UTEC 'Upgrade?'
Old Feb 10, 2014 | 01:45 PM
  #461
djamps's Avatar
djamps
UTEC and Uprev actually compliment each other well... uprev adds injector scaling and fueling to deal with vacuum tuning (where you spend 99% of life) in addition to cam phasing. UTEC just pulls MAF voltage in vacuum which ends up with too much timing and lean fueling at low load - uprev fixes that. Injectors over 440cc are going to be a impossible to dial in properly without Uprev especially without a fuel return.
And while in boost, UTEC provides more reliable MAP based tuning, overboost cut and far better knock control.
Originally Posted by Cux350z
The interface is old school and not a lot of columns in the tuning tables but it is definitely a very capable piece of hardware.
Would definitely use it over uprev like str8dum said.
Map, boost control,safeguards, datalogging....and your not flashing your OEM ecu. Multiple maps, easy map switching without steering wheel controls...user tunable with free software.
Old Feb 25, 2014 | 04:45 AM
  #462
Z33Garage's Avatar
Z33Garage
Originally Posted by djamps
+1. UTEC's are underrated by this community... just as long as you got a 'good' one that doesn't blow coil packs or induce limp mode. My Z has been boosted for 70k miles (130k total) with a UTEC and 440cc's. Drives like stock still making 400+WHP.
The one I got was bricked when the old user attempted to flash the rom and (my guess) his battery died. He did not know how to fix this so he sold it as broken to me for 40 bucks. I re-reflashed it correctly and BAM! works. However I have not attached it to the Z because I am uncertain on how it works, a.k.a how do I just use it for monitoring and not have it override the stock ECU maps/ signals.
That is what I have been reading, its safer in my book that a uprev because if anything happens its as easy as unpugging it from the ecu. Now I am trying to get the software for monitoring, my only issue is the lack of professional tuners anywhere near me, and even though I am Na and I know I will benefit from a tune, I think the only thing I can do is blow the motor if I try it. : /
I plan to go FI in the future ( after the Z is paid and I get a used truck for DD) so I was on the edge about selling the utec and getting the uprev now. But I will keep the Utec and learn more on how to use it with n.a. Maybe I can find someone to help me out locally.
Old Feb 6, 2015 | 11:57 PM
  #463
inthestiks29's Avatar
inthestiks29
Default turboxs MAP sensor
cant find a used MAP sensor. is there any other sensor on the market compatible with the utec? im in need of one to go FI.
Old Feb 11, 2015 | 04:07 AM
  #464
Rick*K's Avatar
Rick*K
Interesting to hear a UTEC could blow coils. I have had to replace 3 coils in the 8-9 years my car has had UTEC installed.
Old Mar 9, 2015 | 06:05 PM
  #465
trusovici's Avatar
trusovici
Default mps still available
hey i know im a little late to the party but I cant pay for the mps logger software. The link to payment on the site is not hosted anymore. any ideas as to what i should do? anyone have a crack for the trial version?
Old May 16, 2015 | 06:07 AM
  #466
trusovici's Avatar
trusovici
Default utec problem
was wondering if anyone had any advice for me. I bought a used utec a while back, just installed it today. The car starts and idles fine but the check engine, tcs off, and slip lights all come on and i can not rev past 2k rpm. I can communicate with it through hyperterminal. I tried a few different maps and even when i use the 0 map the problem remains. Any help would be appreciated.
2ndchanceZ
Oct 26, 2015 08:03 PM
