend and have to go retune it and all
Old Sep 26, 2006 | 02:25 PM
  #172
ACEMAN's Avatar
ACEMAN
Master
Thumbs up
Good Info in here
Later
Aceman
Old Sep 26, 2006 | 02:42 PM
  #173
Road Warrior's Avatar
Road Warrior
i wish someone could take all of the info in here and put it into a word document so its easy to read.
Old Sep 26, 2006 | 08:41 PM
  #174
SmokyTyrz's Avatar
SmokyTyrz
I'm working on something to help arrange the knowledge a little better. Stay tuned...
Old Oct 6, 2006 | 08:06 AM
  #175
Road Warrior
on your timing maps...are you guys changing all of your values from 10%-100%?
also, do you need to change any knock sensor values before logging?
i have a bosch knock sensor installed on mine but i am wondering if the stock knock sensor would be more accurate because of its location.
Old Feb 10, 2008 | 10:07 AM
  #176
mw9's Avatar
mw9
Originally Posted by Sharif@Forged
You missed the point. On an NA car, as soon as you go to WOT, you come very close to 0psi, as the vaccum is deminished. This spread of resolution is tiny. Why would pay extra for a MAP sensor, only to have a very restricted resolution, when you can use the full spectrum of the factory MAF sensor as your load reference?
Using MAF is your load reference is the best and most accurate method of tuning an NA car. Hell, if we had the resolution, its the best way to tune an FI car as well.
Using MAF is how you guys tune cars on the dyno and if I want to do some tuning on my own I should get the txs tuner? Thanks
Old Feb 11, 2008 | 04:32 AM
  #177
QuadCam's Avatar
QuadCam
you pulled this one out from the depths.
if tuning on your own, get the TXS Tuner wideband. It just makes everything so easy to datalog. You can use other widebands for datalogging, but then you have to use another program to log the UTEC info and your wideband info together. then, you'd have to go back into the utec to make changes......not as nice as using the TXS tuner wideband, where everything is done within the same utec connection.
Old Feb 11, 2008 | 05:48 AM
  #178
zerosec's Avatar
zerosec
i'll be using the UTEC with the APS TT pretty soon
btw guys, the UTEC has a BC right? no need to buy an EBC...
Old Feb 11, 2008 | 01:40 PM
  #179
athenG's Avatar
athenG
/\ You still need the Utec BCS to be able to control your boost.
Old Feb 11, 2008 | 02:36 PM
  #180
zerosec's Avatar
zerosec
Doens't the utec have an integrated BC? i might just need to order the solenoid
