more questions about utec...
Old Apr 25, 2006 | 06:06 PM
  #141
Audible Mayhem's Avatar
Audible Mayhem
My350z
i wish cause i love to take useless stuff outta my car....
Old Apr 27, 2006 | 02:51 PM
  #142
mxjosh711's Avatar
mxjosh711
i have a utec, im willing to pay any of you to help me out with it. IM located in st louis and Kansas city... PM me if any of you are interested. Local shop wants 250 bucks, im sure one of you needs the cash more than they do. ALSO, do you have to have a afr gauge to tune it or does it read those numbers for you?
Old Apr 27, 2006 | 09:21 PM
  #143
RED RIDER's Avatar
RED RIDER
Originally Posted by Sharif@Forged
The MAF sensor maxes out a little bit more than 300whp, so even 5-6psi will max out the MAF sensor. A MAP sensor is required for FI.
sharif...hey sorry..not trying to hijack thread but OMG where can I get some of these rims on this car which is from your website????
http://www.injectedperformance.com/V...ID=3515&VID=36
TIA
Tom
Old Apr 28, 2006 | 06:47 AM
  #144
Road Warrior's Avatar
Road Warrior
TIA
Tom
how about a pm...that works better
Old Apr 28, 2006 | 06:08 PM
  #145
Audible Mayhem
My350z
TIA
Tom
little OT there buddy... like to say thanks again to the guys at turboxs for helping out on my tuner wb little situation...
Old Apr 28, 2006 | 06:09 PM
  #146
Audible Mayhem
My350z
if i was closer i would help. im in orlando though...
Old Apr 28, 2006 | 07:40 PM
  #147
mxjosh711's Avatar
mxjosh711
Default utec
well since your in orlando i might as well take a trip lol.... i used to live in vero beach..
Old Apr 29, 2006 | 01:59 AM
  #148
Audible Mayhem
My350z
i know there are a few shops in TX that could tune your utec if you dont want to mess with it. if you buy the tuner wideband and know a local dyno, we could probably tune your car pretty easily....
Old May 9, 2006 | 02:27 PM
  #149
Audible Mayhem
My350z
is this thread officially dead now??
Old May 9, 2006 | 02:59 PM
  #150
ACEMAN's Avatar
ACEMAN
Master
I wouldn't say its dead. Lots of good info in here. Hows things going on your side? Still waiting to see what you get out of your car. With the Utec and that crazy carved up lower Plenum
Later
Aceman
Old May 9, 2006 | 07:10 PM
  #151
JG 350Z's Avatar
JG 350Z
I was just reading this thread as I recently got the tuner and starting logging, adjusting timing, fuel etc... but I got a question for you guys, are you running open loop fueling with the MAF option?
According to the manual...
When Open Loop Fuelling is enabled, the UTEC uses its own background fuel table to determine injector ontime instead of the factory ECU’s fuel table once the car is past the Open Loop Threshold parameter setting.
seems like the lowest value for the injector size is 300cc but don't we run 290cc? I get strange readings on the injector duty cycle, like hitting 99.9% at arounf 6100-6200 rpms! It doesn't look like the utec's fuel table would work. Tuning in closed loop mode it runs fine.
Old May 9, 2006 | 07:22 PM
  #152
Julian@MRC's Avatar
Julian@MRC
To do this you would need to add a MAP sensor, leave the injector scaling in the parameters set to 380/380 and use the 0% load column to scale the inectors, then 10%-100% load would be in actual IPW in milliseconds..
Old May 9, 2006 | 07:41 PM
  #153
JG 350Z's Avatar
JG 350Z
OK, thanks but would the Load Indicator still be the MAF or MAP? The manual just doesn't seem too clear regarding this.
Old May 11, 2006 | 01:04 PM
  #154
Audible Mayhem
My350z
yes everything is great here, been really busy. i actually have to work fri sat sun mon tue and off for over a week so lots of fun to happen with the car.....
Old Jun 11, 2006 | 02:44 PM
  #155
Audible Mayhem
My350z
why didnt this make the tuning section!!!
Old Jun 11, 2006 | 02:53 PM
  #156
Audible Mayhem
My350z
dp... oops
Old Jun 11, 2006 | 05:30 PM
  #157
DavesZ#3's Avatar
DavesZ#3
What 'cha talkin 'bout Willis? It's in the Tuning section
Old Jun 11, 2006 | 05:32 PM
  #158
Audible Mayhem
My350z
hmm.... if i didnt know you were a moderator.... then i would think you were kiddin!!
Old Aug 21, 2006 | 09:31 PM
  #159
SmokyTyrz's Avatar
SmokyTyrz
Wanted to revive this post. It has lots of good "out of box" experience information for UTEC noob's like me.
Old Aug 22, 2006 | 02:33 PM
  #160
ACEMAN's Avatar
ACEMAN
Master
I know i learned alot with this thread
Later
Aceman
